    multiple error in magic mirror after update from 2.28.0 to 2.36.0
    71 Posts 2 Posters 66 Views 2 Watching
      sdetweil @1a2a3a
      @1a2a3a said:
      0|MagicMir | /home/hsa/MagicMirror/installers/mm.sh: line 2: $‘\r’: command not found
      0|MagicMir | /home/hsa/MagicMirror/installers/mm.sh: line 3: cd: $‘/home/hsa/MagicMirror\r’: No such file or directory
      are you on windows??
      it added a carriage return to lines 2 and 3… please remove… the script failed, and pm2s JOB is to keep it running
      pm2 status will show you the restart count
      | id │ name                │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
      │ 8  │ MagicMirror         │ default     │ 2.32.0… │ fork    │ N/A      │ 0      │ 245… │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
      the circle arrow next to uptime, is number of restarts
      1 1 Reply Last reply Reply Quote 0
        sdetweil @1a2a3a
        @1a2a3a
        API is deprecated. Please use Array.isArray() instead.
        same as punycode
        up to the module author
        • 1 Offline
          1a2a3a @sdetweil
          @sdetweil im on rpi5, ssh from a windows. where do i remove the lines?
            sdetweil @1a2a3a
            @1a2a3a in some editor… you might see them in nano
            cd ~/MagicMirror/installers
            nano mm.sh
            use arrow keys to move around, delete to remove, ins to be able to insert
            when done
            ctrl-o
            to save
            ctrl-x to exit
            if you don’t want to save
            ctrl-x and reply n
            • 1 Offline
              1a2a3a @sdetweil
              @sdetweil i dont see the lines in mm.sh…
                sdetweil @1a2a3a
                @1a2a3a
                cat mm.sh
                • 1 Offline
                  1a2a3a @sdetweil
                  hsa@HSA:~/MagicMirror/installers $ cat mm.sh
                  #!/bin/bash
                  cd ~/MagicMirror
                  DISPLAY=:0 npm run start:x11
                    sdetweil @1a2a3a
                    @1a2a3a ok, thats not my mm.sh which you supposedly saved
                    but
                    nano mm.sh
                    remove the blank line 2
                    and go to the end of new line 2 and if the cursor is not after the last character, hit backspace,
                    then ctrl-o to save
                    and ctrl-x to exit nano
                    • 1 Offline
                      1a2a3a @sdetweil
                      @sdetweil edited to your mm.sh but same result
                      #!/bin/bash
                      cd ~/MagicMirror
                      if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
                         # if WAYLAND_DISPLAYis set, use it, else set to -0
                         export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                         npm run start:wayland
                      else
                      fi
                        sdetweil @1a2a3a
                        @1a2a3a are you sure this is the script listed in pm2 info output?
                        • 1 Offline
                          1a2a3a @sdetweil
                          status │ errored │
                          │ name │ MagicMirror │
                          │ namespace │ default │
                          │ version │ 2.36.0 │
                          │ restarts │ 45 │
                          │ uptime │ 0 │
                          │ script path │ /home/hsa/MagicMirror/installers/mm.sh │
                          │ script args │ N/A │
                          │ error log path │ /home/hsa/.pm2/logs/MagicMirror-error.log │
                          │ out log path │ /home/hsa/.pm2/logs/MagicMirror-out.log │
                          │ pid path │ /home/hsa/.pm2/pids/MagicMirror-0.pid │
                          │ interpreter │ bash │
                          │ interpreter args │ N/A │
                          │ script id │ 0 │
                          │ exec cwd │ /home/hsa/MagicMirror │
                          │ exec mode │ fork_mode │
                          │ node.js version │ N/A │
                          │ node env │ N/A │
                          │ watch & reload │ ✘ │
                          │ unstable restarts │ 0 │
                          │ created at │ N/A
                            sdetweil @1a2a3a
                            weird… do this
                            curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/refs/heads/master/mm.sh >mm.sh
                            then do the
                            pm2 stop all
                            pm2 start MagicMirror
                            • 1 Offline
                              1a2a3a @sdetweil
                              done, but mirror no response or whatsoever
                              hsa@HSA:~ $ cd ~/MagicMirror/installers
                              hsa@HSA:~/MagicMirror/installers $ curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/refs/heads/master/mm.sh >mm.sh
                              hsa@HSA:~/MagicMirror/installers $ pm2 stop all
                              (node:10682) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
                              (Use `node --trace-deprecation ...` to show where the warning was created)
                              [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                              [PM2] [all](0) ✓
                              │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                              │ 0  │ MagicMirror        │ fork     │ 45   │ stopped   │ 0%       │ 0b       │
                              hsa@HSA:~/MagicMirror/installers $ pm2 start MagicMirror
                              (node:10691) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
                              [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                              [PM2] [MagicMirror](0) ✓
                              [PM2] Process successfully started
                              │ 0  │ MagicMirror        │ fork     │ 45   │ online    │ 0%       │ 2.7mb    │
                                sdetweil @1a2a3a
                                @1a2a3a and MM is up or not?
                                pm2 status
                                has the cycle count changed?
                                • 1 Offline
                                  1a2a3a @sdetweil
                                  @sdetweil mm is not up
                                  hsa@HSA:~ $ pm2 status
                                  │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                                  │ 0  │ MagicMirror    │ default     │ 2.36.0  │ fork    │ 12206    │ 15s    │ 49   │ online    │ 0%       │ 2.6mb    │ hsa      │ disabled │
                                  hsa@HSA:~ $
                                    sdetweil @1a2a3a
                                    @1a2a3a
                                    pm2 stop all
                                    cd ~/MagicMirror
                                    installers/mm.sh
                                    • 1 Offline
                                      1a2a3a @sdetweil
                                      @sdetweil did not manage to open MM
                                      > magicmirror@2.36.0 start:wayland
                                      > WAYLAND_DISPLAY="${WAYLAND_DISPLAY:=wayland-1}" ./node_modules/.bin/electron js/electron.js --ozone-platform=wayland
                                      [2026-05-02 02:39:50.838] [LOG]   [app] Starting MagicMirror: v2.36.0
                                      [2026-05-02 02:39:50.845] [LOG]   [utils] Loading config ...
                                      [2026-05-02 02:39:51.547] [INFO]  [systeminformation]
                                      ####  System Information  ####
                                      - SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 5 Model B Rev 1.0; virtual: false; MM: v2.36.0
                                      - OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.75+rpt-rpi-2712
                                      - VERSIONS: electron: 41.3.0; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
                                      - ENV:      XDG_SESSION_TYPE: tty; MM_CONFIG_FILE: undefined
                                                  WAYLAND_DISPLAY:  wayland-0; DISPLAY: undefined; ELECTRON_ENABLE_GPU: undefined
                                      - RAM:      total: 8059.06 MB; free: 6932.14 MB; used: 1126.92 MB
                                      - OTHERS:   uptime: 65 minutes; timeZone: Asia/Singapore
                                      [2026-05-02 02:40:04.644] [INFO]  [utils] Checking config file /home/hsa/MagicMirror/config/config.js ...
                                      [2026-05-02 02:40:04.720] [INFO]  [utils] Your configuration file doesn't contain syntax errors :)
                                      [2026-05-02 02:40:04.721] [INFO]  [utils] Checking modules structure configuration ...
                                      [2026-05-02 02:40:04.787] [INFO]  [utils] Your modules structure configuration doesn't contain errors :)
                                      [2026-05-02 02:40:04.788] [LOG]   [app] Loading module helpers ...
                                      [2026-05-02 02:40:04.788] [LOG]   [app] No helper found for module: alert.
                                      [2026-05-02 02:40:04.790] [LOG]   [node_helper] Initializing new module helper ...
                                      [2026-05-02 02:40:04.791] [LOG]   [node_helper] Module helper loaded: updatenotification
                                      [2026-05-02 02:40:04.791] [LOG]   [app] No helper found for module: clock.
                                      [2026-05-02 02:40:04.891] [LOG]   [node_helper] Initializing new module helper ...
                                      [2026-05-02 02:40:04.891] [LOG]   [node_helper] Module helper loaded: MMM-Jast
                                      [2026-05-02 02:40:05.554] [LOG]   [node_helper] Initializing new module helper ...
                                      [2026-05-02 02:40:05.555] [LOG]   [node_helper] Module helper loaded: MMM-GoogleDocs-Notes
                                      [2026-05-02 02:40:05.580] [LOG]   [node_helper] Initializing new module helper ...
                                      [2026-05-02 02:40:05.580] [LOG]   [node_helper] Module helper loaded: newsfeed
                                      [2026-05-02 02:40:05.586] [LOG]   [node_helper] Initializing new module helper ...
                                      [2026-05-02 02:40:05.586] [LOG]   [app] Check MagicMirror² version for node helper 'MMM-NewsAPI' - Minimum version: 2.21.0 - Current version: 2.36.0
                                      [2026-05-02 02:40:05.587] [LOG]   [app] Version is ok!
                                      [2026-05-02 02:40:05.587] [LOG]   [node_helper] Module helper loaded: MMM-NewsAPI
                                      [2026-05-02 02:40:05.588] [LOG]   [node_helper] Initializing new module helper ...
                                      [2026-05-02 02:40:05.588] [LOG]   [node_helper] Module helper loaded: MMM-MyScoreboard
                                      [2026-05-02 02:40:05.595] [LOG]   [node_helper] Initializing new module helper ...
                                      [2026-05-02 02:40:05.595] [LOG]   [app] Check MagicMirror² version for node helper 'MMM-SoccerLiveScore' - Minimum version: 2.1.0 - Current version: 2.36.0
                                      [2026-05-02 02:40:05.595] [LOG]   [app] Version is ok!
                                      [2026-05-02 02:40:05.595] [LOG]   [node_helper] Module helper loaded: MMM-SoccerLiveScore
                                      [2026-05-02 02:40:05.688] [LOG]   [node_helper] Initializing new module helper ...
                                      [2026-05-02 02:40:05.688] [LOG]   [node_helper] Module helper loaded: MMM-OneDrive
                                      [2026-05-02 02:40:05.689] [LOG]   [node_helper] Initializing new module helper ...
                                      [2026-05-02 02:40:05.689] [LOG]   [node_helper] Module helper loaded: MMM-CalendarExt3Agenda
                                      [2026-05-02 02:40:05.746] [LOG]   [node_helper] Initializing new module helper ...
                                      [2026-05-02 02:40:05.746] [LOG]   [node_helper] Module helper loaded: calendar
                                      [2026-05-02 02:40:05.747] [LOG]   [node_helper] Initializing new module helper ...
                                      [2026-05-02 02:40:05.747] [LOG]   [node_helper] Module helper loaded: MMM-CalendarExt3
                                      [2026-05-02 02:40:05.747] [LOG]   [app] All module helpers loaded.
                                      [2026-05-02 02:40:05.751] [LOG]   [server] Starting server on port 8080 ...
                                      [2026-05-02 02:40:05.760] [ERROR] [unknown] (node:13239) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                      (Use `electron --trace-deprecation ...` to show where the warning was created)
                                      [13239:0502/024005.762036:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                                      [13239:0502/024005.762106:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                                      [13239:0502/024005.762122:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                                      /home/hsa/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                                      hsa@HSA:~/MagicMirror $
                                        sdetweil @1a2a3a
                                        @1a2a3a ok, it still thinks wayland is active.
                                        nano  installers/mm.sh
                                        change line
                                        to
                                          if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 1 ]; then
                                        ctrl-o,
                                        enter
                                        ctrl-x
                                        then
                                        installers/mm.sh
                                        • 1 Offline
                                          1a2a3a @sdetweil
                                          @sdetweil ok it runs now. what do i do next?
                                          edit sorry obviously stupid. just pm2 start and we are GOLD :D
                                          thanks again!
                                            sdetweil @1a2a3a
                                            @1a2a3a yeh, weird tho
                                            can you show me output of
                                            lsb_release -a
                                            uname -a
                                            weird it thinks wayland, but won’t run that way
                                            • 3 / 4
