    Best Raspberry Pi for MagicMirror – Expert Recommendation to Choose
    4 Posts 4 Posters 4.3k Views 5 Watching
    • A
      alexa123
      I have researched the best Raspberry Pi models for the past few days because I want to set up a MagicMirror at home. I read reviews on tech blogs, YouTube channels, and trusted forums, and they are marking these two as the best options:
      Vilros Raspberry Pi 5
      https://www.amazon.com/Vilros-Raspberry-Starter-Kit-MAX/dp/B0D232HN74
      Raspberry Pi 5 8GB
      https://www.amazon.com/Raspberry-Pi-8GB-SC1112-Quad-core/dp/B0CK2FCG1K
      However, I am having trouble deciding which one would best suit my needs and need your expert advice. I plan to use the MagicMirror for displaying calendar, weather, news, and home automation controls.
      So which one should I buy? Any recommendation would be greatly appreciated.
      Thanks in advance!
      S N R 3 Replies Last reply Reply Quote 0
        sdetweil @alexa123
        @alexa123 you will need a power supply, and a video cable or adapter, and a case and fan are not bad additions…
        8gb is large (for now!!)
        • N
          nowayto @alexa123
          @alexa123
          They suggested you the best option,
          but these are way powerful for what you really need for running a MM.
          Clearly, more powerful=better
          But on my experience I run a simple instance of MM on a Raspberry 3 A+, daily.
          For simple instance I mean these modules: basic clock, CalendarEXT3, basic calendar, MM-Formula1 and a module for monitor the solar panel energy production.
          So you don’t need very powerful machines, in my opinion.
          The best advice is, as sdtweil said, USE a Raspberry power supply
          NOT a simple charger
          • R
            rkorell Module Developer @alexa123
            @alexa123 as already stated Pi5 is kind of oversized.
            I had build up two identical mirrors - one for me and later on a second one (a clone) for a fried of mine.
            My own is on a Pi5/8GB which was always hot and the power supply was hot as well - which led to some major modifications in my mirror setup because I had to move the power supply out of the frame - which was not that easy, annoying and unsatisfying…
            The ONLY fact that IS useful and is an argument for the Pi5 is the really smooth integration of a NVME SSD disk which I had performed and am happy with. The fan on the pi5 is HUGE ! (NOT the „official Pi 5 fan“ tiny thingi which isn’t sufficient). Picture of fan
            The second mirror (clon) is software-wise nearly identical but is installed on a (spare) Pi4 which layed around so it was no problem to overhand it to my friend. This is performance/capacity wise identical and MUCH colder. The SD-card reliability problem on this Pi4 is solved with an USB-SSD-Stick.
            Today I might go for the Pi4 again…
            Good luck!
            Ralf
