    MagicMirror on Trixie
    8 Posts 4 Posters 2.2k Views 5 Watching
    • R
      Rags
      I took the plunge. My five year old MagicMirror ground to a halt as far as Display resolution, Rotation and DIsplay control are concerned. Everything was working great on my Raspberry Pi 3B+. An unfortunate rpi-update broke everything. I struggled to restore Bullseye, and it was a shock to realise it is not easy to find the right official image.
      I then tried Bookworm, the three issues continued to remain unsolved.
      I then decided to install Trixie. Most of the transition of MM was smooth, ofcourse with a few hicks, but getting the display resolution and rotation was the most frustrating part.
      I got it working finally. I have restored the Display resolution and the rotation succesfully.
      I will shortly upload the entire process which was not only exhausting but of great learning value.
      I need to recover the GPIO Notification Module which isnt working and resulting Motion control of monitor using RCWL0516.
      plainbrokeP 1 Reply Last reply Reply Quote 2
      • plainbrokeP
        plainbroke @Rags
        @Rags
        Did you get it to work like it did on bookworm?
        Mine on Trixie looks like it goes into screensaver mode, but I have made sure screen blanking is turned off in raspi-config
        I ran Sam’s screensaver off script. Mine just keeps blanking the screen the exact same image works fine on bookworm but blanks on trixie… Really frustrating.
          sdetweil @plainbroke
          @plainbroke yes, they changed the UI manager AGAIN…
          plainbrokeP 1 Reply Last reply Reply Quote 0
          • plainbrokeP
            plainbroke @sdetweil
            So what is the fix? or is there one even.?
            B plainbrokeP 2 Replies Last reply Reply Quote 0
            • B
              BGH_H @plainbroke
              Mine was running on an old version since 2021. I noticed it got really slow so I did the same. I’m still in the process reinstalling and updating on a 4b with 8gb.
              I had troubles with turning the mirror off and on with a webcam usb camera based on motion. I (and ChatGPT mostly) rewrote the mmm-motiondectortor to be compatible with the new os. Vcmgen isn’t supported anymore. I used external execute script to power of and on with wlandr display driver. ChatGPT is actually pretty good at reading and rewriting .js if you give it the right inputs.
              • plainbrokeP
                plainbroke @plainbroke
                I had to add a blank line in this to get config.js to work with MM 2.33 on Trixie to run my 50+ modules on my MM using Pages by @sdetweil
                let config = {
                	ignoreXOriginHeader: true,
                	ignoreContentSecurityPolicy: true,
                	electronOptions: {
                	webPreferences: {
                	webviewTag: true,
                  @plainbroke can you post the error without the blank line?
                  We have been trying to make the tester better, but there are trouble spots
                  • plainbrokeP
                    No error message, just black screen on some modules. I am still having some issues with modules just not showing up… Putting that space in, now I get webview and 2 of the iframe modules working. Nixie clock is fighting me for some reason. I just have not had any time to really dig into it the last week or so…
