    Failed to Connect to Wayland Display
    58 Posts 7 Posters 14.3k Views 6 Watching
      Scruffy @sdetweil
      @sdetweil said:
      npm run start:wayland
      Unfortunately, still no go.
      The whole system is feeling sluggish… I wounder if it’s an SD issue…?
      I have a new SD card arriving later today. I’ll image and reinstall MM and report back.
      If it’s still not working, I’ll provide the logs again.
      Cannot thank you enough, @sdetweil. You’re incredibly responsive and your support is greatly appreciated.
      Cheers!
      S A 2 Replies Last reply Reply Quote 0
        sdetweil @Scruffy
        @Scruffy use my backup/restore scripts to save and restore your MagicMirror config and modules list
        Backup, copy off backup folder, tiny size
        Install new MagicMirror and copy back folder and restore
          atwist @Scruffy
          @Scruffy I actually never resolved my issue either. But, my system was very sluggish as well.
          S S 2 Replies Last reply Reply Quote 1
            sdetweil @atwist
            @atwist the latest PI OS is larger than the previous versions…
            leading to more swapping. This can affect performance because of the speed of the SD card.
            free -m
            will tell you how much memory and swap space you are using.
              Scruffy @atwist
              @atwist what did you end up doing? Or are you still without MM working?
                Scruffy @sdetweil
                @sdetweil I ran the command and this is my output.
                             total       used      free      shared     buff/cache   available
                Mem:         3992        2153      210       550        2126         1839
                Swap:        511         30        481
                Is the output in MB? Doesn’t seem like it’s to the point where everything is so slow to respond.
                  sdetweil @Scruffy
                  @Scruffy pi4, 4 gig?
                    Scruffy @sdetweil
                    @sdetweil Pi 5 4GB
                      Scruffy @sdetweil
                      @sdetweil UPDADE:
                      I have MagicMirror back up and running using a new SD card. I’m guessing the old one died for whatever reason since the whole system was becoming extremely sluggish to the point it would take 10 seconds between input commands triggering.
                      Glad to be back up and running!
                      Thank you again for all your help troubleshooting and support us!
                      Cheers!
                        sdetweil @Scruffy
                        @Scruffy awesome!!! Thanks for the feedback!
                        How did you migrate your config ?
                        Just interested in how people do things
                          Scruffy @sdetweil
                          @sdetweil I’m still very new to Linux/Pi so I was concerned I may have corrupted my original config file(s) with all the changes/modifications I was performing when trying to get the original system back up and running.
                          I copied over the old config.js which has all my module settings.
                          I installed MM from scratch along with all the modules. I then brought up both config.js files in Geany and copied and pasted over my configurations.
                          Not the cleanest of methods but it worked lol.
                            sdetweil @Scruffy
                            @Scruffy thanks.
                              sdetweil @Scruffy
                              @Scruffy I strongly recommend using some backup/restore mechanism,
                              please see my backup/restore scripts for one approach.
                              they also support versioning, so you can tell one set of changes from another and can go back or forward…
                              and move between systems. too…
                              https://github.com/sdetweil/MagicMirror-backup-restore.git
                              and I also support the install/upgrade scripts, mentioned in the MM doc, Alternative install section
                              M S 2 Replies Last reply Reply Quote 1
                                magicmikael @sdetweil
                                @sdetweil, I am running into a similar occurrence but from your initial post I don’t have pm2 installed (as you can see below). Any advice would be appreciated. I have completely reimaged my Pi and retried the steps.
                                I followed all of the standard manual install steps, have git and node and npm.
                                This is what I am getting when attempting to run ‘node --run start’
                                Starting server on port 8080 …
                                [1877:0409/161415.143762:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                                [1877:0409/161415.143988:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                                [1877:0409/161415.144045:ERROR:ui/aura/env.cc:246] The platform failed to initialize. Exiting.
                                /home/onthewall/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                                System Information
                                • SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.2; virtual: false; MM: v2.35.0
                                • OS: platform: linux; distro: Debian GNU/Linux; release: 13; arch: arm64; kernel: 6.12.75+rpt-rpi-v8
                                • VERSIONS: electron: 41.1.0; used node: 24.14.1; installed node: 24.14.1; npm: 11.11.0; pm2:
                                • ENV: XDG_SESSION_TYPE: undefined; MM_CONFIG_FILE: undefined
                                  WAYLAND_DISPLAY: wayland-1; DISPLAY: undefined; ELECTRON_ENABLE_GPU: undefined
                                • RAM: total: 3796.68 MB; free: 3304.59 MB; used: 492.10 MB
                                • OTHERS: uptime: 1 minutes; timeZone: America/Los_Angeles
                                  sdetweil @magicmikael
                                  @magicmikael as we said in the readme notes on the release
                                  We changed
                                  npm start/node —run start
                                  To launch for Wayland compositor
                                  If you are still on x11
                                  You need to use
                                  npm run start:x11
                                  Or
                                  node —run start:x11
                                    @sdetweil, I ran a fresh install of the OS (64-bit). I would have assumed it would be all set for Wayland. Confirmed under raspi-config its “Wayland” but strangely
                                    echo $XDG_SESSION_TYPE
                                    returns nothing.
                                    I am thinking of going the pm2 route and trying to launch using your aforementioned script but I can’t imagine it would yield another result.
                                      @magicmikael if you do env
                                      Do you see wayland_display in the list?
                                      The script sets WAYLAND_DISPLAY if not already set
                                      Here is the script , make sure to make it executable
                                      chmod +x mm.sh
                                      #!/bin/bash
                                      cd ~/MagicMirror
                                      if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
                                         # if WAYLAND_DISPLAYis set, use it, else set to -0
                                         export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                                      else
                                         DISPLAY=:0 npm run start:x11
                                      fi
                                        Scruffy @sdetweil
                                        OK perfect! I’ll run through this process next time this occurs. Thanks!
                                        • 3 / 3
