    problem with config.js file
    4 Posts 3 Posters 926 Views 3 Watching
      Jose1701
      I#m not very used with programming so i can’t solve the problem in my config.js
        module: "MMM-Hoymiles-Wifi",
          width: "300px",
          height: "320px",
          updateInterval: 60000, // in milli seconds
          frames : [
            { src: 'http://192.168.178.150:5000'},
      I always get errors like this;
      npm run config:check
      magicmirror@2.33.0 config:check
      node js/check_config.js
      [2025-11-01 15:16:44.895] [INFO] Checking config file /home/florian/MagicMirror/config/config.js …
      [2025-11-01 15:16:44.994] [ERROR] Your configuration file contains syntax errors :(
      Line 232 column 1: Parsing error: Unexpected token }
      Thanks a lot if everybody could help me.
      Kinds regards
      Florian
      S evroomE 2 Replies Last reply Reply Quote 0
        sdetweil @Jose1701
        @Jose1701 so, at the top we have
        var config = {
                                    module: x
                                repeat for each module
        and at the bottom  ( all of this is missing )
        ]  // end of modules list
        }  // end of config variable
          Jose1701 @sdetweil
          Thanks a lot. Got it working!
          • evroomE Online
            evroom @Jose1701
            @Jose1701
            The
            needs to be
            So a comma iso of a semicolon.
            MagicMirror version: 2.37.0
