    update package list
    45 Posts 2 Posters 13.7k Views 2 Watching
    • P Offline
      pat59
      Hello,
      After updating the package list,
      sudo apt-get update
      sudo apt-get dist-uprade
      and updating Raspbian
      sudo rpi-update
      I no longer have Calendar and Newsfeed, it says “loading” but nothing appears.
      What should I do? Thank you.
      • P Offline
        pat59
        Hello
        Thank you for what you did for me. Now it’s bothering me. We’ll stop there and close the session. Thank you again. Thank you for your help. You are a fantastic person. Thank you for your time spent on our problems. Thank you and thank you again.
          sdetweil @pat59
          @pat59 show the output of npm start
          But when you change the os under an app, it’s recommended to reset it too
          Stop MagicMirror
          cd ~/MagicMirror
          rm -rf node_modules
          npm install
          Start MagicMirror
          • P Offline
            pat59
            Hello, I did the manipulation, it doesn’t work. To stop Magic Mirror, I have to press Ctrl+M.
            pi@raspberrypi:~ $ npm start
            npm ERR! Missing script: “start”
            npm ERR!
            npm ERR! Did you mean one of these?
            npm ERR! npm star # Mark your favorite packages
            npm ERR! npm stars # View packages marked as favorites
            npm ERR!
            npm ERR! To see a list of scripts, run:
            npm ERR! npm run
            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2025-09-11T14_07_45_151Z-debug-0.log
            pi@raspberrypi:~ $
              sdetweil @pat59
              @pat59 all MM commands require you to be IN the MagicMirror folder
              you are still in the users home folder
              pi@raspberrypi:~
              • P Offline
                pat59
                magicmirror@2.27.0 start
                DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                [2025-09-11 16:56:55.039] [LOG] Starting MagicMirror: v2.27.0
                [2025-09-11 16:56:55.176] [LOG] Loading config …
                [2025-09-11 16:56:55.192] [LOG] config template file not exists, no envsubst
                [2025-09-11 16:56:55.206] [LOG] Loading module helpers …
                [2025-09-11 16:56:55.858] [LOG] Initializing new module helper …
                [2025-09-11 16:56:55.860] [LOG] Module helper loaded: MMM-Remote-Control
                [2025-09-11 16:56:55.863] [LOG] No helper found for module: alert.
                [2025-09-11 16:56:55.885] [LOG] Initializing new module helper …
                [2025-09-11 16:56:55.887] [LOG] Module helper loaded: MMM-Saint
                [2025-09-11 16:56:55.913] [LOG] Initializing new module helper …
                [2025-09-11 16:56:55.915] [LOG] Module helper loaded: MMM-BME280
                [2025-09-11 16:56:55.933] [LOG] No helper found for module: MMM-FlipClock.
                [2025-09-11 16:56:56.121] [LOG] Initializing new module helper …
                [2025-09-11 16:56:56.122] [LOG] Module helper loaded: MMM-network-signal
                [2025-09-11 16:56:56.827] [LOG] Initializing new module helper …
                [2025-09-11 16:56:56.828] [LOG] Module helper loaded: calendar
                [2025-09-11 16:56:58.426] [LOG] Initializing new module helper …
                [2025-09-11 16:56:58.427] [LOG] Module helper loaded: MMM-Jast
                [2025-09-11 16:57:00.066] [LOG] Initializing new module helper …
                [2025-09-11 16:57:00.069] [LOG] Module helper loaded: MMM-GooglePhotos
                [2025-09-11 16:57:00.088] [LOG] No helper found for module: MMM-WiFiPassword.
                [2025-09-11 16:57:00.093] [LOG] No helper found for module: MMM-OpenmapWeather.
                [2025-09-11 16:57:00.107] [LOG] No helper found for module: MMM-WeatherOrNot.
                [2025-09-11 16:57:00.122] [WARN] No /home/pi/MagicMirror/js/…/modules/MMM-Linky/MMM-Linky.js found for module: MMM-Linky.
                [2025-09-11 16:57:00.124] [LOG] No helper found for module: MMM-Linky.
                [2025-09-11 16:57:00.569] [LOG] Initializing new module helper …
                [2025-09-11 16:57:00.571] [LOG] Module helper loaded: newsfeed
                [2025-09-11 16:57:00.573] [LOG] All module helpers loaded.
                [2025-09-11 16:57:00.599] [LOG] Starting server on port 8080 …
                [2025-09-11 16:57:00.649] [WARN] You’re using a full whitelist configuration to allow for all IPs
                [2025-09-11 16:57:03.916] [ERROR] Whoops! There was an uncaught exception…
                [2025-09-11 16:57:03.930] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                at Server.setupListenHandle [as _listen2] (node:net:1872:16)
                at listenInCluster (node:net:1920:12)
                at doListen (node:net:2069:7)
                at process.processTicksAndRejections (node:internal/process/task_queues:83:21) {
                code: ‘EADDRINUSE’,
                errno: -98,
                syscall: ‘listen’,
                address: ‘0.0.0.0’,
                port: 8080
                [2025-09-11 16:57:03.933] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                [2025-09-11 16:57:03.936] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                [2025-09-11 16:57:40.629] [INFO] System information:
                SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; raspberry: [object Object]; virtual: false
                OS: platform: linux; distro: Raspbian GNU/Linux; release: 10; arch: arm; kernel: 6.12.45-v7+
                VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 18.18.0; npm: 9.8.1; pm2: 5.3.1
                OTHER: timeZone: Europe/Paris; ELECTRON_ENABLE_GPU: undefined
                  sdetweil @pat59
                  @pat59 so, you already have an instance running, probably under pm2
                  when I said stop MM I meant in whatever way running…
                  pm2’s JOB is to start and KEEP MM running… no matter what
                  you ctrl-Q
                  pm2 says, oops, app crashed, restart…
                  so, you have to use the pm2 commands to tell it what to do
                  pm2 status
                  will show the managed apps, one line per
                  you can control the app, by using the name or number of the app in a row
                  pm2 stop 0
                  pm2 stop MagicMirror
                  could both be for the same app
                  once stopped, THEN you can go to the MM folder and do the npm start to see the possible errors easier…
                  once you fix the errors, you can stop the temp MM with ctrl-q (as you started it manually)
                  and then tell pm2 to manage it again
                  pm2 start 0/MagicMirror
                  • P Offline
                    pat59
                    pi@raspberrypi:~/MagicMirror $ rm -rf node_modules
                    pi@raspberrypi:~/MagicMirror $ npm install
                    magicmirror@2.27.0 postinstall
                    npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                    magicmirror@2.27.0 install-vendor
                    echo "Installing vendor files …
                    " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                    up to date in 3s
                    magicmirror@2.27.0 install-fonts
                    echo "Installing fonts …
                    " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                    Installing fonts …
                    up to date in 3s
                    magicmirror@2.27.0 prepare
                    [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                    added 976 packages in 8m
                    205 packages are looking for funding
                    run npm fund for details
                      sdetweil @pat59
                      @pat59 and now
                      npm start
                      • P Offline
                        pat59
                        I don’t know how to thank you, it’s working again, thank you, thank you
                        • P Offline
                          pat59
                          Well, it’s working normally again. I don’t know how to thank you. Thank you, thank you.
                          • P Offline
                            pat59
                            Hello, I must have missed a step. I started my mirror this morning, same problem.
                            pi@raspberrypi:~/MagicMirror $ pm2 stop MagicMirror
                            [PM2] Applying action stopProcessId on app [MagicMirror](ids: [ 1 ])
                            [PM2] MagicMirror ✓
                            │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                            │ 1 │ MagicMirror │ fork │ 0 │ stopped │ 0% │ 0b │
                            │ 0 │ mm │ fork │ 0 │ online │ 0% │ 2.4mb │
                            [2025-09-12 07:06:24.742] [LOG] Starting MagicMirror: v2.27.0
                            [2025-09-12 07:06:24.863] [LOG] Loading config …
                            [2025-09-12 07:06:24.888] [LOG] config template file not exists, no envsubst
                            [2025-09-12 07:06:24.899] [LOG] Loading module helpers …
                            [2025-09-12 07:06:25.265] [LOG] Initializing new module helper …
                            [2025-09-12 07:06:25.269] [LOG] Module helper loaded: MMM-Remote-Control
                            [2025-09-12 07:06:25.273] [LOG] No helper found for module: alert.
                            [2025-09-12 07:06:25.286] [LOG] Initializing new module helper …
                            [2025-09-12 07:06:25.290] [LOG] Module helper loaded: MMM-Saint
                            [2025-09-12 07:06:25.299] [LOG] Initializing new module helper …
                            [2025-09-12 07:06:25.301] [LOG] Module helper loaded: MMM-BME280
                            [2025-09-12 07:06:25.303] [LOG] No helper found for module: MMM-FlipClock.
                            [2025-09-12 07:06:25.467] [LOG] Initializing new module helper …
                            [2025-09-12 07:06:25.469] [LOG] Module helper loaded: MMM-network-signal
                            [2025-09-12 07:06:26.004] [LOG] Initializing new module helper …
                            [2025-09-12 07:06:26.005] [LOG] Module helper loaded: calendar
                            [2025-09-12 07:06:27.471] [LOG] Initializing new module helper …
                            [2025-09-12 07:06:27.474] [LOG] Module helper loaded: MMM-Jast
                            [2025-09-12 07:06:28.921] [LOG] Initializing new module helper …
                            [2025-09-12 07:06:28.923] [LOG] Module helper loaded: MMM-GooglePhotos
                            [2025-09-12 07:06:28.926] [LOG] No helper found for module: MMM-WiFiPassword.
                            [2025-09-12 07:06:28.929] [LOG] No helper found for module: MMM-OpenmapWeather.
                            [2025-09-12 07:06:28.931] [LOG] No helper found for module: MMM-WeatherOrNot.
                            [2025-09-12 07:06:28.933] [WARN] No /home/pi/MagicMirror/js/…/modules/MMM-Linky/MMM-Linky.js found for module: MMM-Linky.
                            [2025-09-12 07:06:28.935] [LOG] No helper found for module: MMM-Linky.
                            [2025-09-12 07:06:29.442] [LOG] Initializing new module helper …
                            [2025-09-12 07:06:29.444] [LOG] Module helper loaded: newsfeed
                            [2025-09-12 07:06:29.446] [LOG] All module helpers loaded.
                            [2025-09-12 07:06:29.475] [LOG] Starting server on port 8080 …
                            [2025-09-12 07:06:29.494] [WARN] You’re using a full whitelist configuration to allow for all IPs
                            [2025-09-12 07:06:31.407] [ERROR] Whoops! There was an uncaught exception…
                            [2025-09-12 07:06:31.452] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                            code: ‘EADDRINUSE’,
                            errno: -98,
                            syscall: ‘listen’,
                            address: ‘0.0.0.0’,
                            port: 8080
                            [2025-09-12 07:06:31.459] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                            [2025-09-12 07:06:31.461] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                            [2025-09-12 07:06:44.850] [INFO] System information:
                            [PM2] MagicMirror ✓
                            code: ‘EADDRINUSE’,
                            errno: -98,
                            syscall: ‘listen’,
                            address: ‘0.0.0.0’,
                            port: 8080
                              sdetweil @pat59
                              @pat59
                              Did you stop it manually ctrl-q
                              Yesterday after we finished testing?
                              pm2 status
                              Is anything listed as running?
                              If not then do this
                              ps -ef| grep MagicMirror
                              You should only get one line of output
                              • P Offline
                                pat59
                                pi@raspberrypi:~ $ cd ~/MagicMirror
                                pi@raspberrypi:~/MagicMirror $ pm2 status
                                │ 1  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.5mb    │
                                │ 0  │ mm                 │ fork     │ 0    │ online    │ 0%       │ 2.3mb    │
                                so you have two instances
                                pi@raspberrypi:~/MagicMirror $ ps -ef|grep MagicMirror
                                pi        1037   818  0 14:29 ?        00:00:00 bash /home/pi/MagicMirror/installers/mm.sh
                                pi        1096  1075 26 14:29 ?        00:00:56 /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js
                                pi        1097  1077 24 14:29 ?        00:00:52 /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js
                                pi        1102  1097  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote --no-zygote-sandbox
                                pi        1103  1096  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote --no-zygote-sandbox
                                pi        1104  1096  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
                                pi        1106  1097  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
                                pi        1109  1104  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
                                pi        1110  1106  0 14:29 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=zygote
                                pi        1407  1103  1 14:31 ?        00:00:01 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --gpu-preferences=WAAAAAAAAAAgAAAEAAAAAAAAAAAAAAAAAABgAAAAAAA4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAGAAAAAAAAAAYAAAAAAAAAAgAAAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --use-gl=angle --use-angle=swiftshader-webgl --shared-files --field-trial-handle=0,i,17126282988831355409,13634691343321116781,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                                pi        1408  1102  0 14:31 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=gpu-process --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --gpu-preferences=WAAAAAAAAAAgAAAEAAAAAAAAAAAAAAAAAABgAAAAAAA4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAGAAAAAAAAAAYAAAAAAAAAAgAAAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --use-gl=angle --use-angle=swiftshader-webgl --shared-files --field-trial-handle=0,i,4975378740503322807,8852675362163135929,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                                pi        1478  1097  0 14:31 ?        00:00:00 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=utility --utility-sub-type=network.mojom.NetworkService --lang=fr --service-sandbox-type=none --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,4975378740503322807,8852675362163135929,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                                pi        1498  1096  1 14:31 ?        00:00:01 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=utility --utility-sub-type=network.mojom.NetworkService --lang=fr --service-sandbox-type=none --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,17126282988831355409,13634691343321116781,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                                pi        1517  1109  4 14:31 ?        00:00:04 /home/pi/MagicMirror/node_modules/electron/dist/electron --type=renderer --enable-crash-reporter=d92a2a3b-ea77-4f26-9bb3-aaab877f322e,no_channel --user-data-dir=/home/pi/.config/Electron --app-path=/home/pi/MagicMirror/js --enable-sandbox --autoplay-policy=no-user-gesture-required --disable-gpu-compositing --lang=fr --num-raster-threads=2 --enable-main-frame-before-activation --renderer-client-id=4 --time-ticks-at-unix-epoch=-1757680110193681 --launch-time-ticks=192347868 --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,17126282988831355409,13634691343321116781,262144 --enable-features=kWebSQLAccess --disable-features=SpareRendererForSitePerProcess --variations-seed-version
                                pi        1662  1367  0 14:33 pts/1    00:00:00 grep --color=auto MagicMirror
                                • P Offline
                                  pat59
                                  Hello, I stopped it with smartphone remote control.
                                    sdetweil @pat59
                                    @pat59 you have two instances… pick one… delete the other
                                    pm2 --help
                                    will give you the command options
                                    what is the remote control function to stop it?
                                    • P Offline
                                      pat59
                                      I used restart RPII used restart RPI
                                      • P Offline
                                        pat59
                                        pi@raspberrypi:~/MagicMirror $ pm2 --help
                                        Usage: pm2 [cmd] app
                                        Options:
                                        -V, --version                                                output the version number
                                        -v --version                                                 print pm2 version
                                        -s --silent                                                  hide all messages
                                        --ext <extensions>                                           watch only this file extensions
                                        -n --name <name>                                             set a name for the process in the process list
                                        -m --mini-list                                               display a compacted list without formatting
                                        --interpreter <interpreter>                                  set a specific interpreter to use for executing app, default: node
                                        --interpreter-args <arguments>                               set arguments to pass to the interpreter (alias of --node-args)
                                        --node-args <node_args>                                      space delimited arguments to pass to node
                                        -o --output <path>                                           specify log file for stdout
                                        -e --error <path>                                            specify log file for stderr
                                        -l --log [path]                                              specify log file which gathers both stdout and stderr
                                        --filter-env [envs]                                          filter out outgoing global values that contain provided strings (default: )
                                        --log-type <type>                                            specify log output style (raw by default, json optional)
                                        --log-date-format <date format>                              add custom prefix timestamp to logs
                                        --time                                                       enable time logging
                                        --disable-logs                                               disable all logs storage
                                        --env <environment_name>                                     specify which set of environment variables from ecosystem file must be injected
                                        -a --update-env                                              force an update of the environment with restart/reload (-a <=> apply)
                                        -f --force                                                   force actions
                                        -i --instances <number>                                      launch [number] instances (for networked app)(load balanced)
                                        --parallel <number>                                          number of parallel actions (for restart/reload)
                                        --shutdown-with-message                                      shutdown an application with process.send('shutdown') instead of process.kill(pid, SIGINT)
                                        -p --pid <pid>                                               specify pid file
                                        -k --kill-timeout <delay>                                    delay before sending final SIGKILL signal to process
                                        --listen-timeout <delay>                                     listen timeout on application reload
                                        --max-memory-restart <memory>                                Restart the app if an amount of memory is exceeded (in bytes)
                                        --restart-delay <delay>                                      specify a delay between restarts (in milliseconds)
                                        --exp-backoff-restart-delay <delay>                          specify a delay between restarts (in milliseconds)
                                        -x --execute-command                                         execute a program using fork system
                                        --max-restarts [count]                                       only restart the script COUNT times
                                        -u --user <username>                                         define user when generating startup script
                                        --uid <uid>                                                  run target script with <uid> rights
                                        --gid <gid>                                                  run target script with <gid> rights
                                        --namespace <ns>                                             start application within specified namespace
                                        --cwd <path>                                                 run target script from path <cwd>
                                        --hp <home path>                                             define home path when generating startup script
                                        --wait-ip                                                    override systemd script to wait for full internet connectivity to launch pm2
                                        --service-name <name>                                        define service name when generating startup script
                                        -c --cron <cron_pattern>                                     restart a running process based on a cron pattern
                                        -c --cron-restart <cron_pattern>                             (alias) restart a running process based on a cron pattern
                                        -w --write                                                   write configuration in local folder
                                        --no-daemon                                                  run pm2 daemon in the foreground if it doesn't exist already
                                        --source-map-support                                         force source map support
                                        --only <application-name>                                    with json declaration, allow to only act on one application
                                        --disable-source-map-support                                 force source map support
                                        --wait-ready                                                 ask pm2 to wait for ready event from your app
                                        --merge-logs                                                 merge logs from different instances but keep error and out separated
                                        --watch [paths]                                              watch application folder for changes (default: )
                                        --ignore-watch <folders|files>                               List of paths to ignore (name or regex)
                                        --watch-delay <delay>                                        specify a restart delay after changing files (--watch-delay 4 (in sec) or 4000ms)
                                        --no-color                                                   skip colors
                                        --no-vizion                                                  start an app without vizion feature (versioning control)
                                        --no-autostart                                               add an app without automatic start
                                        --no-autorestart                                             start an app without automatic restart
                                        --stop-exit-codes <exit_codes...>                            specify a list of exit codes that should skip automatic restart
                                        --no-treekill                                                Only kill the main process, not detached children
                                        --no-pmx                                                     start an app without pmx
                                        --no-automation                                              start an app without pmx
                                        --trace                                                      enable transaction tracing with km
                                        --disable-trace                                              disable transaction tracing with km
                                        --sort <field_name:sort>                                     sort process according to field's name
                                        --attach                                                     attach logging after your start/restart/stop/reload
                                        --v8                                                         enable v8 data collecting
                                        --event-loop-inspector                                       enable event-loop-inspector dump in pmx
                                        --deep-monitoring                                            enable all monitoring tools (equivalent to --v8 --event-loop-inspector --trace)
                                        -h, --help                                                   output usage information
                                        Commands:
                                        start [options] [name|namespace|file|ecosystem|id...]        start and daemonize an app
                                        trigger <id|proc_name|namespace|all> <action_name> [params]  trigger process action
                                        deploy <file|environment>                                    deploy your json
                                        startOrRestart <json>                                        start or restart JSON file
                                        startOrReload <json>                                         start or gracefully reload JSON file
                                        pid [app_name]                                               return pid of [app_name] or all
                                        create                                                       return pid of [app_name] or all
                                        startOrGracefulReload <json>                                 start or gracefully reload JSON file
                                        stop [options] <id|name|namespace|all|json|stdin...>         stop a process
                                        restart [options] <id|name|namespace|all|json|stdin...>      restart a process
                                        scale <app_name> <number>                                    scale up/down a process in cluster mode depending on total_number param
                                        profile:mem [time]                                           Sample PM2 heap memory
                                        profile:cpu [time]                                           Profile PM2 cpu
                                        reload <id|name|namespace|all>                               reload processes (note that its for app using HTTP/HTTPS)
                                        id <name>                                                    get process id by name
                                        inspect <name>                                               inspect a process
                                        delete|del <name|id|namespace|script|all|json|stdin...>      stop and delete a process from pm2 process list
                                        sendSignal <signal> <pm2_id|name>                            send a system signal to the target process
                                        ping                                                         ping pm2 daemon - if not up it will launch it
                                        updatePM2                                                    update in-memory PM2 with local PM2
                                        update                                                       (alias) update in-memory PM2 with local PM2
                                        install|module:install [options] <module|git:/>              install or update a module and run it forever
                                        module:update <module|git:/>                                 update a module and run it forever
                                        module:generate [app_name]                                   Generate a sample module in current folder
                                        uninstall|module:uninstall <module>                          stop and uninstall a module
                                        package [target]                                             Check & Package TAR type module
                                        publish|module:publish [options] [folder]                    Publish the module you are currently on
                                        set [key] [value]                                            sets the specified config <key> <value>
                                        multiset <value>                                             multiset eg "key1 val1 key2 val2
                                        get [key]                                                    get value for <key>
                                        conf [key] [value]                                           get / set module config values
                                        config <key> [value]                                         get / set module config values
                                        unset <key>                                                  clears the specified config <key>
                                        report                                                       give a full pm2 report for https://github.com/Unitech/pm2/issues
                                        link [options] [secret] [public] [name]                      link with the pm2 monitoring dashboard
                                        unlink                                                       unlink with the pm2 monitoring dashboard
                                        monitor [name]                                               monitor target process
                                        unmonitor [name]                                             unmonitor target process
                                        open                                                         open the pm2 monitoring dashboard
                                        plus|register [options] [command] [option]                   enable pm2 plus
                                        login                                                        Login to pm2 plus
                                        logout                                                       Logout from pm2 plus
                                        dump|save [options]                                          dump all processes for resurrecting them later
                                        cleardump                                                    Create empty dump file
                                        send <pm_id> <line>                                          send stdin to <pm_id>
                                        attach <pm_id> [comman]                                      attach stdin/stdout to application identified by <pm_id>
                                        resurrect                                                    resurrect previously dumped processes
                                        unstartup [platform]                                         disable the pm2 startup hook
                                        startup [platform]                                           enable the pm2 startup hook
                                        logrotate                                                    copy default logrotate configuration
                                        ecosystem|init [mode]                                        generate a process conf file. (mode = null or simple)
                                        reset <name|id|all>                                          reset counters for process
                                        describe <name|id>                                           describe all parameters of a process
                                        desc <name|id>                                               (alias) describe all parameters of a process
                                        info <name|id>                                               (alias) describe all parameters of a process
                                        show <name|id>                                               (alias) describe all parameters of a process
                                        env <id>                                                     list all environment variables of a process id
                                        list|ls                                                      list all processes
                                        l                                                            (alias) list all processes
                                        ps                                                           (alias) list all processes
                                        status                                                       (alias) list all processes
                                        jlist                                                        list all processes in JSON format
                                        sysmonit                                                     start system monitoring daemon
                                        slist|sysinfos [options]                                     list system infos in JSON
                                        prettylist                                                   print json in a prettified JSON
                                        monit                                                        launch termcaps monitoring
                                        imonit                                                       launch legacy termcaps monitoring
                                        dashboard|dash                                               launch dashboard with monitoring and logs
                                        flush [api]                                                  flush logs
                                        reloadLogs                                                   reload all logs
                                        logs [options] [id|name|namespace]                           stream logs file. Default stream all logs
                                        kill                                                         kill daemon
                                        pull <name> [commit_id]                                      updates repository for a given app
                                        forward <name>                                               updates repository to the next commit for a given app
                                        backward <name>                                              downgrades repository to the previous commit for a given app
                                        deepUpdate                                                   performs a deep update of PM2
                                        serve|expose [options] [path] [port]                         serve a directory over http via port
                                        autoinstall
                                        examples                                                     display pm2 usage examples
                                          sdetweil @pat59
                                          @pat59 said in update package list:
                                          I don’t know what that means in reality under the covers
                                          so, you need to delete one of the apps… unless you intentionally have two instances.
                                          they show online, and no restarts, which is weird
                                          • P Offline
                                            pat59
                                            Well, thank you, I’m going to stop now. I’m 65 years old and I don’t always understand what to do. I’m a novice. I don’t know which application to delete. Thanks again for your help.
                                              sdetweil @pat59
                                              @pat59 im 74… so its never too late
                                              try this
                                              pm2 stop mm
                                              pm2 restart MagicMirror
                                              • 1 / 3
