    Default Calendar Not Loading Events After New MM Update
    69 Posts 8 Posters 21.0k Views 8 Watching
    • A
      angeliKITTYx @sdetweil
      kittypi@KITTYpi:~ $ cd ~/MagicMirror
      rm package-lock.json
      rm -rf node_modules
      npm run install-mm
      rm: cannot remove 'package-lock.json': No such file or directory
      > magicmirror@2.35.0 install-mm
      > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
      > magicmirror@2.35.0 postinstall
      > git clean -df fonts vendor modules/default
      > magicmirror@2.35.0 prepare
      > [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
      no husky installed.
      added 389 packages in 6m
      kittypi@KITTYpi:~/MagicMirror $
        sdetweil @angeliKITTYx
        @angeliKITTYx ok, now start MagicMirror
        A 1 Reply Last reply
        • A
          it’s booted again and no update notifs (:
          …but none of my calendar events are populating. this morning, it took about 20m and they eventually showed up. I’ve had it open for about 10m already and don’t see anything. I’ll keep an eye on it.
          update - I backed out and saw that I got all of these errors still…
          ssignment -July 4th [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
          [2026-04-29 21:45:07.831] [ERROR] [calendar] Could not expand event "Introductory Speech Written Submission [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
          [2026-04-29 21:45:07.832] [ERROR] [calendar] Could not expand event "PHI 100 Quiz 4": ical.expandRecurringEvent is not a function
          [2026-04-29 21:45:07.833] [ERROR] [calendar] Could not expand event "Persuasive Ad Analysis  [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
          [2026-04-29 21:45:07.834] [ERROR] [calendar] Could not expand event "Discussion 1  [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
          [2026-04-29 21:45:07.834] [ERROR] [calendar] Could not expand event "Final Discussion  [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
          [2026-04-29 21:45:07.835] [ERROR] [calendar] Could not expand event "Introductory Speech Video (Recorded Audio and Video)  [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
          [2026-04-29 21:45:07.836] [ERROR] [calendar] Could not expand event "Submit Persuasive Speech [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
          [2026-04-29 21:45:07.837] [ERROR] [calendar] Could not expand event "PHI 100 QUIZ 2": ical.expandRecurringEvent is not a function
          [2026-04-29 21:45:07.838] [ERROR] [calendar] Could not expand event "Homework [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
          [2026-04-29 21:45:07.839] [ERROR] [calendar] Could not expand event "My Listening Skills [TC295.CST.100.O01N.SU24.7W1]": ical.expandRecurringEvent is not a function
          [2026-04-29 21:45:07.840] [ERROR] [calendar] Could not expand event "PHI 100 Discussion": ical.expandRecurringEvent is not a function
          [2026-04-29 21:45:07.841] [INFO]  [calendar] Broadcasting 0 events from https://calendar.google.com/calendar/ical/2adcc5394a749909a5fbe4e93d3673b2e0ff6fd91551d1977ecc7dfb84dde87a%40group.calendar.google.com/private-b562d8f04caac264bc19d634d4bfcee0/basic.ics.
          [2026-04-29 21:45:09.852] [LOG]   [electron] Shutting down server...
          [2026-04-29 21:45:09.853] [LOG]   [node_helper] Stopping module helper: updatenotification
          [2026-04-29 21:45:09.854] [LOG]   [node_helper] Stopping module helper: calendar
          [2026-04-29 21:45:09.854] [LOG]   [node_helper] Stopping module helper: MMM-CalendarExt3
          [2026-04-29 21:45:09.855] [LOG]   [node_helper] Stopping module helper: MMM-Jokes
          [2026-04-29 21:45:09.855] [LOG]   [node_helper] Stopping module helper: weather
          [2026-04-29 21:45:09.855] [LOG]   [node_helper] Stopping module helper: MMM-Todoist2
          [2026-04-29 21:45:09.856] [LOG]   [app] Node_helpers stopped ...
          S KristjanESPERANTOK 2 Replies Last reply
            @angeliKITTYx thanks
            @kristjanesperanto what do you think of this?
            We’ve made sure to erase node_modules and start fresh
            KristjanESPERANTOK S 2 Replies Last reply
            Reply Quote 1
            • KristjanESPERANTOK
              KristjanESPERANTO Module Developer @sdetweil
              Hmm… I didn’t expect something like that in the current release. But I won’t be able to take a closer look at it right away. It would be interesting to see if this also happens in the develop branch.
                KristjanESPERANTO Module Developer @angeliKITTYx
                @angeliKITTYx This shouldn’t happen with the just released new version v2.36.0. I recommend to update :)
                  Upgrade , use my script
                  • A
                    @sdetweil @kristjanesperanto we are up and running!! even fixed the issue of one of my calendars loading slowly (: thank you both so so so much!
                    Reply Quote 2
                      @angeliKITTYx awesome. Thanks for the feedback
                      • K kkmirr04 referenced this topic on
                      • 4 / 4
