    MMM-PIR-Sensor off delay
    6 Posts 2 Posters 3.5k Views 2 Watching
      svonbentzel
      Hello together,
      it is possible to add a off delay to the module?
      PAVIRO-MMM-PIR
      if true ? --> Where? ;-)
      Thanks for answers
      Best Greets
      • Y
        yawns Moderator
        There is a fork which is supposed to do exactly that:
        https://github.com/Patrick-Remy/MMM-PIR-Sensor
        Reply Quote 1
          svonbentzel
          sorry maybe i expressed wrong:
          this module is running perfectly but I need a OFF-DELAY (mirror turns on and stay a while on before switch off)
          like time.sleep(50)
          Y 1 Reply Last reply
          • Y
            yawns Moderator @svonbentzel
            @svonbentzel
            Understood. And the forked version added this configuration option:
            powerSavingDelay
            Additional software side delay (in seconds) before the monitor will be turned off. Possible values: int, default value: 0
              svonbentzel
              ahh, -ok thank you,
              i have used the old configuration options.
              Thank You
                svonbentzel
                on this site is the git clone command false:
                MMM-PIR
                the correct clone command is:
                git clone https://github.com/**Patrick-Remy**/MMM-PIR-Sensor.git
