    MMM-Chores - Manage and keep track of your household Chores
    84 Posts 15 Posters 24.1k Views 16 Watching
      sdetweil @khayfer
      @khayfer address:“localhost”
      means ONLY apps INSIDE the same system can connect, means a browser started from the desktop
      if you want to use another system, set
      address:“0.0.0.0”,
      • K Offline
        khayfer @sdetweil
        @sdetweil I changed it to 0.0.0.0 and it still says it could not connect to the server :-/
          sdetweil @khayfer
          @khayfer can you open the MagicMirror page from that machine?
          many browsers have started to implement local network access security. i know on my mac, i cannot access my 3d print server w chrome anymore. i have to use safari
          • K Offline
            khayfer @sdetweil
            @sdetweil yes, I’m able to use the browser in the pi. I can navigate the internet no problem, but the moment I type the ip address, it still says could not connect to the server.
            I then tried it on multiple different devices/browsers on the same wifi and they all say the same thing.
              sdetweil @khayfer
              @khayfer and you are doing
              http://address:port
              for MagicMirror
              port from config.js
              on the same machine
              you can use localhost
              http://localhost:8080
              ip addr
              will give you the address of the pi
              from your laptop
              http://xxxxx:8080
              where xxxxx was the addr from ip addr
                mischag
                my MMM-Chores is playing up big time now…
                after the last update, not the most recent one, but the one before that, my chores list now is just a long list of everything coming up for ever…
                it’s not just displaying the next days chores, but every chore. and if you tick off a chore being completed, it then just add’s that next time the chore is due to the bottom of the list. and there’s no end in sight on my magic mirror, but also no end in sight for the admin page. I’ll ‘complete’ a job, but then it just adds it to the bottom of the page…
                anyone else having major issues with it? was working great before… and I worked out that the magic mirror needs to be running to get into the admin portal page. but now my mirror just looks like this…
                Any help much appreciated as the kids can’t tick off when completed anymore…
                PierreGodeP 2 Replies Last reply Reply Quote 0
                • PierreGodeP Offline
                  PierreGode Module Developer @mischag
                  @mischag Hi!
                  latest update a lot settings has being moved to the webpage.
                  It should work with the old config.js but might be acting up.
                  try with the new settings. enabling show past tasks will show only past tasks that are not completed.
                  make sure your config.js has
                    module: "MMM-Chores",
                    position: "bottom_right",
                    header: "Chores",
                      updateInterval: 60 * 1000,
                      adminPort: 5003,
                      openaiApiKey: "your-openApi-key here",
                      settings: "unlocked", // set a 6 digit pin like "000000" to lock settings popup with a personal pin, change 000000 to any 6 digit password you want, or comment this out to lock settings completely
                  // other options can be set in the admin portal
                      levelTitles: [
                      // titles for every 10 levels
                        "Junior",
                        "Apprentice",
                        "Journeyman",
                        "Experienced",
                        "Expert",
                        "Veteran",
                        "Master",
                        "Grandmaster",
                        "Legend",
                        "Mythic"
                    @mischag said in MMM-Chores - Manage and keep track of your household Chores:
                    PierreGodeP 1 Reply Last reply Reply Quote 0
                      PierreGode Module Developer @PierreGode
                      If you cant make the new settings work for you, you could jump back to an older version
                      git checkout uiimproovments and restart the module
                        JohnGalt @PierreGode
                        @PierreGode – What does the ‘Chores per Week Estimate’ do?
                        What is it estimating, and what does it do with the estimate?
                        • 6
                        • 7
                        • 8
                        • 9
                        • 7 / 9
