    Problems building opengpio when installing the MMM-GPIO-Notifications module
    7 Posts 3 Posters 1.6k Views 3 Watching
    • Q
      Queasy
      Hi all,
      I want to have the MMM-GPIO-Notification module send notifications when a Pi GPIO pin goes high.
      I have GPIO pin 17 (Pi connector pin 11) with a 10k pull down, resistor and see it go from 0v to 3.255v when the switch is closed.
      I followed the setup instructions here https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications (not docker), but npm install fails with the same errors that are discussed here:
      https://github.com/ExpeditionExploration/opengpio/issues/37 .
      The issue was fixed in opengpio v2.0.1. As an experiment I changed the MMM-GPIO-Notification package.json opengpio dependency from ~1.0.13 to ~2.0.1
      npm install now runs without error (it also built with opengpio v2.0.0 which surprised me)
      When I close the switch, I don’t see any indication in the server logs or MMM-ViewNotifications that any notifications were sent, but I’m not sure if it’s because I have the Pi/MM set up incorrectly, or because it’s not the right version opengpio :(
      I tried both with and without the forceInfoFileUsage option.
      Server startup::
      [LOG]   Loading config ...
      [LOG]   config template file not exists, no envsubst
      [INFO]  Checking config file MagicMirror/config/config.js ...
      [INFO]  Your configuration file doesn't contain syntax errors :)
      [INFO]  Checking modules structure configuration ...
      [INFO]  Your modules structure configuration doesn't contain errors :)
      [LOG]   Loading module helpers ...
      [LOG]   No helper found for module: alert.
      [LOG]   No helper found for module: clock.
      [LOG]   Initializing new module helper ...
      [LOG]   Module helper loaded: calendar
      [LOG]   No helper found for module: weather.
      [LOG]   No helper found for module: MMM-ViewNotifications.
      [LOG]   Module helper loaded: MMM-GPIO-Notifications
      [LOG]   All module helpers loaded.
      [LOG]   Starting server on port 8080 ...
      [LOG]   Server started ...
      [LOG]   Connecting socket for: calendar
      [LOG]   Starting node helper for: calendar
      [LOG]   Connecting socket for: MMM-GPIO-Notifications
      [LOG]   Sockets connected & modules started ...
      [LOG]   Launching application.
      [INFO]
      ####  System Information  ####
      SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Rev 1.2; virtual: false; MM: 2.33.0
      OS:       platform: linux; distro: Debian GNU/Linux; release: 13; arch: arm64; kernel: 6.12.47+rpt-rpi-v8
      VERSIONS: electron: 38.1.2; used node: 22.19.0; installed node: 25.1.0; npm: 11.6.2; pm2: 6.0.13
      ENV:      XDG_SESSION_TYPE: wayland; MM_CONFIG_FILE: undefined
                  WAYLAND_DISPLAY:  wayland-0; DISPLAY: :0; ELECTRON_ENABLE_GPU: undefined
      RAM:      total: 906.04 MB; free: 405.40 MB; used: 500.64 MB
      OTHERS:   uptime: 225 minutes;
      [LOG]   MMM-GPIO-Notifications: Using naming schema Default
      [LOG]   Force use of GPIO info file is configured. Using the information of gpioinfo.json instead of a specific device!
      [LOG]   MMM-GPIO-Notifications: Trying to registering pin: 17
      [LOG]   MMM-GPIO-Notifications: Using chip (0) and line (17) info of GPIO17
      [LOG]   MMM-GPIO-Notifications: Watched pin: 17 has low state delay of 1000!
      [LOG]   MMM-GPIO-Notifications: Watched pin: 17 has high state delay of 1000!
      [LOG]   MMM-GPIO-Notifications: Successfully registered pin: 17
      config.js:
      	module: 'MMM-ViewNotifications',
      	header: 'Notifications',
      		timeout: 20,
      		format: '{time}: "{module}" sent "{notification}" with {payloadData}',
      		includeModules: ["MMM-GPIO-Notifications"]
      	module: 'MMM-GPIO-Notifications',
      		'17': {
      			delay: 1000,
      			notifications_high: [
      					notification: 'TEST_NOTIFICATION',
      					payload: {}
      Is there any kind of extra logging for MMM-GPIO-Notifications or opengpio I can perhaps switch on?
      Thanks in advance for any other info or suggestions.
      ~Queasy…
      S wishmaster270W 2 Replies Last reply Reply Quote 0
      • wishmaster270W
        wishmaster270 Module Developer @Queasy
        @Queasy
        Hi and sorry for the late reply.
        I released a new version of the module a couple of minutes ago which should fix the problem.
        It uses the new version of the lib for newer operation systems and changes to a other branch if it is a old debian otherwise.
        As expected the api of the lib changed and i needed to do a small change in the modules node_helper.js.
        Q 1 Reply Last reply Reply Quote 0
          sdetweil @Queasy
          @Queasy generally you would open an issue on the module GitHub page to engage the module author
          • wishmaster270W
            @Queasy Hi,
            I will try to take a closer look at the problem in the next days.
            I do not have a setup with Debian 13 at the moment and it will take me some time.
            Did not test 2.x of open gpio yet. Maybe the api changed.
            Make sure you set up the pull-up/pull-down resistor like described in this description
            https://www.raspberrypi.com/documentation/computers/config_txt.html#gpio-control
            • Q
              Queasy @wishmaster270
              @wishmaster270 Great - thanks
              Here is some more info in case it helps:
              As well as a pull-down resistor, I also tried a pull up, and tried without any resistor - neither sent notifications.
              To double check, I used Python (RPi.GPIO) and received the events from GPIO 17 when the switch was closed.
              Rasberry Pi OS was install around Nov 2 2025 using the Rasberry Pi imager
              $ uname -a
              Linux raspberrypi 6.12.47+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1 (2025-09-16) aarch64 GNU/Linux
              • wishmaster270W
                @Queasy
                • Q
                  @wishmaster270
                  Now works great on my RasberryPi - thanks
                  • wishmaster270W
                    @Queasy
                    Great to hear that. As I am using Debian 12 at the moment I am optimistic it is working for older installations, too.
                    I think the topic is solved then.
