    Family Mirror
    10 Posts 5 Posters 11.4k Views 4 Watching
    • D
      dathbe
      I finally got around to making my mirror presentable, so I thought I’d show it off.
      Yes, I do have eventual plans to do something about that brown electrical cord hanging out the bottom.
      The guts are a 30" TV I pulled out of its shell and a Raspberry Pi 4B. I used some 1"x3" and some molding to build a simple box frame.
      The primary modules are:
      alert
      updatenotification
      clock
      MMM-Remote-Control - used for updating several other modules
      MMM-CustomText - used to show a message via a python script when there are apt updates for my RPi, and weather alerts via another python script
      MMM-EarthquakeAlerts
      MMM-RandomPhoto
      MMM-MagicMover
      MMM-ModuleScheduler - hides certain modules when they’re out of season
      MMM-Carousel - rotates through 5 separate pages
      Page 1 - Calendar
      MMM-CalendarExt2 - It pulls from a generic GMail calendar I’ve convinced my wife to invite to anything the whole fam should know about
      MMM-Multimonth
      Page 2 - Weather
      MMM-RAIN-MAP - only displays when rain is predicted in the next 12 hours
      weather - used only to trigger MMM-OpenWeatherMapForecast
      MMM-MoonPhase
      A proprietary module that displays a day/night map of the earth
      MMM-Block - adjusts the height of the two bottom modules so they line up
      Page 3 - Home Automation
      MMM-Rest - several instances; grabs info from my home automation server
      MMM-NestRemoteThermostat
      MMM-GoogleMaps-Tracking - updated via python script
      MMM-Block - to move modules around so they line up
      Page 4 - Sports
      MMM-MyScoreboard
      MMM-MyStandings - multiple instances
      MMM-PGA
      Page 5 - Info
      MMM-SimpleLogo - a logo from our school
      MMM-LINQConnectCalendar
      MMM-TitanSchoolMealMenu
      MMM-JsonTable - displays gas prices via a python script
      MMM-Pinfo
      MMM-Block - multiple instances to adjust things so they line up
      The Future
      Adding touchscreen capabilities? This seems like a pain that would ruin the aesthetics, but maybe.
      KristjanESPERANTOK plainbrokeP 2 Replies Last reply
      Reply Quote 4
      • KristjanESPERANTOK
        KristjanESPERANTO Module Developer @dathbe
        Really nice! Thanks for sharing and the description with details about the modules! 👏
        • plainbrokeP
          plainbroke @dathbe
          @dathbe
          Cool setup.
          Under page 5 you have the json table setup for gas prices.
          Can you share the url for the gas prices you use?
          D 1 Reply Last reply
          • D
            dathbe @plainbroke
            @plainbroke It’s a custom python script, and it has broken since I created this post. Working on a plan B.
            • L
              Lmagenis
              This looks great! How did you get only the lunch menus to show?
              D T 3 Replies Last reply
              • D
                dathbe @Lmagenis
                @Lmagenis custom CSS:
                /* MMM-TitanSchoolMealMenu CSS */
                .MMM-TitanSchoolMealMenu {
                  max-width: 500px;
                .MMM-TitanSchoolMealMenu .meal-list {
                  margin-block-start: unset;
                .MMM-TitanSchoolMealMenu li {
                  font-size: var(--font-size-small);
                .MMM-TitanSchoolMealMenu ul {
                  padding-inline-start: 0;
                .MMM-TitanSchoolMealMenu .large {
                  color: #f8dd70;
                  line-height: unset;
                .MMM-TitanSchoolMealMenu .meal-title,
                .MMM-TitanSchoolMealMenu .breakfast-description {
                  display: none;
                The last entry is the key to what you’re asking.
                Reply Quote 1
                • D
                  dathbe @Lmagenis
                  @Lmagenis Looking again, it appears that my tweak to the module to add the ‘.breakfast-description’ class was never merged. I’m on my own fork of the module:
                  https://github.com/dathbe/MMM-TitanSchoolMealMenu/tree/combined
                  (Note that it’s the “combined” branch not the default branch.)
                  You can see the various tweaks I’ve made to my fork here:
                  https://github.com/evanhsu/MMM-TitanSchoolMealMenu/pulls
                  L 1 Reply Last reply
                  • L
                    Lmagenis @dathbe
                    @dathbe Thank you! I’m still learning all of this. I appreciate your help!
                    • T
                      trnitz @Lmagenis
                      @Lmagenis said in Family Mirror:
                      There is also the ‘hideEmptyMeals’ boolean in the config, which is set to false by default.
                      Setting that to true, while also setting ‘recipeCategoriesToInclude’ to ‘Lunch’ (or ‘Lunch Entree’ in my case) will not display empty meals.
                      Example config section:
                          module: "MMM-TitanSchoolMealMenu",
                          position: "bottom_left",
                          header: "Namaqua Elementary menu",
                              size: 'x-small', // Optional: 'small', 'medium', 'large'; Default: 'medium'
                              todayClass: 'x-small',
                              hideEmptyDays: true,
                              hideEmptyMeals: true,
                              buildingId: 'edf06a3e-65f3-ee11-a85d-f8b9c75e31xx',
                              districtId: '931753cd-1e95-ee11-b902-959a1bfff3xx',
                              updateIntervalMs: 3600000, // Optional: Milliseconds between updates; Default: 3600000 (1 hour)
                              numberOfDaysToDisplay: 2, // Optional: 0 - 5; Default: 3
                              recipeCategoriesToInclude: [
                                  "Lunch Entree",
                              debug: false
                      Reply Quote 1
                      • L
                        Lmagenis @trnitz
                        @trnitz Thank you, that’s what mine looks like but it returns everything offered for lunch that day, right down to the condiments.
