    MMM-Chores - Manage and keep track of your household Chores
    104 Posts 19 Posters 41.5k Views 20 Watching
    • KristjanESPERANTOK Offline
      @sdetweil said in MMM-Chores - Manage and keep track of your household Chores:
      or use unclutter (have apt install it) will only be visible when you move it
      I think unclutter doesn’t work on modern systems (Wayland).
        sdetweil @KristjanESPERANTO
        @KristjanESPERANTO true
        similar options
        https://bist.be/posts/unclutterwayland/
          redbeardedninja @PierreGode
          @PierreGode thanks so much! The new update works like a charm. Now for me to work on the custom css to make the module a bit larger…
          PierreGodeP 2 Replies Last reply Reply Quote 1
            JohnGalt @PierreGode
            @PierreGode – Thanks for the update on the data being available to AI. Since I don’t want my data available, I will just delete the module folder and remove it from the config file.
            Can you confirm that data is NOT stored anywhere outside the module folder? Thanks in advance.
            PierreGodeP 1 Reply Last reply Reply Quote 0
            • PierreGodeP Offline
              PierreGode Module Developer @redbeardedninja
              @redbeardedninja
              I will add that a little bit later so sizes an be modified from config.js
                PierreGode Module Developer @JohnGalt
                @JohnGalt
                No need to set your device on fire.
                The data is only stored in the module folder /MMM-Chores/ in data.json and will NOT be shared with anything unless you add the openapi token.
                No openai api token = no data leaving your device.
                If you want to use ai with api token
                1. ONLY content of modules/MMM-Chores/data.json is shared.
                2. data.json is my file were I store the content of admin page, for security I convert users to ID’s
                3. NOTHING gets sent unless YOU press the AI genrste button.
                  @PierreGode – OK, good to know. Thanks for the quick response.
                  PierreGodeP 2 Replies Last reply Reply Quote 0
                    @JohnGalt
                    I will add an option in config.js to disable AI from being configurable and hide the AI button
                      @redbeardedninja
                      Hi! You can now use in config.js
                      textMirrorSize: “small”, // small, medium or large
                        @JohnGalt
                        Hi, you can now disable AI in config.js
                        useAI: false, // hide AI features when false
                          sarote
                          Hi @PierreGode ! Thank for your job, one of the best modules for MagicMirror. Is it possible to show analtitycs graphs on the mirror screen?if not, are you planning to implement it?
                            PierreGode Module Developer @sarote
                            @sarote
                            Hi! No it it’s not possible…
                            But I will plan to implement it upon your request.
                            I will let you now. If you wish to track the progress please create a ticket ”issue” in GitHub with the request.
                            //Pierre
                              sarote @PierreGode
                              @PierreGode Great! i will do,thanks for your job
                                mischag @PierreGode
                                @PierreGode
                                Hi there,
                                I’m loving the idea behind this module.
                                But, I can’t work out how to open the admin interface??
                                I’ve tried the ip address that I’m using to remote into the raspberry pi, but it’s not working? I’m trying using tigervnc on a mac, do I need to physically do it on the raspberry pi? I thought I could do it whilst on the same network?
                                Any ideas at all?
                                Just keeps saying can’t connect to the server…
                                Thanks heaps,
                                Mischa
                                J PierreGodeP 2 Replies Last reply Reply Quote 0
                                  JohnGalt @mischag
                                  @mischag – Are you using the port described in the documentation [5003]?
                                  See:
                                  Admin Interface
                                  Go to http://yourmirrorIP:5003/ #page will be reachable within same network.
                                  Caution
                                  DO NOT expose application with portforward
                                    mischag @JohnGalt
                                    @JohnGalt
                                    Yeah, I am. But I’m wondering if it’s because I am remoting in on a different port, that I can’t then access that port? I’ve checked the documentation heaps and can’t work it out. I even tried opening the html admin file within the ‘public’ folder, and I can open it but I can’t edit it. I can write the names and click on dates and everything, but when I press ‘add’ nothing happens. I’ve updated and it says it’s all up to date.
                                    • plainbrokeP Offline
                                      plainbroke @mischag
                                      @mischag
                                      This is what I get when I login to MMMChores admin
                                      http://192.168.1.223:5003
                                      https doesn’t work for me. I don’t have it setup to work in my config.js.
                                      Are you trying to reach it from work or from home and it is in another building???
                                        mischag @plainbroke
                                        @plainbroke
                                        Yeah ok. I might have to try another way… but it’s definitely not working at the moment for me…
                                        The port doesn’t bring anything up for me other than the page saying it does not exist.
                                        I was hoping not to have it setup through the config folder but it was the only way I could find the admin interface. But then I couldn’t add people or tasks to it…
                                        plainbrokeP S 2 Replies Last reply Reply Quote 0
                                          plainbroke @mischag
                                          @mischag
                                          So are you trying to change things by going into MM/modules/MMM-Chores/data.json and editing it? I just tried that and it does not work.
                                          I think it is because the module assigns each grouping a specific ID that way beyond my paygrade… Wish I could be of more help…
                                          So are you accessing it remotely i.E. from a different network?
                                          Hope you figure it out…
                                            PierreGode Module Developer @mischag
                                            @mischag
                                            Hi the ip adress id 192.168.1.whatevertheipofghepi:5003
                                            • 2 / 6
