    MMM-Chores - Manage and keep track of your household Chores
    104 Posts 19 Posters 37.7k Views 20 Watching
      redbeardedninja @JohnGalt
      @JohnGalt
      Yeah, exactly what I’m trying to do. Ideally, the kids or me or whoever would be able to check off their completed chores. When I go to click the box on the display screen, I see the hand/mouse cursor but it doesn’t interact. If I have to do it from the admin panel, it sort of defeats the purpose that I’m looking for. Open to ideas of how to make this work (not that I have the skill or knowledge to accomplish that…but still).
      J PierreGodeP 3 Replies Last reply Reply Quote 0
        JohnGalt @redbeardedninja
        @redbeardedninja – Agreed! If the developer can make it work as you described it will be much more useable. Probably more intuitive to use, too.
          redbeardedninja
          @PierreGode could you clarify how this module is meant to work? Should we be able to check off things on the magic mirror, or just on the admin panel?
          PierreGodeP 1 Reply Last reply Reply Quote 0
          • PierreGodeP Offline
            PierreGode Module Developer @JohnGalt
            @JohnGalt
            Hi! dateFormatting: “” is now working with todays patch.
              PierreGode Module Developer @redbeardedninja
              @redbeardedninja the plan is to do everything in the admin portal. the mirror is for you to have an overview of what is done and what is left to do.
                @JohnGalt
                if you want to remove things from the mirror you can delete them after being marked as completed. ( everything is still stored in data.json file and AI can use that as information.
                  @redbeardedninja Hi! good point! I am lookin at it and started a update for it to work.
                    redbeardedninja @PierreGode
                    @PierreGode awesome, thanks for letting us know and working on a new way to interact with your module
                      JohnGalt @PierreGode
                      @PierreGode – Great! I went in and did a ‘git pull’, and indeed that functionality now works.
                        @PierreGode – Can you clarify your comment above comment above [quoted below]? If I read this correctly, the module is exposing the data it has to be scraped by AI engines.
                        " … everything is still stored in data.json file and AI can use that as information "
                          @JohnGalt
                          All tasks and peope are stored in data.json even if you delete them (softdelete) . this is so both analytics page can view history and also so the AI generate can use your completed task as information. when you press AI generate it will read the data.json and look for all completed task deleted or not, and use that to create tasks for coming week.
                            @redbeardedninja Hi this has now being added to latest update!
                            you can now check the checkboxes directly on the mirror it self. (touch screen also works)
                            ( the web admin portal will not update directly unless you refresh the page)
                            What i found hard is that the mouse is invisible on magic mirror but if you manage to find the checkboxes they will be clickable. ( meaby a setting that can be tampered with)
                            KristjanESPERANTOK S R 3 Replies Last reply Reply Quote 0
                            • KristjanESPERANTOK Offline
                              KristjanESPERANTO Module Developer @PierreGode
                              @PierreGode said in MMM-Chores - Manage and keep track of your household Chores:
                              MMM-Cursor can solve that 🙂
                                sdetweil @PierreGode
                                @PierreGode just change it to not hidden using custom.css
                                html {
                                cursor:default;
                                or use unclutter (have apt install it) will only be visible when you move it
                                it is hidden on purpose(in msin.css), an output only panel couldn’t use it
                                  @sdetweil said in MMM-Chores - Manage and keep track of your household Chores:
                                  I think unclutter doesn’t work on modern systems (Wayland).
                                    sdetweil @KristjanESPERANTO
                                    @KristjanESPERANTO true
                                    similar options
                                    https://bist.be/posts/unclutterwayland/
                                      @PierreGode thanks so much! The new update works like a charm. Now for me to work on the custom css to make the module a bit larger…
                                      PierreGodeP 2 Replies Last reply Reply Quote 1
                                        @PierreGode – Thanks for the update on the data being available to AI. Since I don’t want my data available, I will just delete the module folder and remove it from the config file.
                                        Can you confirm that data is NOT stored anywhere outside the module folder? Thanks in advance.
                                          @redbeardedninja
                                          I will add that a little bit later so sizes an be modified from config.js
                                            @JohnGalt
                                            No need to set your device on fire.
                                            The data is only stored in the module folder /MMM-Chores/ in data.json and will NOT be shared with anything unless you add the openapi token.
                                            No openai api token = no data leaving your device.
                                            If you want to use ai with api token
                                            1. ONLY content of modules/MMM-Chores/data.json is shared.
                                            2. data.json is my file were I store the content of admin page, for security I convert users to ID’s
                                            3. NOTHING gets sent unless YOU press the AI genrste button.
                                            • 2 / 6
