    MMM-Chores - Manage and keep track of your household Chores
    104 Posts 19 Posters 48.2k Views 20 Watching
    • PierreGodeP
      PierreGode Module Developer @JohnGalt
      @JohnGalt
      No need to set your device on fire.
      The data is only stored in the module folder /MMM-Chores/ in data.json and will NOT be shared with anything unless you add the openapi token.
      No openai api token = no data leaving your device.
      If you want to use ai with api token
      1. ONLY content of modules/MMM-Chores/data.json is shared.
      2. data.json is my file were I store the content of admin page, for security I convert users to ID’s
      3. NOTHING gets sent unless YOU press the AI genrste button.
      J 1 Reply Last reply
        JohnGalt @PierreGode
        @PierreGode – OK, good to know. Thanks for the quick response.
        PierreGodeP 2 Replies Last reply
        • PierreGodeP
          @JohnGalt
          I will add an option in config.js to disable AI from being configurable and hide the AI button
          • PierreGodeP
            PierreGode Module Developer @redbeardedninja
            @redbeardedninja
            Hi! You can now use in config.js
            textMirrorSize: “small”, // small, medium or large
            • PierreGodeP
              @JohnGalt
              Hi, you can now disable AI in config.js
              useAI: false, // hide AI features when false
                sarote
                Hi @PierreGode ! Thank for your job, one of the best modules for MagicMirror. Is it possible to show analtitycs graphs on the mirror screen?if not, are you planning to implement it?
                • PierreGodeP
                  PierreGode Module Developer @sarote
                  @sarote
                  Hi! No it it’s not possible…
                  But I will plan to implement it upon your request.
                  I will let you now. If you wish to track the progress please create a ticket ”issue” in GitHub with the request.
                  //Pierre
                    sarote @PierreGode
                    @PierreGode Great! i will do,thanks for your job
                      mischag @PierreGode
                      @PierreGode
                      Hi there,
                      I’m loving the idea behind this module.
                      But, I can’t work out how to open the admin interface??
                      I’ve tried the ip address that I’m using to remote into the raspberry pi, but it’s not working? I’m trying using tigervnc on a mac, do I need to physically do it on the raspberry pi? I thought I could do it whilst on the same network?
                      Any ideas at all?
                      Just keeps saying can’t connect to the server…
                      Thanks heaps,
                      Mischa
                      J PierreGodeP 2 Replies Last reply
                        JohnGalt @mischag
                        @mischag – Are you using the port described in the documentation [5003]?
                        See:
                        Admin Interface
                        Go to http://yourmirrorIP:5003/ #page will be reachable within same network.
                        Caution
                        DO NOT expose application with portforward
                        M 1 Reply Last reply
                          mischag @JohnGalt
                          @JohnGalt
                          Yeah, I am. But I’m wondering if it’s because I am remoting in on a different port, that I can’t then access that port? I’ve checked the documentation heaps and can’t work it out. I even tried opening the html admin file within the ‘public’ folder, and I can open it but I can’t edit it. I can write the names and click on dates and everything, but when I press ‘add’ nothing happens. I’ve updated and it says it’s all up to date.
                          plainbrokeP 1 Reply Last reply
                          • plainbrokeP
                            plainbroke @mischag
                            @mischag
                            This is what I get when I login to MMMChores admin
                            http://192.168.1.223:5003
                            https doesn’t work for me. I don’t have it setup to work in my config.js.
                            Are you trying to reach it from work or from home and it is in another building???
                              mischag @plainbroke
                              @plainbroke
                              Yeah ok. I might have to try another way… but it’s definitely not working at the moment for me…
                              The port doesn’t bring anything up for me other than the page saying it does not exist.
                              I was hoping not to have it setup through the config folder but it was the only way I could find the admin interface. But then I couldn’t add people or tasks to it…
                              plainbrokeP S 2 Replies Last reply
                              • plainbrokeP
                                plainbroke @mischag
                                @mischag
                                So are you trying to change things by going into MM/modules/MMM-Chores/data.json and editing it? I just tried that and it does not work.
                                I think it is because the module assigns each grouping a specific ID that way beyond my paygrade… Wish I could be of more help…
                                So are you accessing it remotely i.E. from a different network?
                                Hope you figure it out…
                                • PierreGodeP
                                  PierreGode Module Developer @mischag
                                  @mischag
                                  Hi the ip adress id 192.168.1.whatevertheipofghepi:5003
                                  • PierreGodeP
                                    @sarote
                                    It is done
                                      sdetweil @PierreGode
                                      @PierreGode .1 is typically the router , not the pi
                                      on the MagicMirror system do
                                      ip addr
                                      PierreGodeP 1 Reply Last reply
                                      • PierreGodeP
                                        PierreGode Module Developer @sdetweil
                                        What?? 🤭
                                        Like I said I think it is 192.168.subdomain.yourip ❤️
                                        So yes you are right 1 could be 0 depending on your router. I mention http://yourmirrorip:5003/ in my readme for the reason that it can vary, it could even be 10. 24.x.x
                                          @PierreGode yes. all my routers set their ip address to.1 of the assigned address range
                                          home is 192.168.2.(1)
                                          a test network i have it 10.0.2.(1)
                                          all the devices start at .2
                                          on linux
                                          ip addr
                                          will give this machine’s address
                                          on windows its
                                          ipconfig /all
                                            supascoopa74 @mischag
                                            @mischag I’m having the exact same problems that you describe here. Cannot connect to admin page via ip address/trying to use the admin.html page directly is non-responsive. Did you make any progress?
                                            • 3 / 6
