    Best Weather module.
    4 Posts 3 Posters 1.2k Views 3 Watching
    • plainbrokeP
      plainbroke
      I am using MMM-PirateSkyForecast module, I think that is the name of it.
      I am wanting to find one that is the most accurate with temps and precipitation.
      We removed MMM-OpenWeatherForecast with Api3.0 due to inaccurate weather.
      It was telling us 11 inches of rain expected with a 23% chance of rain with the temp constantly off 5 to 10 degrees.
      Just wondering what everyone else is using and if what you use is very accurate or not at all.
      S mumblebajM 2 Replies Last reply
        sdetweil @plainbroke
        @plainbroke did you have a wrong location???
        plainbrokeP 1 Reply Last reply
        • mumblebajM
          mumblebaj Module Developer @plainbroke
          @plainbroke You can give this one a try, https://github.com/mumblebaj/MMM-NOAA3
          • plainbrokeP
            plainbroke @sdetweil
            Don’t think so, because I use the same location for pirate one.
            It is pretty much spot on most of the time. Open weather was off more than it wasn’t lately.
            @mumblebaj
            I did not know Noaa3 was still working. I will give it a try…
            • plainbrokeP plainbroke has marked this topic as solved on
