    MMM-next-episode
    23 Posts 3 Posters 5.1k Views 3 Watching
      sdetweil @rambomonkey
      @rambomonkey said in mmm-next-episode:
      No /root/
      also, NEVER run this stuff as root…
      is that the user you used when you installed the module???
        rambomonkey @sdetweil
        @sdetweil to be honest I cannot remember if I used root or not:
        root@mmnew:~/MagicMirror/MMM-next-episode# ls -laF
        total 108
        drwxr-xr-x 6 root root 4096 Aug 21 19:22 ./
        drwxr-xr-x 15 root root 4096 Aug 19 20:51 …/
        drwxr-xr-x 8 root root 4096 Aug 19 18:45 .git/
        drwxr-xr-x 3 root root 4096 Aug 19 18:45 .github/
        -rwxr-xr-x 1 root root 31 Aug 19 18:45 .gitignore*
        -rw-r–r-- 1 root root 35149 Aug 19 18:45 LICENSE
        -rw-r–r-- 1 root root 602 Aug 19 18:45 MMM-next-episode.css
        -rw-r–r-- 1 root root 5798 Aug 19 18:45 MMM-next-episode.js
        -rw-r–r-- 1 root root 4613 Aug 19 18:45 README.md
        drwxr-xr-x 2 root root 4096 Aug 19 18:45 img/
        -rw-r–r-- 1 root root 2904 Aug 19 18:45 node_helper.js
        drwxr-xr-x 33 root root 4096 Aug 19 18:45 node_modules/
        -rw-r–r-- 1 root root 13972 Aug 19 18:45 package-lock.json
        -rw-r–r-- 1 root root 544 Aug 19 18:45 package.json
        S PierreGodeP 2 Replies Last reply Reply Quote 0
          @rambomonkey uou can see root owns the files
          if you try to run as a normal user, you dont have permission to access them at all
          thus the not found
            @sdetweil Thanks for the info, sorry im new to Linux. Would you happen to know how I could give a specific user the permissions?
              @rambomonkey
              the permissions are 3 sets of 3 rights
              user read/write/execute
              group anyone in this group
              other anybody not specified above
              the commands
              are chmod which can set the individual
              permissions using flags or a number
              777 means all for all
              770 mean user and group users can do anything, everyone else no access
              the there is chgrp to change the group
              all commands have help
              –help
              and most have a page in the manuals
              man commandname
              man chmod
              man chgrp
              you
              eill need root permission to take root
              permissions away
              sudo gives root permission for this command
              • PierreGodeP Offline
                PierreGode Module Developer @rambomonkey
                @rambomonkey
                So this is how you want your Magic mirror setup to look like.
                yeah no /root/ that can create a loads of headaches like this.
                R 2 Replies Last reply Reply Quote 1
                  rambomonkey @PierreGode
                  @PierreGode @sdetweil thanks you two, think I will just re-install as a normal user, you live and learn lol.
                    @PierreGode Hi, I have now re-installed it under user petek and I’m still seeing the same issue:
                    petek@MagicMirror-v2:/home/MagicMirror$ ls -la /home/MagicMirror/modules/MMM-next-episode/MMM-next-episode.js
                    -rw-r–r-- 1 petek petek 5798 Aug 26 19:34 /home/MagicMirror/modules/MMM-next-episode/MMM-next-episode.js
                      @rambomonkey I just installed the module
                      git clone
                      cd MMM-next-episode
                      npm install
                      used the sample config from the readme
                      (typo missing : after password in the readme)
                        module: "MMM-next-episode",
                        position: "bottom_right",
                        header: "Next-Episode",
                          hash_key: '',
                          username: '',
                          password: '',
                          displaySeasonAndEpisode: false,
                          displayShowingOn: false,
                          displayEpisodeName: false,
                          maxdays: 7,
                          ShowThumbnail: true,
                          ThumbnailSize: 'small',
                          updateInterval: 180
                      and see the qr code on the screen under the header
                      R PierreGodeP 2 Replies Last reply Reply Quote 0
                        @sdetweil Thank you so much, its now working!
                        • 2 / 3
