    MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs
    43 Posts 7 Posters 16.3k Views 7 Watching
    • V
      Volkae @KristjanESPERANTO
      @KristjanESPERANTO said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
      @sdetweil said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
      @Volkae @p1lspeda @KristjanESPERANTO will have to advise next steps
      I need the system information part from the logs. Like this:
      [2025-01-14 20:05:03.529] [INFO]  System information:
      ### SYSTEM:    manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false
      ### OS:        platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.1.21-v8+
      ### VERSIONS:  electron: 31.2.1; used node: 20.15.0; installed node: 22.4.1; npm: 10.8.1; pm2:
      ### OTHER:     timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
      Sorry, but I am not sure how to see this informations
      • KristjanESPERANTOK
        KristjanESPERANTO Module Developer @Volkae
        @Volkae said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
        “version”: “2.30.0”,
        You need to update MagicMirror. The module doesn’t work anymore with MagicMirror version 2.30.0.
          sdetweil @Volkae
          @Volkae that means the upgrade didn’t execute
          copy/paste and execute this in a terminal window on the MagicMirror system
          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"  apply
            p1lspeda @p1lspeda
            @p1lspeda said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
            Here you go
            [2025-05-06 06:46:30.229] [INFO]  System information:
            ### SYSTEM:   manufacturer: ; model: ; virtual: false
            ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-v8
            ### VERSIONS: electron: 32.2.7; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
            Although it is not listed, I am running a Raspberry Pi 4
            pi@magicmirror:~ $ lscpu
            Architecture:             aarch64
              CPU op-mode(s):         32-bit, 64-bit
              Byte Order:             Little Endian
            CPU(s):                   4
              On-line CPU(s) list:    0-3
            Vendor ID:                ARM
              Model name:             Cortex-A72
                Model:                3
                Thread(s) per core:   1
                Core(s) per cluster:  4
                Socket(s):            -
                Cluster(s):           1
                Stepping:             r0p3
                CPU(s) scaling MHz:   50%
                CPU max MHz:          1800.0000
                CPU min MHz:          600.0000
                BogoMIPS:             108.00
                Flags:                fp asimd evtstrm crc32 cpuid
            Caches (sum of all):
              L1d:                    128 KiB (4 instances)
              L1i:                    192 KiB (4 instances)
              L2:                     1 MiB (1 instance)
            NUMA:
              NUMA node(s):           1
              NUMA node0 CPU(s):      0-3
            Vulnerabilities:
              Gather data sampling:   Not affected
              Itlb multihit:          Not affected
              L1tf:                   Not affected
              Mds:                    Not affected
              Meltdown:               Not affected
              Mmio stale data:        Not affected
              Reg file data sampling: Not affected
              Retbleed:               Not affected
              Spec rstack overflow:   Not affected
              Spec store bypass:      Vulnerable
              Spectre v1:             Mitigation; __user pointer sanitization
              Spectre v2:             Vulnerable
              Srbds:                  Not affected
              Tsx async abort:        Not affected
            S KristjanESPERANTOK 2 Replies Last reply
              sdetweil @p1lspeda
              @p1lspeda have you tried the upgrade script?
              I believe the module requires 2.31.0 as a minimum MM version now
                KristjanESPERANTO Module Developer @p1lspeda
                You still need to upgrade MagicMirror. I recommend the official upgrade process.
                P 1 Reply Last reply
                • V
                  Volkae
                  I used the update script again and now MM is 2.31.0
                  MMM-PublicTransportHafas works again, that`s fine, but now MMM-SmartWebDisplay is gone…
                  Not fine…
                    sdetweil @Volkae
                    @Volkae any errors listed in MagicMirror startup?
                    V 1 Reply Last reply
                    • V
                      Volkae @sdetweil
                      Sorry, I don`t know how to show the errors during startup :-(
                        sdetweil @Volkae
                        @Volkae where does npm start output
                        if using pm2 tge
                        pm2 logs --lines=xxx
                        xxx is the number of most recent lines
                        default 15
                        probably 100 good start
                        note the output comes in 2 parts
                        error and output
                        • V
                          Volkae @sdetweil
                          Not using pm2
                          using cronjob to start MM
                            sdetweil @Volkae
                            @Volkae i forgot to mention that the full calendar url
                            is shown
                            i have deleted the other message
                            • V
                              Volkae @sdetweil
                              Upps,
                              thank you!!!
                                @KristjanESPERANTO
                                I’ve upgraded to the latest MM Version
                                pi@magicmirror:~/MagicMirror $ grep version package.json
                                        "version": "2.31.0-develop",
                                [2025-05-07 09:57:22.742] [INFO]  System information:
                                And I still get this error
                                [2025-05-07 09:57:19.297] [ERROR] Error when loading MMM-PublicTransportHafas: require() of ES Module /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs not supported.
                                Instead change the require of /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs to a dynamic import() which is available in all CommonJS modules.
                                My module version:
                                pi@magicmirror:~/MagicMirror/modules/MMM-PublicTransportHafas $ grep version package.json
                                  "version": "3.1.11",
                                pi@magicmirror:~/MagicMirror/modules/MMM-PublicTransportHafas $ git pull
                                Already up to date.
                                I do not know what else I can do or what I have missed
                                mumblebajM karsten13K 2 Replies Last reply
                                • mumblebajM
                                  mumblebaj Module Developer @p1lspeda
                                  @p1lspeda
                                  I just done a fresh install of the module and it works fine for me.
                                  Just out of curiosity, did you do the following steps?
                                  • cd MMM-PublicTransportHafas
                                  • npm ci --omit=dev
                                  @KristjanESPERANTO ) saw the below in the log, I am assuming it is nothing to be concerned about?
                                  • karsten13K
                                    karsten13 @p1lspeda
                                    not really, 2.31.0-develop <> 2.31.0
                                    KristjanESPERANTOK 1 Reply Last reply
                                      KristjanESPERANTO Module Developer @karsten13
                                      @p1lspeda How did you perform the MagicMirror update? Please show us the output of git branch when you are in the MagicMirror root directory.
                                      S P 2 Replies Last reply
                                        sdetweil @KristjanESPERANTO
                                        @KristjanESPERANTO looks like he was on the dev branch for a fix and didn’t use my script to update or follow the instructions I posted
                                        https://forum.magicmirror.builders/topic/19561/version-2.31.0-april-1-2025-upgrade-reminder
                                          @KristjanESPERANTO
                                          Thanks for your patience,
                                          Edit: did a complete reinstall and now it works. I must have misconfigured something and could not remember what or how.
                                          This is what I have done:
                                          • I switched to the master branch yesterday and ran @sdetweil 's update script no change
                                          • I’ve done a fresh module install - no change
                                          • I’ve ran @sdetweil 's upgrade script - no change
                                          pi@magicmirror:~/MagicMirror $ git branch
                                            _fix_clipping
                                          * master
                                          pi@magicmirror:~/MagicMirror $ cd modules/MMM-PublicTransportHafas/
                                          pi@magicmirror:~/MagicMirror/modules/MMM-PublicTransportHafas $ npm ci --omit=dev
                                          > mmm-publictransporthafas@3.1.11 prepare
                                          > [ -f node_modules/.bin/husky ] && husky || echo husky is not installed.
                                          added 63 packages, and audited 64 packages in 20s
                                          19 packages are looking for funding
                                            run `npm fund` for details
                                          found 0 vulnerabilities
                                                  "version": "2.31.0",
                                          Here’s my config.js
        module: "MMM-PublicTransportHafas",
        stationID: "000405041",                   // Replace with your stationID!
        stationName: "Höfchen/Listmann",   // Replace with your station name!
        direction: "",                    // Show only departures heading to this station. (A station ID.)
        ignoredLines: [],                 // Which lines should be ignored? (comma-separated list of line names)
        excludedTransportationTypes: [],  // Which transportation types should not be shown on the mirror? (comma-separated list of types) possible values: StN for >
        timeToStation: 10,                // How long do you need to walk to the next Station?
        showColoredLineSymbols: true,     // Want colored line symbols?
        useColorForRealtimeInfo: true,    // Want colored real time information (timeToStation, early)?
        showTableHeadersAsSymbols: true,  // Table Headers as symbols or text?
        maxUnreachableDepartures: 0,      // How many unreachable departures should be shown?
        maxReachableDepartures: 10,        // How many reachable departures should be shown?
        customLineStyles: "",             // Prefix for the name of the custom css file. ex: Leipzig-lines.css (case sensitive)
        showOnlyLineNumbers: false        // Display only the line number instead of the complete name, i. e. "11" instead of "STR 11"
                                          The error still occurs.
                                          At this point I’m completely clueless
                                          • V
                                            Vulan12354
                                            Hello together,
                                            i tried your instruction and updated MM and node.
                                            My node Version is 23.7.0
                                            My MM Version is 2.31.0
                                            git branch shows me master (highlighted)
                                            I also updated the module Version to: “3.1.11”
                                            Still got the error message.
                                            • 2 / 3
