    MMM-Chores - Manage and keep track of your household Chores
    104 Posts 19 Posters 49.7k Views 20 Watching
    • PierreGodeP
      PierreGode Module Developer @JohnGalt
      @JohnGalt
      if you want to remove things from the mirror you can delete them after being marked as completed. ( everything is still stored in data.json file and AI can use that as information.
      J 1 Reply Last reply
      • PierreGodeP
        PierreGode Module Developer @redbeardedninja
        @redbeardedninja Hi! good point! I am lookin at it and started a update for it to work.
        R 1 Reply Last reply
          redbeardedninja @PierreGode
          @PierreGode awesome, thanks for letting us know and working on a new way to interact with your module
            JohnGalt @PierreGode
            @PierreGode – Great! I went in and did a ‘git pull’, and indeed that functionality now works.
              @PierreGode – Can you clarify your comment above comment above [quoted below]? If I read this correctly, the module is exposing the data it has to be scraped by AI engines.
              " … everything is still stored in data.json file and AI can use that as information "
              PierreGodeP 1 Reply Last reply
              • PierreGodeP
                @JohnGalt
                All tasks and peope are stored in data.json even if you delete them (softdelete) . this is so both analytics page can view history and also so the AI generate can use your completed task as information. when you press AI generate it will read the data.json and look for all completed task deleted or not, and use that to create tasks for coming week.
                • PierreGodeP
                  @redbeardedninja Hi this has now being added to latest update!
                  you can now check the checkboxes directly on the mirror it self. (touch screen also works)
                  ( the web admin portal will not update directly unless you refresh the page)
                  What i found hard is that the mouse is invisible on magic mirror but if you manage to find the checkboxes they will be clickable. ( meaby a setting that can be tampered with)
                  KristjanESPERANTOK S R 3 Replies Last reply
                  • KristjanESPERANTOK
                    KristjanESPERANTO Module Developer @PierreGode
                    @PierreGode said in MMM-Chores - Manage and keep track of your household Chores:
                    MMM-Cursor can solve that 🙂
                      sdetweil @PierreGode
                      @PierreGode just change it to not hidden using custom.css
                      html {
                      cursor:default;
                      or use unclutter (have apt install it) will only be visible when you move it
                      it is hidden on purpose(in msin.css), an output only panel couldn’t use it
                      KristjanESPERANTOK 1 Reply Last reply
                        @sdetweil said in MMM-Chores - Manage and keep track of your household Chores:
                        I think unclutter doesn’t work on modern systems (Wayland).
                          sdetweil @KristjanESPERANTO
                          @KristjanESPERANTO true
                          similar options
                          https://bist.be/posts/unclutterwayland/
                            @PierreGode thanks so much! The new update works like a charm. Now for me to work on the custom css to make the module a bit larger…
                            PierreGodeP 2 Replies Last reply
                              @PierreGode – Thanks for the update on the data being available to AI. Since I don’t want my data available, I will just delete the module folder and remove it from the config file.
                              Can you confirm that data is NOT stored anywhere outside the module folder? Thanks in advance.
                              • PierreGodeP
                                @redbeardedninja
                                I will add that a little bit later so sizes an be modified from config.js
                                • PierreGodeP
                                  @JohnGalt
                                  No need to set your device on fire.
                                  The data is only stored in the module folder /MMM-Chores/ in data.json and will NOT be shared with anything unless you add the openapi token.
                                  No openai api token = no data leaving your device.
                                  If you want to use ai with api token
                                  1. ONLY content of modules/MMM-Chores/data.json is shared.
                                  2. data.json is my file were I store the content of admin page, for security I convert users to ID’s
                                  3. NOTHING gets sent unless YOU press the AI genrste button.
                                    @PierreGode – OK, good to know. Thanks for the quick response.
                                    • PierreGodeP
                                      @JohnGalt
                                      I will add an option in config.js to disable AI from being configurable and hide the AI button
                                      • PierreGodeP
                                        @redbeardedninja
                                        Hi! You can now use in config.js
                                        textMirrorSize: “small”, // small, medium or large
                                        • PierreGodeP
                                          @JohnGalt
                                          Hi, you can now disable AI in config.js
                                          useAI: false, // hide AI features when false
                                            sarote
                                            Hi @PierreGode ! Thank for your job, one of the best modules for MagicMirror. Is it possible to show analtitycs graphs on the mirror screen?if not, are you planning to implement it?
                                            • 2 / 6
