    Line breaks in Compliments using MMM-Remote-Control
    9 Posts 3 Posters 1.8k Views 3 Watching
      alfi153
      Hi everyone,
      I have a question regarding the combination of the default compliments module and MMM-Remote-Control.
      I am using the web interface of Remote-Control to set the module compliments. Some of my texts are a bit longer and I would like to split them into two lines for better visibility.
      I tried using \n within the text string to force a line break, but unfortunately, it doesn’t work (it is just ignored or displayed as text).
      Is there a specific syntax or a workaround to force a line break when sending updates via the Remote-Control interface?
      Thanks for your help!
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @alfi153
        @alfi153 I did’t test it, but have you tried <br> ?
        S 1 Reply Last reply Reply Quote -1
          sdetweil @KristjanESPERANTO
          @KristjanESPERANTO the module splits the line with ‘\n’ into its parts. Is RC converting that text to 0x0a
            alfi153
            Hello
            I tested ´⁄n´and
            nothing worked
              sdetweil @alfi153
              @alfi153 not right leaning slash, left leaning, like this
              “Now is the time\nto come to the aid of your country”
                alfi153 @sdetweil
                @sdetweil I tryed Both. Nothing worked
                  sdetweil @alfi153
                  @alfi153 can you make up some text and show me with \n
                  You gave to
                  Use the " double quotes on the strings, not single
                    alfi153 @sdetweil
                    @sdetweil Hi there. I’m entering the comments via the ‘Remote control’ module in the web interface. I’m wondering if it’s simply not supported through that specific module. I’ve already tried every possible variation, but unfortunately, I can’t get it to work.
                      sdetweil @alfi153
                      @alfi153 if you add one via the config.js does it work?
                      I am traveling today, cannot test til I setup my system
                      As a side request. Can you explain what with remote control means?
                      I don’t see any notifications that compliments accepts to change the data. Only a remote file is supported with a refresh time.
                      And I don’t see any mention of compliments in the remote control
                      Module doc
                      Ps I wrote the code for line break with \n and the remote file function in the compliments module
