    pages and simple back groung slidswhows
    8 Posts 2 Posters 1.6k Views 2 Watching
    • V Offline
      videogame95
      Hi have simple background slide show and pages install ill add the config at a later date I’v renamed images pic1 pic2 and up 4pic pic 5 the only pic to show up is
      pic1 the picture are in folder called images my clock comes on page 1 when it changes to page 2 should pic2 and google calendar thats working fine but no pic 2 or 3, 4, 5,
      picture should. came up on all pages .
      ill add the config.js file tomorrow
      any help how to add the code this forum?
      any suggestions help please
      S V 2 Replies Last reply Reply Quote 0
        sdetweil @videogame95
        @videogame95 what module for the background?
        Is the module for images listed in the fixed section of pages config
        What do you mean renamed the pics?
        Are you doing this thru css?
        • V Offline
          videogame95
          Hi using back round slide show 3rd party module I have install page indicator
          how do i add code to this page and ill add it in next time . I’ve tried adding London for transport Timetable But unfortunately its not showing up even when I’ve added the API keys off the site Any help The problems are heavy.
          thank you
            @videogame95 sorry, I don’t understand ‘this page’
            Always showing goes with fixed
            Others have names I. The modules section
            Or
            classes: at the modules
            Page indicator should be in the fixed section
            • V Offline
              videogame95 @videogame95
              Is there a way of video to the page I can add pictures of my screen if possible Sorry I forgot to add this into my other part of the post,
              Thank you for any help
              • V Offline
                videogame95
                back gound slide show is a 3rd party module
                it rolls over images about 5 image tress waterfalls etc I’ve change some of the pictures to my own .
                • V Offline
                  videogame95
                  let config = {
                  address: “localhost”,
                  port: 8080,
                  basePath: “/”,
                  ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”],
                  language: "en",
                  locale: "en-GB",
                  timeFormat: 24,
                  units: "metric",
                  		module: "alert",
                  		module: "updatenotification",
                  		position: "top_bar"
                  		module: "clock",
                  			calendars: [{
                  				symbol: "calendar-check",
                  				url: "https://calendar.google.com/calendar/ical/jamesharris4191%40gmail.com/private-a9dbbb5842466e98dfa403a4f00fc787/basic.ics"
                  		module: "MMM-UKNationalRail",
                  		module: "weather",
                  			weatherProvider: "openmeteo",
                  			type: "current",
                  			lat: 51.575,
                  			lon: 0.180
                  		module: "MMM-BackgroundSlideshow",
                  		position: "fullscreen_below",
                  			imagePaths: ["modules/MMM-BackgroundSlideshow/exampleImages/"],
                  			transitionInterval: 20000,
                  			slideshowSpeed: 20000,
                  		header: "Romford Station",
                  			stationCode: "ROM",
                  			app_id: "099938b9", // <--- CHANGE THIS
                  			app_key: "6ef71984b273400141cb5dbc847aed00", // <--- CHANGE THIS
                  			maxResults: 5,
                  			updateInterval: 600000 // 10 minutes
                  		module: "MMM-UKLiveBusStopInfo",
                  		header: "Romford Market Buses",
                  			atcocode: "490011659G",
                  			app_id: "099938b9", // <--- CHANGE THIS (same as above)
                  			app_key: "6ef71984b273400141cb5dbc847aed00", // <--- CHANGE THIS (same as above)
                  			nextBuses: "yes",
                  			showRealTime: true,
                  			updateInterval: 300000 // 5 minutes
                  		module: "MMM-page-indicator",
                  		position: "bottom_bar",
                  		config: { pages: 4 }
                  		module: "MMM-pages",
                  				["calendar", "weather", "clock"],
                  				["MMM-SoccerLiveScore"],
                  				["MMM-UKNationalRail", "MMM-UKLiveBusStopInfo"],
                  			fixed: ["alert", "updatenotification", "MMM-BackgroundSlideshow", "MMM-page-indicator"],
                  			timings: { default: 20000 }
                  if (typeof module !== “undefined”) {module.exports = config;}
                    @videogame95
                    What is this?
                    Can’t have a page with no modules defined on it,
                    edit: this doesn’t show the error
                    Mmm-pages is all in browser, so open the browser console
                    ctrl-shift-i
                    Select the console tab
                    Add pages to the filter field
                    also, for MMM-page-indicator, it can figure out how many pages you have defined, so this
                    is not necessary (and misleading, when you have only 3 pages, technically)
