    Problem after update Master branch
    9 Posts 3 Posters 2.5k Views 3 Watching
    • K
      Klinge
      Hello,
      A few days ago, I tried to update my MM using the update script from @sdetweil with the “apply” option. Unfortunately, it didn’t work.
      Yesterday, I tried the same thing, but with the “force” option. But that didn’t work either.
      Now I renamed the folder ‘MagicMirror’ and tried to install MM using the installation script by @sdetweil . But that didn’t work either.
      The debug log contains the following information. I will show you the last ~70 lines. I hope that is enough.
      668 silly packumentCache full:https://registry.npmjs.org/chalk cache-hit
      669 silly fetch manifest commander@^4.0.1
      670 silly packumentCache full:https://registry.npmjs.org/commander cache-miss
      671 silly fetch manifest diff@^4.0.1
      672 silly packumentCache full:https://registry.npmjs.org/diff cache-miss
      673 silly fetch manifest handlebars@^4.5.3
      674 silly packumentCache full:https://registry.npmjs.org/handlebars cache-miss
      675 silly fetch manifest lodash@^4.17.15
      676 silly packumentCache full:https://registry.npmjs.org/lodash cache-miss
      677 http fetch GET 200 https://registry.npmjs.org/lodash 303ms (cache revalidated)
      678 silly packumentCache full:https://registry.npmjs.org/lodash set size:242486 disposed:false
      679 silly fetch manifest replace-last@^1.2.6
      680 silly packumentCache full:https://registry.npmjs.org/replace-last cache-miss
      681 http fetch GET 200 https://registry.npmjs.org/diff 442ms (cache miss)
      682 silly packumentCache full:https://registry.npmjs.org/diff set size:undefined disposed:false
      683 silly fetch manifest string.prototype.matchall@^4.0.8
      684 silly packumentCache full:https://registry.npmjs.org/string.prototype.matchall cache-miss
      685 silly fetch manifest @typescript-eslint/types@^8.35.0
      686 silly packumentCache full:https://registry.npmjs.org/@typescript-eslint%2ftypes cache-miss
      687 http cache https://registry.npmjs.org/@typescript-eslint%2ftypes 110ms (cache hit)
      688 silly packumentCache full:https://registry.npmjs.org/@typescript-eslint%2ftypes set size:11733932 disposed:false
      689 silly fetch manifest comment-parser@^1.4.1
      690 silly packumentCache full:https://registry.npmjs.org/comment-parser cache-miss
      691 http fetch GET 200 https://registry.npmjs.org/string.prototype.matchall 896ms (cache miss)
      692 silly packumentCache full:https://registry.npmjs.org/string.prototype.matchall set size:undefined disposed:false
      693 silly fetch manifest debug@^4.4.1
      694 silly packumentCache full:https://registry.npmjs.org/debug cache-hit
      695 silly fetch manifest eslint-import-context@^0.1.9
      696 silly packumentCache full:https://registry.npmjs.org/eslint-import-context cache-miss
      697 silly fetch manifest is-glob@^4.0.3
      698 silly packumentCache full:https://registry.npmjs.org/is-glob cache-hit
      699 silly fetch manifest minimatch@^9.0.3 || ^10.0.1
      700 silly packumentCache full:https://registry.npmjs.org/minimatch cache-hit
      701 silly fetch manifest semver@^7.7.2
      702 silly packumentCache full:https://registry.npmjs.org/semver cache-hit
      703 silly fetch manifest stable-hash-x@^0.2.0
      704 silly packumentCache full:https://registry.npmjs.org/stable-hash-x cache-miss
      705 http fetch GET 200 https://registry.npmjs.org/eslint-import-context 189ms (cache miss)
      706 silly fetch manifest unrs-resolver@^1.9.2
      707 silly packumentCache full:https://registry.npmjs.org/unrs-resolver cache-miss
      708 silly fetch manifest @es-joy/jsdoccomment@~0.76.0
      709 silly packumentCache full:https://registry.npmjs.org/@es-joy%2fjsdoccomment cache-miss
      710 silly fetch manifest @es-joy/resolve.exports@1.2.0
      711 silly packumentCache full:https://registry.npmjs.org/@es-joy%2fresolve.exports cache-miss
      712 silly fetch manifest are-docs-informative@^0.0.2
      713 silly packumentCache full:https://registry.npmjs.org/are-docs-informative cache-miss
      714 http fetch GET 200 https://registry.npmjs.org/are-docs-informative 82ms (cache miss)
      715 silly fetch manifest comment-parser@1.4.1
      716 silly packumentCache full:https://registry.npmjs.org/comment-parser cache-miss
      717 http fetch GET 200 https://registry.npmjs.org/@es-joy%2fresolve.exports 99ms (cache miss)
      718 silly fetch manifest debug@^4.4.3
      719 silly packumentCache full:https://registry.npmjs.org/debug cache-hit
      720 silly fetch manifest esquery@^1.6.0
      721 silly packumentCache full:https://registry.npmjs.org/esquery cache-miss
      722 silly fetch manifest html-entities@^2.6.0
      723 silly packumentCache full:https://registry.npmjs.org/html-entities cache-miss
      724 http fetch GET 200 https://registry.npmjs.org/stable-hash-x 244ms (cache miss)
      725 silly fetch manifest object-deep-merge@^2.0.0
      726 silly packumentCache full:https://registry.npmjs.org/object-deep-merge cache-miss
      727 silly fetch manifest parse-imports-exports@^0.2.4
      728 silly packumentCache full:https://registry.npmjs.org/parse-imports-ex
      Unfortunately, I don’t understand it.
      It would be great if you could help me!
      Thank you in advance!
      Kind regards
      Klinge
        sdetweil @Klinge
        @Klinge can you show me/send me the ~/MagicMirror/installers/upgrade.log
        I have never seen this before
        were those silly… lines from MagicMirror startup???
        • K
          Klinge @sdetweil
          upgrade.log
          Upgrade started - Tue Jan  6 14:50:54 CET 2026
          system is Linux raspi-mm-gaeste 6.6.51+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.51-1+rpt1 (2024-09-26) aarch64 GNU/Linux
          user requested to force apply changes
          doing test run = false
          the os is PRETTY_NAME="Debian GNU/Linux 12 (bookworm)" NAME="Debian GNU/Linux" VERSION_ID="12" VERSION="12 (bookworm)" VERSION_CODENAME=bookworm ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/"
          architecture from dpkg is
          Node currently installed. Checking version number.
          Minimum Node version: v22.21.1
          Installed Node version: v22.21.1
          No npm engines section specified in package.json, using default=V10.9.4 ...
          Check current Node installation ...
          No Node.js upgrade necessary.
          Check current NPM installation ...
          NPM currently installed. Checking version number.
          Minimum npm version: V10.9.4
          Installed npm version: V10.9.4
          No npm upgrade necessary.
          increasing swap space
          saving custom.css
          remote name = origin
          upgrading from version 2.34.0 to 2.34.0
          MagicMirror running under control of PM2, stopping
          [PM2] Applying action stopProcessId on app [MagicMirror](ids: [ 0 ])
          [PM2] [MagicMirror](0) ✓
          │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
          │ 0  │ MagicMirror    │ default     │ 2.34.0  │ fork    │ 0        │ 0      │ 3    │ stopped   │ 0%       │ 0b       │ kling    │ disabled │
          fetching latest revisions
          git fetch rc=0
          current branch = master
          On branch master
          Your branch is up to date with 'origin/master'.
          Changes not staged for commit:
            (use "git add <file>..." to update what will be committed)
            (use "git restore <file>..." to discard changes in working directory)
                  modified:   package-lock.json
                  modified:   package.json
          Untracked files:
            (use "git add <file>..." to include in what will be committed)
                  core
                  credentials.json
                  installers/
                  monitor_off.sh
                  monitor_on.sh
                  run-start.sh
                  splashscreen/
          no changes added to commit (use "git add" and/or "git commit -a")
          there are 2 local files that are different than the master repo
             package-lock.json
             package.json
          save/restore files selection = Y
          erasing lock files
          Saved working directory and index state WIP on master: b742e83 Release 2.34.0 (#3999)
          test merge result rc='' , if empty, no conflicts
          executing merge, apply specified
          merge result rc= 0
           Already up to date.
          processor architecture is aarch64
          updating MagicMirror runtime, please wait
          > magicmirror@2.34.0 postinstall
          > git clean -df fonts vendor
          > magicmirror@2.34.0 prepare
          > [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
          no husky installed.
          added 465 packages in 3m
          141 packages are looking for funding
            run `npm fund` for details
          npm install completed - Tue Jan  6 14:56:30 CET 2026 on base
          added 568 packages in 2m
          302 packages are looking for funding
          fixing sandbox permissions
          Checking for modules with removed libraries
          downloading dumpactivemodules script
          updating dependencies for active modules with package.json files
                  processing for module MMM-OpenWeatherMapForecast please wait
          added 1 package, and audited 2 packages in 7s
          found 0 vulnerabilities
                  processing complete for module MMM-OpenWeatherMapForecast
                  processing for module MMM-NINA please wait
          up to date, audited 1 package in 871ms
                  processing complete for module MMM-NINA
                  processing for module MMM-DWD-WarnWeather please wait
          npm warn deprecated har-validator@5.1.5: this library is no longer supported
          npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
          npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          added 51 packages, and audited 52 packages in 6s
          3 packages are looking for funding
          4 vulnerabilities (1 moderate, 1 high, 2 critical)
          Some issues need review, and may require choosing
          a different dependency.
          Run `npm audit` for details.
                  processing complete for module MMM-DWD-WarnWeather
                  processing for module MMM-PublicTransportHafas please wait
          > mmm-publictransporthafas@3.5.0 postinstall
          > simple-git-hooks
          sh: 1: simple-git-hooks: not found
          npm error code 127
          npm error path /home/kling/MagicMirror/modules/MMM-PublicTransportHafas
          npm error command failed
          npm error command sh -c simple-git-hooks
          npm error A complete log of this run can be found in: /home/kling/.npm/_logs/2026-01-06T14_04_33_120Z-debug-0.log
                  processing complete for module MMM-PublicTransportHafas
                  processing for module MMM-HomeAssistant please wait
          npm error code 1
          npm error path /home/kling/MagicMirror/modules/MMM-HomeAssistant/node_modules/puppeteer
          npm error command sh -c node install.mjs
          npm error **INFO** Skipping Firefox download as instructed.
          npm error Error: ERROR: Failed to set up chrome v143.0.7499.169! Set "PUPPETEER_SKIP_DOWNLOAD" env variable to skip download.
          npm error     at downloadBrowser (file:///home/kling/MagicMirror/modules/MMM-HomeAssistant/node_modules/puppeteer/lib/esm/puppeteer/node/install.js:26:15)
          npm error     at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
          npm error     at async Promise.all (index 0)
          npm error     at async downloadBrowsers (file:///home/kling/MagicMirror/modules/MMM-HomeAssistant/node_modules/puppeteer/lib/esm/puppeteer/node/install.js:84:9) {
          npm error   [cause]: [Error: ENOSPC: no space left on device, write] {
          npm error     errno: -28,
          npm error     code: 'ENOSPC',
          npm error     syscall: 'write'
          npm error   }
          npm error }
          npm error A complete log of this run can be found in: /home/kling/.npm/_logs/2026-01-06T14_05_05_168Z-debug-0.log
                  processing complete for module MMM-HomeAssistant
          restoring custom.css
          removing git alias
          we stashed a set of files that appear changed from the latest repo versions. you should review them
          Upgrade ended - Tue Jan  6 15:05:59 CET 2026
          when I start MM there are the following lines
          > magicmirror@2.34.0 start
          > node --run start:x11
          [2026-01-06 17:14:21.923] [LOG]   [app] Starting MagicMirror: v2.34.0
          [2026-01-06 17:14:21.932] [LOG]   [app] Loading config ...
          [2026-01-06 17:14:21.938] [LOG]   [app] config template file not exists, no envsubst
          [2026-01-06 17:14:23.129] [INFO]  [check_config] Checking config file /home/kling/MagicMirror/config/config.js ...
          [2026-01-06 17:14:23.292] [INFO]  [check_config] Your configuration file doesn't contain syntax errors :)
          [2026-01-06 17:14:23.294] [INFO]  [check_config] Checking modules structure configuration ...
          [2026-01-06 17:14:23.397] [INFO]  [check_config] Your modules structure configuration doesn't contain errors :)
          [2026-01-06 17:14:23.402] [LOG]   [app] Loading module helpers ...
          [2026-01-06 17:14:23.405] [LOG]   [app] No helper found for module: alert.
          [2026-01-06 17:14:23.422] [LOG]   [node_helper] Initializing new module helper ...
          [2026-01-06 17:14:23.424] [LOG]   [node_helper] Module helper loaded: updatenotification
          [2026-01-06 17:14:23.426] [LOG]   [app] No helper found for module: clock.
          [2026-01-06 17:14:23.473] [LOG]   [node_helper] Initializing new module helper ...
          [2026-01-06 17:14:23.474] [LOG]   [node_helper] Module helper loaded: MMM-OpenWeatherMapForecast
          [2026-01-06 17:14:23.530] [LOG]   [node_helper] Initializing new module helper ...
          [2026-01-06 17:14:23.531] [LOG]   [node_helper] Module helper loaded: MMM-NINA
          [2026-01-06 17:14:23.689] [LOG]   [node_helper] Initializing new module helper ...
          [2026-01-06 17:14:23.690] [LOG]   [node_helper] Module helper loaded: MMM-DWD-WarnWeather
          [2026-01-06 17:14:23.765] [LOG]   [node_helper] Initializing new module helper ...
          [2026-01-06 17:14:23.765] [LOG]   [node_helper] Module helper loaded: MMM-PublicTransportHafas
          [2026-01-06 17:14:23.770] [LOG]   [node_helper] Initializing new module helper ...
          [2026-01-06 17:14:23.770] [LOG]   [node_helper] Module helper loaded: MMM-Universal-Pir
          [2026-01-06 17:14:23.772] [LOG]   [app] No helper found for module: compliments.
          [2026-01-06 17:14:23.782] [LOG]   [app] No helper found for module: MMM-WiFiPassword.
          [2026-01-06 17:14:23.789] [ERROR] [app] Error when loading MMM-HomeAssistant: Cannot find module 'mqtt'
          Require stack:
          - /home/kling/MagicMirror/modules/MMM-HomeAssistant/node_helper.js
          - /home/kling/MagicMirror/js/app.js
          - /home/kling/MagicMirror/js/electron.js
          [2026-01-06 17:14:23.790] [LOG]   [app] All module helpers loaded.
          [2026-01-06 17:14:23.799] [LOG]   [server] Starting server on port 8080 ...
          [2026-01-06 17:14:23.803] [WARN]  [server] You're using a full whitelist configuration to allow for all IPs
          [2026-01-06 17:14:23.846] [LOG]   [app] Server started ...
          [2026-01-06 17:14:23.848] [LOG]   [node_helper] Connecting socket for: updatenotification
          [2026-01-06 17:14:23.849] [LOG]   [node_helper] Starting module helper: updatenotification
          [2026-01-06 17:14:23.850] [LOG]   [node_helper] Connecting socket for: MMM-OpenWeatherMapForecast
          [2026-01-06 17:14:23.850] [LOG]   [MMM-OpenWeatherMapForecast] Starting node_helper for MMM-OpenWeatherMapForecast
          [2026-01-06 17:14:23.851] [LOG]   [node_helper] Connecting socket for: MMM-NINA
          [2026-01-06 17:14:23.852] [LOG]   [MMM-NINA] MMM-NINA helper method started...
          [2026-01-06 17:14:23.853] [LOG]   [node_helper] Connecting socket for: MMM-DWD-WarnWeather
          [2026-01-06 17:14:23.854] [LOG]   [MMM-DWD-WarnWeather] MMM-DWD-WarnWeather helper started...
          [2026-01-06 17:14:23.855] [LOG]   [node_helper] Connecting socket for: MMM-PublicTransportHafas
          [2026-01-06 17:14:23.856] [LOG]   [node_helper] Connecting socket for: MMM-Universal-Pir
          [2026-01-06 17:14:23.857] [LOG]   [app] Sockets connected & modules started ...
          [2026-01-06 17:14:25.346] [LOG]   [electron] Launching application.
          [2026-01-06 17:14:31.850] [INFO]  [utils]
          ####  System Information  ####
          - SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false; MM: 2.34.0
          - OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
          - VERSIONS: electron: 39.2.7; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
          - ENV:      XDG_SESSION_TYPE: tty; MM_CONFIG_FILE: undefined
                      WAYLAND_DISPLAY:  undefined; DISPLAY: :0; ELECTRON_ENABLE_GPU: undefined
          - RAM:      total: 7809.97 MB; free: 7005.31 MB; used: 804.66 MB
          - OTHERS:   uptime: 11 minutes; timeZone: Europe/Berlin
            sdetweil @Klinge
            @Klinge said in Problem after update Master branch:
            your disk is full
            • K
              Klinge @sdetweil
              @sdetweil Oh no! So simple. How embarrassing. Sorry!
              I’m just wondering what’s filling up the card. But I’ll figure that out.
              Thank you for your help!
              • K
                Klinge @Klinge
                I’m sorry, but I need some more help with this issue.
                I can’t find the files that are filling up my SD card’s memory.
                When I search for used storage space, I get the following result:
                sudo du -hsx * | sort -rh | head -10
                6.4G    home
                5.5G    usr
                1.3G    var
                105M    boot
                16M     root
                10M     opt
                7.2M    etc
                1.9M    tmp
                1.3M    run
                16K     lost+found
                If I now run the same search in the /home directory
                6.4G    kling
                I display the folder contents …/kling
                ls -laSr
                -rw-r--r--  1 kling kling      0 Jul  4  2024 .sudo_as_admin_successful
                -rwxr-xr-x  1 root  root      14 Oct  1  2024 pir.sh
                -rw-------  1 kling kling     20 Jan  6 17:11 .lesshst
                -rwxr-xr-x  1 kling kling     37 Oct  1  2024 monitor_on.sh
                -rwxr-xr-x  1 root  root      37 Oct  1  2024 monitor_on_root.sh
                -rwxr-xr-x  1 kling kling     37 Oct  1  2024 monitor_off.sh
                -rwxr-xr-x  1 root  root      37 Oct  1  2024 monitor_off_root.sh
                -rw-r--r--  1 kling kling     58 Jan  3 09:07 .gitconfig
                -rw-------  1 kling kling     60 Jan 13 22:03 .Xauthority
                -rw-r--r--  1 kling kling    220 Jul  4  2024 .bash_logout
                -rw-r--r--  1 root  root     351 Oct  1  2024 test.py
                -rw-r--r--  1 kling kling    807 Jul  4  2024 .profile
                -rwxr-xr-x  1 root  root    1007 Oct  1  2024 pir.py
                -rw-r--r--  1 kling kling   3523 Jul  4  2024 .bashrc
                drwxr-xr-x  2 kling kling   4096 Jul  4  2024 Videos
                drwxr-xr-x  2 kling kling   4096 Jul  4  2024 Templates
                drwxr-xr-x  2 kling kling   4096 Jul  4  2024 Public
                drwxr-xr-x  5 kling kling   4096 Jan 13 22:03 .pm2
                drwx------  3 kling kling   4096 Oct  1  2024 .pki
                drwxr-xr-x  2 kling kling   4096 Jul  4  2024 Pictures
                drwxr-xr-x  4 kling kling   4096 Oct  1  2024 .npm
                drwxr-xr-x  2 kling kling   4096 Jul  4  2024 Music
                drwx------  4 kling kling   4096 Oct  1  2024 .mozilla
                drwxr-xr-x 16 kling kling   4096 Jan 14 09:11 MagicMirror
                drwxr-xr-x  4 kling kling   4096 Jul  4  2024 .local
                drwxr-xr-x  3 kling kling   4096 Oct  1  2024 .electron-gyp
                drwxr-xr-x  2 kling kling   4096 Oct 31  2024 Downloads
                drwxr-xr-x  2 kling kling   4096 Jul  4  2024 Documents
                drwxr-xr-x  2 kling kling   4096 Feb 13  2025 Desktop
                drwx------ 10 kling kling   4096 Feb 19  2025 .config
                drwx------ 11 kling kling   4096 Jun 27  2025 .cache
                drwxr-xr-x  2 kling kling   4096 Jul  4  2024 Bookshelf
                drwxr-xr-x  3 root  root    4096 Jul  4  2024 ..
                drwx------ 20 kling kling   4096 Jan 14 09:03 .
                -rw-------  1 kling kling  10446 Jan 13 20:56 .bash_history
                -rw-------  1 kling kling  24785 Jan 14 09:11 .xsession-errors
                -rw-------  1 kling kling  82704 Jan 13 22:03 .xsession-errors.old
                -rw-r--r--  1 kling kling 243765 Jan  6 15:25 install.log
                and when I search here again to find the 6.4 GB, I get the following result
                1.4G    MagicMirror
                55M     Bookshelf
                244K    install.log
                108K    Downloads
                8.0K    Desktop
                4.0K    Videos
                4.0K    test.py
                4.0K    Templates
                4.0K    Public
                4.0K    pir.sh
                With these results, I don’t know where the 6.4 GB is being used.
                What am I doing wrong?
                Thank you in advance.
                • BKeyportB
                  BKeyport Module Developer @Klinge
                  @Klinge You either have some logs that have exploded in size, or a corrupting SD card. Either way, I’d recommend a reformat and/or a new SD card.
                    sdetweil @BKeyport
                    @BKeyport I agree. Weird results multiple times New sd card time
                    Use my backup/restore to save (backup) your MagicMirror config
                    And after install, use restore to put it back
                    • K
                      Klinge @sdetweil
                      ok, thank you for you advice. I will use a new card .
                      • K Klinge has marked this topic as solved on
