    MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs
    43 Posts 7 Posters 16.3k Views 7 Watching
      sdetweil @p1lspeda
      @p1lspeda just fyi, if you use the upgrade script it will npm install all the modules that have a package.json with dependencies after completing the MagicMirror upgrade
        sdetweil @Volkae
        @Volkae @p1lspeda @KristjanESPERANTO will have to advise next steps
        KristjanESPERANTOK 1 Reply Last reply
        • KristjanESPERANTOK
          @sdetweil said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
          I need the system information part from the logs. Like this:
          [2025-01-14 20:05:03.529] [INFO]  System information:
          ### SYSTEM:    manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false
          ### OS:        platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.1.21-v8+
          ### VERSIONS:  electron: 31.2.1; used node: 20.15.0; installed node: 22.4.1; npm: 10.8.1; pm2:
          ### OTHER:     timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
          P V 2 Replies Last reply
            @KristjanESPERANTO said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
            Here you go
            [2025-05-06 06:46:30.229] [INFO]  System information:
            ### SYSTEM:   manufacturer: ; model: ; virtual: false
            ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-v8
            ### VERSIONS: electron: 32.2.7; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
            P 1 Reply Last reply
            • V
              Volkae @sdetweil
              node -v
              grep version package.json
              22.14.0
              “version”: “2.30.0”,
              KristjanESPERANTOK S 2 Replies Last reply
              • V
                Volkae @KristjanESPERANTO
                Sorry, but I am not sure how to see this informations
                  KristjanESPERANTO Module Developer @Volkae
                  @Volkae said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
                  You need to update MagicMirror. The module doesn’t work anymore with MagicMirror version 2.30.0.
                    sdetweil @Volkae
                    @Volkae that means the upgrade didn’t execute
                    copy/paste and execute this in a terminal window on the MagicMirror system
                    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"  apply
                      p1lspeda @p1lspeda
                      @p1lspeda said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
                      Here you go
                      Although it is not listed, I am running a Raspberry Pi 4
                      pi@magicmirror:~ $ lscpu
                      Architecture:             aarch64
                        CPU op-mode(s):         32-bit, 64-bit
                        Byte Order:             Little Endian
                      CPU(s):                   4
                        On-line CPU(s) list:    0-3
                      Vendor ID:                ARM
                        Model name:             Cortex-A72
                          Model:                3
                          Thread(s) per core:   1
                          Core(s) per cluster:  4
                          Socket(s):            -
                          Cluster(s):           1
                          Stepping:             r0p3
                          CPU(s) scaling MHz:   50%
                          CPU max MHz:          1800.0000
                          CPU min MHz:          600.0000
                          BogoMIPS:             108.00
                          Flags:                fp asimd evtstrm crc32 cpuid
                      Caches (sum of all):
                        L1d:                    128 KiB (4 instances)
                        L1i:                    192 KiB (4 instances)
                        L2:                     1 MiB (1 instance)
                      NUMA:
                        NUMA node(s):           1
                        NUMA node0 CPU(s):      0-3
                      Vulnerabilities:
                        Gather data sampling:   Not affected
                        Itlb multihit:          Not affected
                        L1tf:                   Not affected
                        Mds:                    Not affected
                        Meltdown:               Not affected
                        Mmio stale data:        Not affected
                        Reg file data sampling: Not affected
                        Retbleed:               Not affected
                        Spec rstack overflow:   Not affected
                        Spec store bypass:      Vulnerable
                        Spectre v1:             Mitigation; __user pointer sanitization
                        Spectre v2:             Vulnerable
                        Srbds:                  Not affected
                        Tsx async abort:        Not affected
                      S KristjanESPERANTOK 2 Replies Last reply
                        sdetweil @p1lspeda
                        @p1lspeda have you tried the upgrade script?
                        I believe the module requires 2.31.0 as a minimum MM version now
                          KristjanESPERANTO Module Developer @p1lspeda
                          You still need to upgrade MagicMirror. I recommend the official upgrade process.
                          • V
                            Volkae
                            I used the update script again and now MM is 2.31.0
                            MMM-PublicTransportHafas works again, that`s fine, but now MMM-SmartWebDisplay is gone…
                            Not fine…
                              sdetweil @Volkae
                              @Volkae any errors listed in MagicMirror startup?
                              V 1 Reply Last reply
                              • V
                                Volkae @sdetweil
                                Sorry, I don`t know how to show the errors during startup :-(
                                  sdetweil @Volkae
                                  @Volkae where does npm start output
                                  if using pm2 tge
                                  pm2 logs --lines=xxx
                                  xxx is the number of most recent lines
                                  default 15
                                  probably 100 good start
                                  note the output comes in 2 parts
                                  error and output
                                  • V
                                    Volkae @sdetweil
                                    Not using pm2
                                    using cronjob to start MM
                                      sdetweil @Volkae
                                      @Volkae i forgot to mention that the full calendar url
                                      is shown
                                      i have deleted the other message
                                      • V
                                        Volkae @sdetweil
                                        Upps,
                                        thank you!!!
                                          @KristjanESPERANTO
                                          I’ve upgraded to the latest MM Version
                                          pi@magicmirror:~/MagicMirror $ grep version package.json
                                                  "version": "2.31.0-develop",
                                          [2025-05-07 09:57:22.742] [INFO]  System information:
                                          And I still get this error
                                          [2025-05-07 09:57:19.297] [ERROR] Error when loading MMM-PublicTransportHafas: require() of ES Module /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs not supported.
                                          Instead change the require of /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs to a dynamic import() which is available in all CommonJS modules.
                                          My module version:
                                          pi@magicmirror:~/MagicMirror/modules/MMM-PublicTransportHafas $ grep version package.json
                                            "version": "3.1.11",
                                          pi@magicmirror:~/MagicMirror/modules/MMM-PublicTransportHafas $ git pull
                                          Already up to date.
                                          I do not know what else I can do or what I have missed
                                          mumblebajM karsten13K 2 Replies Last reply
                                          • mumblebajM
                                            mumblebaj Module Developer @p1lspeda
                                            @p1lspeda
                                            I just done a fresh install of the module and it works fine for me.
                                            Just out of curiosity, did you do the following steps?
                                            • cd MMM-PublicTransportHafas
                                            • npm ci --omit=dev
                                            @KristjanESPERANTO ) saw the below in the log, I am assuming it is nothing to be concerned about?
