    The typical beginner question
    15 Posts 4 Posters 5.0k Views 4 Watching
    • _
      _V_
      Hey guys,
      So Ive been watching the MM life for a couple of years now but always hesitated to start with it cause I usually have to do things 2 ( just getting impatient most of the ties and start to run over steps ^^ )
      Now what Id like to know is following:
      I need a suitable Pi, thats obvious. If Im really only using the MM for organization among family members, I guess I dont need much ram in my Pi? What size of storage would you recommend?
      Also I wonder, what screen to use and how to get the actual mirror part done?
      Like I need a screen that behind a somehwat mirror surface, otherwise I could simply place a tablet to wall right?
      Besides the Pi with some hardware modules like Bluetooth adapter and WLan card n stuff, I also need some kind of touch controller, which gets the touches from the mirror surface transmitted to the Pi?
      Or would it be smarter to just buy a touchscreen in desired size and put the Put behind it / behind the wall / somewhere hidden ? If its a question of taste whether I want an actual mirror or not - I really dont need a mirror in this case ^^
      Maybe you could share some light with me, and apologies for the maybe bad english, its not my first language.
      Thanks a lot and regards from Germany
      Tobi
        sdetweil @_V_
        @_V_ i would recommend 2g memory as a minimum now a days
        touch is a problem area MagicMirror itself does provide support for touch on anything , its and output information panel
        there are a couple newer modules that provide touch functions, mmm-chores and mmm-calendarext3.
        with a few modiles and done creative configuration you can use touch to hide or show modules, or groups of modules (aka page)
        but no general data entry. most of the apis provided by services are pull only
        mirror and touch is complex. if the surface glass directly touches the touch display and has the right qualities , it might be possible (screen protector on phone like)
        but i dont think you can get direct attachment to the monitor or tv screen that way
        one could add an ir touch frame on TOP on the glass, which acts like a mouse. but these are not asthetically appealing imho.
        MagicMirror will run on linux, macos, and windows
        and you can run the server side somewhere and the display side somewhere else ( provided the hardware works that way too") as it uses a web browser for display.
        speech reco, or direct attach hardware sensors would only work at the server side for example
        look thru the show your mirror topic for examples of others implementations
        _ 1 Reply Last reply Reply Quote 1
        • _
          _V_ @sdetweil
          Hey Sam, thanks for the helpful input.
          Ok I try to sum up a bit for my understandings:
          Mirror option and touch is something hard to do or not all the way functional/supported, correct?
          In general you would recommend, that the MM itself is mainly/only used to display stuff, not for input?
          ( unless you connect components for input to a server like Pi ? )
          Id like to have a screen/tablet to show the basic module stuff, which you already mentioned and which Ive seen in the module corner. Id like to be able to enter some new appointment or calnder stuff via the screen/tablet directly tbh. It would be for the 3 persons in our household and for such itd be nice if I could arrange 3 users with a quick login method ( face, fingerprint, something? ) and everybody would be able to enter its own stuff.
          Like said, I really appreciate your time and help.
          S UncleRogerU 2 Replies Last reply Reply Quote 0
            sdetweil @_V_
            @_V_ there I hear what you want… today there is no capability to provide all that
            was someone that had made a module for entering calendar events, but I can’t find it now.
            its much easier to just use your phone.
            there are modules that can provide profiling, UI by user.
            FaceRecoDNN can use camera images, this one doesn’t support reco on server and camera on client
            ProfileSwitcher, I haven’t researched how you select profiles
            I should note that MM UI is 100% javascript, and uses the latest JS engine capabilities,
            many tablets/pads are NOT at current level, and so our code doesn’t run there in browser unless its updated to latest , which many don’t provide support like that.
            • UncleRogerU
              UncleRoger @_V_
              @_V_
              I’ve got mine running on a RPi 4 with (iirc) 4gb of memory which seems to be enough. I’ve got a lot of modules divvied up into 3 pages that are selected via a wee macropad (three buttons & a knob) attached below the screen. (My dev version has 6 pages and I’m waiting on a new 6-key macropad so I van put that on the main system.)
              I don’t have it behind a mirror; it’s just in a wooden frame.
              I (and my family) add stuff to our calendars on our computers/phones; the MM is only for display. If I didn’t have to waste 8+ hours a day at the stupid job thing, and if I had more money (college in the US is outrageously expensive), I would try to get touch working so as to be able to go to the next/previous month on the calendar (MMM-CalendarExt3) but I’m happy with it as is.
              I don’t worry about profiles – mostly everyone looks at the dinner menu (I have a google calendar just to say what I’m cooking for the next week or two) or the main calendar. Those are on the first page.
              So, based on what you said, I would suggest getting yourself a basic RPi – I think the Pi Zero 2 is a little underpowered, but it’s doable – and an old monitor and start playing with it. Worry about installation and all that once you have it showing what you want and working the way you’d like it to.
              I’m fortunate in that I have an extra Pi so I have a copy running on it that I can play around with without breaking the one in the kitchen that everyone looks at.
              S J 2 Replies Last reply Reply Quote 1
                sdetweil @UncleRoger
                @UncleRoger said in The typical beginner question:
                if you use pages, add an instance for each page
                mode:month
                monthIndex:0/1/2 for each month on each page (this, next and after)
                if using MMM-pages, used the class name page definitions, then its easy to set
                each instance on a separate page
                here is my config for pages and ext3
                        module: "MMM-CalendarExt3",
                        position: "middle_center",
                        classes: "page1",
                        order: "*",
                        animateIn: "None",
                        animateOut: "None",
                        index: 0,
                        label: "instance 1",
                          mode: "month",
                          fontSize: "30px",
                          monthIndex: 0,
                          minimalDaysOfNewYear: "1"
                        disabled: false,
                        hiddenOnStartup: false,
                        configDeepMerge: false
                        classes: "page2",
                        order: "*",
                        animateIn: "None",
                        animateOut: "None",
                        index: 1,
                        label: "instance 2",
                          mode: "month",
                          fontSize: "30px",
                          monthIndex: 1
                        disabled: false,
                        classes: "page3",
                        order: "*",
                        animateIn: "None",
                        animateOut: "None",
                        index: 2,
                        label: "instance 3",
                          mode: "month",
                          weekIndex: -1,
                          dayIndex: -1,
                          weeksInView: 3,
                          cellDateOptions: {
                            month: "short",
                            day: "numeric"
                          eventTimeOptions: {
                            timeStyle: "short"
                          headerWeekDayOptions: {
                            weekday: "long"
                          headerTitleOptions: {
                            month: "long"
                          maxEventLines: 5,
                          fontSize: "30px",
                          eventHeight: "22px",
                          refreshInterval: 120000,
                          waitFetch: 5000,
                          glanceTime: 60000,
                          animationSpeed: 2000,
                          useSymbol: true,
                          useWeather: true,
                          popoverTemplate: "./popover.html",
                          popoverTimeout: 30000,
                          popoverPeriodOptions: {
                            dateStyle: "short",
                            timeStyle: "short"
                          popoverDateOptions: {
                            dateStyle: "full"
                          displayCW: true,
                          animateIn: "fadeIn",
                          animateOut: "fadeOut",
                          showMore: true,
                          useIconify: true,
                          skipDuplicated: true,
                          monthIndex: 2,
                          displayLegend: false,
                          displayEndTime: false,
                          displayWeatherTemp: false,
                          skipPassedEventToday: false,
                          useMarquee: false,
                          customHeader: false,
                          weekends: [],
                          calendarSet: []
                        disabled: false,
                        module: "MMM-pages",
                        disabled: false,
                              "page1"
                              "page2"
                              "page3"
                          fixed: [
                            "fixed"
                          hiddenPages: {
                            screenSaver: [],
                            admin: []
                          rotationTime: 60000
                        order: "*"
                use the page-indicator module to add buttons for the pages… (and you can customize the buttons with css)
                UncleRogerU 1 Reply Last reply Reply Quote 0
                • UncleRogerU
                  UncleRoger @sdetweil
                  An interesting idea but I think I’ve got too many pages as it is – I’ve got three currently and going to switch to six soon – but it’s not enough of an issue to really put much thought into. Thanks though!
                  • _
                    _V_
                    Hey guys
                    Thanks for all the interesting info.
                    I guess Ill go as you both advised - Ill get a Pi ( usually I buy overpowered stuff anyways ^^ ) and a flat screen to try around and get things started. If you say, itll be easier to enter with another device like smartphone, this will surely be the way I am following then.
                    Ill be back with some errors Ill make while setting up the Pi and MM software ;)
                    @UncleRoger a last question though: Ive read a lot about screens which need to have some ports ( hdmi or something ) located on special place or direction - you dont got a recommendation for a screen 17" to 20" which meets those conditions?
                      sdetweil @_V_
                      @_V_ use (my) the installer script listed as alternative ways to install
                      • _
                        _V_
                        Guys, thanks for the interesting thoughts.
                        @sdetweil If you say itll be easier with the phone, Ill surely go that way.
                        @UncleRoger you maybe wanna share a pic or two of this controller and how it is connected? :)
                        I guess Ill do as you adviced and get a Pi. Actually I already got one to play some retro games with it.
                        Usually I buy overpowered hardware, just cause Im one of those victims who can hardly resist ^^
                        Just a last question: So Ive read a couple of times that people warn to check for the right angle/position/whatever of the hdmi port of the screen - is this more related to the people who plan on put the screen into a housing / behind a frame? I guess with a 90° or even 180° adapter itll be good for me if I am going to attach it to a wall?
                        Out of curiousity: Any screen suggestions?
                        Thanks a lot again
                        S UncleRogerU 3 Replies Last reply Reply Quote 0
                          sdetweil @_V_
                          @_V_ the hdmi port is really about keeping the mirror box thinner off the wall
                          they also make adapters for adjusting the angle
                          • UncleRogerU
                            UncleRoger @_V_
                            @_V_ said in The typical beginner question:
                            I just used a monitor I had lying about. iirc, I used a 90° right-angle m-f hdmi adapter to get the cable going in the right direction. I also played around with a few different cables to find ones with small enough connectors. But that’s something to worry about once you go from getting modules set up and all to the point of actually figuring out how you’re going to mount it.
                            • UncleRogerU
                              UncleRoger @_V_
                              Unfortunately, I don’t really have any good pictures of how the Pi and monitor are connected. The Pi itself sits in a little bracket my son designed and 3d printed.
                              The whole mounting process went a little cattywumpus because it turns out that the box that holds the monitor electronics isn’t connected to the screen, other than by a couple of pieces of tape and I was mounting everything and then it started to fall apart and fall off the wall so I panicked and just screwed it to the wall. One of these days, I’m going to have to deal with that but that’s a problem for future me. 8^)
                              • UncleRogerU
                                UncleRoger @_V_
                                The adapters are really just so you can get things to fit in the frame or whatever you’re using to mount it. I’m working on a small one for my son where I have 180° adapters for power & hdmi for the screen to save space and get the cables going in the right direction. I went through a lot of different adapters to get that right. (Aliexpress can be your friend here.)
                                I just used a monitor I had already. It happened to fit the space I wanted it for. Basically, any monitor will work. Note that different size screens (esp. screen ratio – width to height) will display things differently.
                                • J
                                  JohnGalt @UncleRoger
                                  @UncleRoger – +1 on having a separate Magic Mirror instance for development (“dev instance”)! I have a small virtual machine running Magic Mirror where I can try out changes or new modules without disturbing my main instance. I don’t bother with a monitor, just display it on my desktop.
