    MMM-Globe: Meteosat imagery broken — fork with fix available
    Scheduled Pinned Locked Moved Showcase
    12 Posts 5 Posters 5.1k Views 6 Watching
      rkorell Module Developer
      Dear community,
      just a heads-up for those of you using MMM-Globe with the europeDiscNat or europeDiscSnow
      style — you’ve probably noticed that the satellite image has been stuck since around
      February 22. Turns out EUMETSAT has pulled the plug on their old static image server at
      eumetview.eumetsat.int. They moved to a shiny new platform at view.eumetsat.int, but
      unfortunately it’s a JavaScript app now — no more simple image URLs we can point a module
      at.
      I’ve also opened an issue on the original repo for reference:
      https://github.com/LukeSkywalker92/MMM-Globe/issues/22
      I realize this probably flew under the radar for most of you — if your globe is pointed at
      the Americas or Asia, everything’s fine. But for the small but proud club of European globe
      watchers, it’s been a rough week staring at the same cloud pattern wondering if the weather
      had simply stopped.
      Since the original MMM-Globe hasn’t seen any updates in a while, I went ahead and created a
      fork that adds a new “meteosat” style. It pulls Meteosat full-disk imagery from the CIRA
      SLIDER service (run by NOAA/RAMMB at Colorado State University). The GeoColor product looks
      really nice on the mirror — natural color during the day, and city lights on a Blue Marble
      background at night. I think you’ll like it!
      Big thanks to Luke Scheffler (@lukecodewalker) for creating MMM-Globe in
      the first place — his idea of turning satellite images into a globe with a simple CSS circle
      clip is just brilliant. This fork builds on his work.
      If you want to give it a try:
      cd ~/MagicMirror/modules
      rm -rf MMM-Globe
      git clone https://github.com/rkorell/MMM-Globe.git
      Then change your config to:
      module: “MMM-Globe”,
      position: “lower_third”,
      style: “meteosat”,
      imageSize: 600,
      updateInterval: 15 * 60 * 1000
      The fork also fixes an annoying startup issue where the globe would stay blank after a
      reboot if the network wasn’t ready yet — something that probably bugged a few of us running
      this on a Raspberry Pi.
      All the details, available styles and config options are in the README:
      Happy mirroring! 🪞
      plainbrokeP G R M 5 Replies Last reply Reply Quote 5
      • plainbrokeP Offline
        plainbroke @rkorell
        @rkorell
        If I install your fork and use the style: “meteosat”,
        Will that work in the USA ? I like the prettier styling…
        R 2 Replies Last reply Reply Quote 0
          rkorell Module Developer @plainbroke
          @plainbroke :-) It will work in US but you will see the wrong half of the globe …
          To be serious: No, you requirement is for sure to see USA side of the globe - so it will not work for you - wrong satellite.
          Warmest regards,
          Ralf
          • E Offline
            eddiebrok
            Thanks for the update and the clear explanation, that broken image issue has been frustrating for a lot of users. The fork with the new meteosat style and the fix for the blank startup problem sounds like a solid replacement, especially with the improved imagery source. Appreciate you sharing the install steps and config example, it makes testing the fix much easier for everyone.
            • G Offline
              Gabian 0 @rkorell
              @rkorell Thanks a lot, I’ll try that this week ! Greetings
                rkorell Module Developer @rkorell
                Today added a minor fix: Globe disappeared when browser-refresh is performed…
                  Dear @plainbroke ,
                  well, I owe you an apology — and a thank you!
                  When you asked, I answered “wrong satellite” and moved on. Technically correct, but I completely missed the obvious next question: “So… can we get the
                  RIGHT satellite?”
                  Turns out, we can. The CIRA SLIDER service that provides the beautiful Meteosat GeoColor imagery (with the night city lights) serves four geostationary
                  satellites — and one of them is GOES-19, parked right over the Americas at 75.2°W. Same API, same image quality, same stunning day/night visualization.
                  I just never looked.
                  Your question made me look. So as of v3.1.0, MMM-Globe now supports:
                  │      Style      │     Satellite      │           View            │
                  │ geoColorEurope  │ Meteosat (0°)      │ Europe / Africa           │
                  │ geoColorUSA     │ GOES-19 (75.2°W)   │ Americas ← this is yours! │
                  │ geoColorPacific │ GOES-18 (137.0°W)  │ Pacific                   │
                  │ geoColorAsia    │ Himawari (140.7°E) │ Asia / Australia          │
                  Just set style: “geoColorUSA” and you’re good to go. Same auto-polling every 60 seconds, same beautiful globe, just the right half of the planet this
                  time. 😊
                  So thank you for what I should have recognized as a feature request instead of a geography lesson. Sometimes the best contributions come disguised as
                  simple questions.
                  Warmest regards,
                  Ralf
                  plainbrokeP 1 Reply Last reply Reply Quote 4
                    plainbroke @rkorell
                    @rkorell
                    Thank you for the update…
                      @plainbroke you’re really welcome.
                      Thanks for your patience :-)
                      Ralf
                        manu85340 @rkorell
                        @rkorell Bravo c’est super
                          rkorell Module Developer @manu85340
                          @manu85340 :-) Thank You!
                          Glad, if it works for you!
                          Ralf
                            Good afternoon, all!
                            europeDiscNat is back! (plus a small CSS fix for a new white footer)
                            for you, guys a quick update on the European satellite image situation.
                            Since my fork EUMETSAT’s new WMS endpoint at view.eumetsat.int/geoserver/wms works fast, reliably and nice.
                            Yesterday that stopped delivering fresh images!
                            Today I figured out there even is a new version (small changes in URL) v1.1.0 is now v1.3.0 API - but both of them are only returning a stale image from yesterday evening:
                            https://view.eumetsat.int/geoserver/wms?service=WMS&version=1.1.0&request=GetMap&layers=msg_fes:rgb_naturalenhncd&...
                            https://view.eumetsat.int/geoserver/wms?service=WMS&version=1.3.0&request=GetMap&layers=msg_fes:rgb_naturalenhncd&...
                            But here’s the surprise: the old europeDiscNat URL is back and working again!
                            So if you’ve been in trouble with looking for actual pictures without the SLIDER API, this works right now:
                            style: 'europeDiscNat',
                            is re-born …
                            One thing to watch out for: Unfortunately EUMETSAT has changed the image format slightly. The footer bar at the bottom (logo + timestamp) used to be black — invisible against the MagicMirror background. It’s now white and a bit taller, which causes a small white artifact at the bottom of the globe.
                            I’ve pushed a fix that adds a black CSS overlay to mask the footer. Just update the module:
                            cd ~/MagicMirror/modules/MMM-Globe
                            git pull
                            npm install
                            Of course the SLIDER styles (geoColorEurope, geoColorUSA, etc.) continue to work fine if you prefer those.
                            Happy mirroring!
                            Warmest regards,
                            Ralf
