    MMM-Chores - Manage and keep track of your household Chores
    104 Posts 19 Posters 36.6k Views 20 Watching
      JohnGalt @PierreGode
      @PierreGode – Great! I went in and did a ‘git pull’, and indeed that functionality now works.
        @PierreGode – Can you clarify your comment above comment above [quoted below]? If I read this correctly, the module is exposing the data it has to be scraped by AI engines.
        " … everything is still stored in data.json file and AI can use that as information "
        PierreGodeP 1 Reply Last reply Reply Quote 0
        • PierreGodeP Offline
          PierreGode Module Developer @JohnGalt
          @JohnGalt
          All tasks and peope are stored in data.json even if you delete them (softdelete) . this is so both analytics page can view history and also so the AI generate can use your completed task as information. when you press AI generate it will read the data.json and look for all completed task deleted or not, and use that to create tasks for coming week.
            PierreGode Module Developer @redbeardedninja
            @redbeardedninja Hi this has now being added to latest update!
            you can now check the checkboxes directly on the mirror it self. (touch screen also works)
            ( the web admin portal will not update directly unless you refresh the page)
            What i found hard is that the mouse is invisible on magic mirror but if you manage to find the checkboxes they will be clickable. ( meaby a setting that can be tampered with)
            KristjanESPERANTOK S R 3 Replies Last reply Reply Quote 0
            • KristjanESPERANTOK Offline
              KristjanESPERANTO Module Developer @PierreGode
              @PierreGode said in MMM-Chores - Manage and keep track of your household Chores:
              MMM-Cursor can solve that 🙂
                sdetweil @PierreGode
                @PierreGode just change it to not hidden using custom.css
                html {
                cursor:default;
                or use unclutter (have apt install it) will only be visible when you move it
                it is hidden on purpose(in msin.css), an output only panel couldn’t use it
                  KristjanESPERANTO Module Developer @sdetweil
                  @sdetweil said in MMM-Chores - Manage and keep track of your household Chores:
                  I think unclutter doesn’t work on modern systems (Wayland).
                    sdetweil @KristjanESPERANTO
                    @KristjanESPERANTO true
                    similar options
                    https://bist.be/posts/unclutterwayland/
                      redbeardedninja @PierreGode
                      @PierreGode thanks so much! The new update works like a charm. Now for me to work on the custom css to make the module a bit larger…
                      PierreGodeP 2 Replies Last reply Reply Quote 1
                        @PierreGode – Thanks for the update on the data being available to AI. Since I don’t want my data available, I will just delete the module folder and remove it from the config file.
                        Can you confirm that data is NOT stored anywhere outside the module folder? Thanks in advance.
                          @redbeardedninja
                          I will add that a little bit later so sizes an be modified from config.js
                            @JohnGalt
                            No need to set your device on fire.
                            The data is only stored in the module folder /MMM-Chores/ in data.json and will NOT be shared with anything unless you add the openapi token.
                            No openai api token = no data leaving your device.
                            If you want to use ai with api token
                            1. ONLY content of modules/MMM-Chores/data.json is shared.
                            2. data.json is my file were I store the content of admin page, for security I convert users to ID’s
                            3. NOTHING gets sent unless YOU press the AI genrste button.
                              @PierreGode – OK, good to know. Thanks for the quick response.
                              PierreGodeP 2 Replies Last reply Reply Quote 0
                                @JohnGalt
                                I will add an option in config.js to disable AI from being configurable and hide the AI button
                                  @redbeardedninja
                                  Hi! You can now use in config.js
                                  textMirrorSize: “small”, // small, medium or large
                                    @JohnGalt
                                    Hi, you can now disable AI in config.js
                                    useAI: false, // hide AI features when false
                                      sarote
                                      Hi @PierreGode ! Thank for your job, one of the best modules for MagicMirror. Is it possible to show analtitycs graphs on the mirror screen?if not, are you planning to implement it?
                                        PierreGode Module Developer @sarote
                                        @sarote
                                        Hi! No it it’s not possible…
                                        But I will plan to implement it upon your request.
                                        I will let you now. If you wish to track the progress please create a ticket ”issue” in GitHub with the request.
                                        //Pierre
                                          sarote @PierreGode
                                          @PierreGode Great! i will do,thanks for your job
                                            mischag @PierreGode
                                            @PierreGode
                                            Hi there,
                                            I’m loving the idea behind this module.
                                            But, I can’t work out how to open the admin interface??
                                            I’ve tried the ip address that I’m using to remote into the raspberry pi, but it’s not working? I’m trying using tigervnc on a mac, do I need to physically do it on the raspberry pi? I thought I could do it whilst on the same network?
                                            Any ideas at all?
                                            Just keeps saying can’t connect to the server…
                                            Thanks heaps,
                                            Mischa
                                            J PierreGodeP 2 Replies Last reply Reply Quote 0
                                            • 6
                                            • 2 / 6
