    v2.35.0
    Scheduled Pinned Locked Moved MagicMirror
    1 Posts 1 Posters 494 Views 1 Watching
    • karsten13K Offline
      karsten13
      Release Notes
      Thanks to: @angeldeejay, @in-voker, @JHWelch, @khassel, @KristjanESPERANTO, @rejas, @sdetweil
      ⚠️ This release needs nodejs version >=22.21.1 <23 || >=24 (no change to previous release)
      Compare to previous Release v2.34.0
      ⚠️ We introduced some internal changes with this release, please read this forum post before upgrading!
      [core]
      • Prepare Release 2.35.0 (#4071)
      • docs: add security policy and vulnerability reporting guidelines (#4069)
      • refactor: simplify internal require() calls (#4056)
      • allow environment variables in cors urls (#4033)
      • fix cors proxy getting binary data (e.g. png, webp) (#4030)
      • fix: correct secret redaction and optimize loadConfig (#4031)
      • change loading config.js, allow variables in config.js and try to protect sensitive data (#4029)
      • remove kioskmode (#4027)
      • Add dark theme logo (#4026)
      • move custom.css from css to config (#4020)
      • move default modules from /modules/default to /defaultmodules (#4019)
      • update node versions in workflows (#4018)
      • [core] refactor: extract and centralize HTTP fetcher (#4016)
      • fix systeminformation not displaying electron version (#4012)
      • Update node-ical and support it’s rrule-temporal changes (#4010)
      • Change default start scripts from X11 to Wayland (#4011)
      • refactor: unify favicon for index.html and Electron (#4006)
      • [core] run systeminformation in subprocess so the info is always displayed (#4002)
      • set next release dev number (#4000)
      [dependencies]
      • update dependencies (#4068)
      • update dependencies incl. electron to v41 (#4058)
      • chore: upgrade ESLint to v10 and fix newly surfaced issues (#4057)
      • chore: update ESLint and plugins, simplify config, apply new rules (#4052)
      • chore: update dependencies + add exports, files, and sideEffects fields to package.json (#4040)
      • [core] refactor: enable ESLint rule require-await and handle detected issues (#4038)
      • Update node-ical and other deps (#4025)
      • chore: update dependencies (#4021)
      • chore(eslint): migrate from eslint-plugin-vitest to @vitest/eslint-plugin and run rules only on test files (#4014)
      • Update deps as requested by dependabot (#4008)
      • update Collaboration.md and dependencies (#4001)
      [logging]
      • refactor: further logger clean-up (#4050)
      • Fix Node.js v25 logging prefix and modernize logger (#4049)
      [modules/calendar]
      • fix(calendar): make showEnd behavior more consistent across time formats (#4059)
      • test(calendar): fix hardcoded date in event shape test (#4055)
      • [calendar] refactor: delegate event expansion to node-ical’s expandRecurringEvent (#4047)
      • calendar.js: remove useless hasCalendarURL function (#4028)
      • fix(calendar): update to node-ical 0.23.1 and fix full-day recurrence lookup (#4013)
      • fix(calendar): correct day-of-week for full-day recurring events across all timezones (#4004)
      [modules/newsfeed]
      • fix(newsfeed): fix full article view and add framing check (#4039)
      • [newsfeed] refactor: migrate to centralized HTTPFetcher (#4023)
      [modules/weather]
      • fix(weather): fix openmeteo forecast stuck in the past (#4064)
      • fix(weather): fix weathergov forecast day labels off by one (#4065)
      • weather: fixes for templates (#4054)
      • weather: add possibility to override njk’s and css (#4051)
      • Use getDateString in openmeteo (#4046)
      • [weather] refactor: migrate to server-side providers with centralized HTTPFetcher (#4032)
      • [weather] feat: add Weather API Provider (#4036)
      [testing]
      • chore: remove obsolete Jest config and unit test global setup (#4044)
      • replace template_spec test with config_variables test (#4034)
      • refactor(clientonly): modernize code structure and add comprehensive tests (#4022)
      • Switch to undici Agent for HTTPS requests (#4015)
      • chore: migrate CI workflows to ubuntu-slim for faster startup times (#4007)
      see https://github.com/MagicMirrorOrg/MagicMirror/releases/tag/v2.35.0
      1 Reply Last reply Reply Quote 4
      • karsten13K karsten13 locked this topic on
