    MMM-HomeAssistant
    23 Posts 10 Posters 12.0k Views 8 Watching
      adamambarus
      Hello,
      After configuring my MagicMirror frame, I realized there is no straightforward module to establish a good connection with Home Assistant using its available features. Please take a look at the module I have been working on recently:
      https://github.com/ambarusa/MMM-HomeAssistant
      This module makes the MagicMirror available as an MQTT device automatically in Home Assistant, with the browser/monitor as a light entity, modules as switch entities, and sensors connected via GPIO as sensor entities. Everything happens through MQTT Autodiscovery, without needing to touch any configuration files in Home Assistant. This is what I really missed in other solutions like MMM-MQTTBridge.
      Once connected, the possibilities for automations are endless and can be managed in the same place as other home automations. Once the GPIO pins are read and published, toggling the screen based on motion can be triggered from the central server, and this information can be used for other triggers in the house. This is what MMM-PIR is lacking.
      So please have a look, give feedbacks and have fun with it!!
      S KristjanESPERANTOK 2 Replies Last reply Reply Quote 3
        sdetweil @adamambarus
        @adamambarus AWESOME… been looking for this myself…
        I have done similar with a diff mirror platform…
        I have one problem with mine, when the mqtt server goes down, the connection is not restarted as expected… and the devices in HA are marked as not available
          adamambarus @sdetweil
          @sdetweil Hm great idea! I will investigate what happens with my module in that case, and come up with a handling for it!
            @adamambarus I have mqtt server in a compose stack with watchtower and it gets upgraded on version updates…
            also that machine is on UPS that just recently died after 8 years during a 15 second power outage… so mqtt went away for a LONG time… (I was out of town)
            way longer than its reconnect timeout.
            I see client is 5.13.0 now, I am using 5.1.3 on this client (last PR on mqtt for this reconnect problem seems to be 5.5.6 SO… maybe
            https://github.com/mqttjs/MQTT.js/issues/1727
            • KristjanESPERANTOK Offline
              KristjanESPERANTO Module Developer @adamambarus
              @adamambarus Nice! Don’t forget to add it to the module list: https://github.com/MagicMirrorOrg/MagicMirror/wiki/3rd-party-modules :-)
                Hi, I just ran a few tests and the module can automatically reconnect if the server reappears. It is handled automatically in the mqtt lib, my part was to stop flooding the MM logs with mqtt error messages.
                Give this module a try if you are interested, I would really appreciate other good findings.
                  adamambarus @KristjanESPERANTO
                  @KristjanESPERANTO Thanks! I am interested in that, I just don’t know how to do that :D Never changed other repos other than mine ever.
                    @adamambarus you edit this wiki page to add your module entry
                    https://github.com/MagicMirrorOrg/MagicMirror/wiki/3rd-Party-Modules#module-creators
                      @sdetweil Hahh, of course how could I not see that button…
                        @adamambarus great… now, suddenly (been running for near 2 years) MY mqtt server cannot be reached from outside the docker host… SO much fun…
                        • SnilleS Offline
                          Snille Module Developer
                          Awsome! This changes a lot in my “config”, my Mirror(s) are tightly integrated with Home Assistant.
                          Thank you for this module!!
                          I’m currently running 3 different mirrors, but two of them are “mixed” with each other in HA, the third (first one) are separate :). I’ll have to do some more investigating. Have you tested with multiple mirrors against one “HA-MQTT”?
                          Again, thank you for this! :)
                          Update: I did some cleaning in the MQTT-queue (with MQTT Explorer) and now it all works. I got to have had my config(s) mixed at some point during my testing. So, now it’s all good. :)
                          If you cant find it, make it and share it
                          MMM-homeassistant-sensors,MMM-Modulebar,MMM-Profilepicture,MMM-Videoplayer,MMM-TautulliLatest
                            adamambarus @Snille
                            @Snille Wow, I am so glad to hear it. I made a test with my real MagicMirror, and a dummy one running on a linux laptop. At this point I added a real uniqueID for the HA device config jsons.
                            @Snille said in MMM-HomeAssistant:
                            Hmm, alright!! I will try to think of a handling in case two MM instances want to connect with the same device name. That is the only attribute left on the user.
                              schlomm
                              I’m just here to say “Thank you” - installed the module yesterday and after some struggling with my MQTT Backend all is working :)
                              • UncleRogerU Offline
                                UncleRoger
                                Just to be clear, this is meant to allow you to control the MM from HA, not display HA info on the MM, right?
                                  sdetweil @UncleRoger
                                  @UncleRoger correct MMM-HomeAssistantDisplay
                                  will display info from ha
                                    mirrorlover270
                                    Would you see a chance to include a “sensor” that shows whether an update for a module is available? Right now the sensor on updates can only “hide” the update message on the mirror.
                                    With an update sensor, I could get a message on my phone and at least trigger the update remotely with the MMM-Remote module.
                                    Thanks anyway for this great module.
                                      raymonvdm @mirrorlover270
                                      I found a display (touchscreen) to setup a family dashboard and i`m making babysteps to get it going again after a long time of trying out MagicMirror
                                      I did get this module to work and most of the buttons in HomeAssistant work, but since i`m using a GigabyteBrix debian12 pc the screen off and on does not work.
                                      This however is working to get the screen on/off
                                      apt install vbetool
                                      root@debian:~# sudo vbetool dpms off
                                      root@debian:~# sudo vbetool dpms on
                                      root@debian:~# cat /etc/sudoers.d/magicmirror
                                      magicmirror ALL=(ALL) NOPASSWD: /usr/bin/vbetool
                                      root@debian:~#
                                      So i changed the on off command to
                                      /usr/bin/sudo /usr/bin/vbetool dpms off
                                      /usr/bin/sudo /usr/bin/vbetool dpms on
                                      But it stops working as soon as i start the MagicMirror using PM2 and i`m not sure why.
                                      Are there any other options?
                                      • L Offline
                                        Lateadapter
                                        I was directed from [MagicMirror Forum] Digest for 1/11/2026 to that discussion and I can show you some kind of alternative regarding Home Assistant controlled MagicMirror. It is using TouchKIO as a mirror client.
                                        Recently I did upgrade my many years existing setup and I did summarize it here:
                                        https://github.com/Lateadapter/TouchKIO-as-Kiosk-Application-for-MagicMirror
                                          sdetweil @raymonvdm
                                          @raymonvdm can you show the log?
                                          I always recommend testing with manual start after you make a module change
                                          pm2 stop all
                                          cd ~/MagicMirror
                                          npm start
                                          if it comes up ok, ctrl-q, or alt-spacebar, c
                                          then pm2 status
                                          and pm2 start xxxx
                                          where xxxx is the name or number on the row for your application
                                            raymonvdm @sdetweil
                                            I found out that it stil asked for the user password when performing sudo. I had this statement in /etc/sudoers
                                            magicmirror ALL=(ALL:ALL) ALL
                                            And this in /etc/sudoers.d/magicmirror
                                            For now i removed the line in /etc/sudoers
