    MMM-CalendarExt2 - I want to change the first day of the week, but weekStart setting is not having an effect
    5 Posts 2 Posters 461 Views 3 Watching
    • eprostkoE
      eprostko
      For the last few weeks, my calendar weeks have been starting on Monday, rather than Sunday (I’m in the US). It used to show Sun-Sat, but now it’s Mon-Sun.
      I found the weekStart: 0 setting, but it’s not having any effect.
      I set the locale: en-US.
      I tried setting the mode: “week” and type: “row” and weekStart: 0 or 3 or 5 just to see what it would do, and it had no effect.
      I set type: “weekly” and it did change the first day to Sunday, each week was a column, not a row.
      The blocks from my config are below. Can anyone help?
      module: ‘MMM-CalendarExt2’,
      locale: “en-US”,
      weekStart: 0,
      Under views, here’s what I have
      views: [
      position: “top_bar”,
      mode: “week”,
      type: “row”,
      slotMaxHeight: “150px”,
      slotCount: 3,
      hideOverflow: false,
      slotTitle: “”,
      slotTitleFormat: “dddd, M/D”,
      timeFormat: “h:mm”,
      slotSubTitle: " ",
      modeOptions: {
      weekStart: 0, // Sunday-first
      KristjanESPERANTOK 2 Replies Last reply
      • KristjanESPERANTOK
        KristjanESPERANTO Module Developer @eprostko
        @eprostko The issue is that modeOptions is not a valid configuration field in MMM-CalenderExt2. Where did you get that?
        weekStart needs to be set directly inside the view object:
        views: [
            position: "top_bar",
            mode: "week",
            type: "row",
            weekStart: 0,        // ← here, at the top level of the view
            slotMaxHeight: "150px",
            slotCount: 3,
        The top-level weekStart: 0 in your config has no effect either - there’s no such top-level option, only the per-view (or defaultSet.view) one.
        Reply Quote 1
          @eprostko And it would be great if you could format your code snippets a bit more clearly in the future like proper indentation and quotation marks. The way you wrote the config part is really hard to read and analyze 🙂
          eprostkoE 1 Reply Last reply
          Reply Quote 1
          • eprostkoE
            eprostko @KristjanESPERANTO
            @KristjanESPERANTO Thank you so much! That worked. I thought I tried it that way in one of my many attempts, but clearly I didn’t.
            Where did that modeOptions thing come from? ChatGPT. It gave me quite a few wrong answers. Some days I have great luck with it and other days I do not.
            And I will be sure to format my config the next time I need some help. Thanks for pointing that out.
            Again, thanks for the help, and have a wonderful day!
            KristjanESPERANTOK 1 Reply Last reply
            Reply Quote 1
              @eprostko I’m glad it’s working. The configuration of MMM-CalendarExt2 and the documentation are quite complex, so I completely understand if you’re having a hard time with it.
              Have fun with your project 😃
