    multiple error in magic mirror after update from 2.28.0 to 2.36.0
    71 Posts 2 Posters 66 Views 2 Watching
    • 1 Offline
      1a2a3a @sdetweil
      hsa@HSA:~/MagicMirror $ lsb_release -a
      No LSB modules are available.
      Distributor ID: Debian
      Description:    Debian GNU/Linux 12 (bookworm)
      Release:        12
      Codename:       bookworm
      hsa@HSA:~/MagicMirror $ uname -a
      Linux HSA 6.12.75+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.75-1+rpt1~bookworm (2026-03-11) aarch64 GNU/Linux
      S 1 2 Replies Last reply Reply Quote 0
        sdetweil @1a2a3a
        @1a2a3a thanks…
        • 1 Offline
          1a2a3a @1a2a3a
          @sdetweil dont know man, gets even weirder.
          i cant turn on mm using the terminal on the pi directly.
          i tried npm run start:x11 and it will just close off with a /home/hsa/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
          i can now only turn on my mm using pm2 on my ssh terminal…
          btw i have a cron job, not sure if this is causing the issue
          crontab -e
          38 00 * * * /home/HSA/display_on.sh
          37 00 * * * /home/HSA/display_off.sh
          display_off.sh
          #!/bin/bash
          export WAYLAND_DISPLAY=wayland-1
          export XDG_RUNTIME_DIR=/run/user/1000
          /usr/bin/wlr-randr --output HDMI-A-2 --off
          display_on.sh
          #!/bin/bash
          /usr/bin/wlr-randr --output HDMI-A-2 --on --transform 90
            sdetweil @1a2a3a
            @1a2a3a yeh… weird indeed… those scripts are wayland based…
            ok, open a new terminal window
            and do
            env
            to dump out the environment variables…
            check to make sure none expose any info you don’t want shown here and paste the cleaned list
            1 1 Reply Last reply Reply Quote 0
            • 1 Offline
              1a2a3a @sdetweil
              @sdetweil uhm which are the info that are sensitive?
              so im actually wayland instead of x11?
                sdetweil @1a2a3a
                @1a2a3a sensitive
                name, address, zipcode, apikeys, passwords…
                • 1 Offline
                  1a2a3a @sdetweil
                  @sdetweil this safe?
                  SHELL=/bin/bash
                  LANGUAGE=en_US.UTF-8
                  NO_AT_BRIDGE=1
                  XDG_SESSION_TYPE=tty
                  MOTD_SHOWN=pam
                  LANG=en_US.UTF-8
                  LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=00:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.avif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:*~=00;90:*#=00;90:*.bak=00;90:*.old=00;90:*.orig=00;90:*.part=00;90:*.rej=00;90:*.swp=00;90:*.tmp=00;90:*.dpkg-dist=00;90:*.dpkg-old=00;90:*.ucf-dist=00;90:*.ucf-new=00;90:*.ucf-old=00;90:*.rpmnew=00;90:*.rpmorig=00;90:*.rpmsave=00;90:
                  XDG_SESSION_CLASS=user
                  TERM=xterm
                  SHLVL=1
                  XDG_SESSION_ID=6
                  LC_ALL=en_US.UTF-8
                  DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
                  SSH_TTY=/dev/pts/0
                  _=/usr/bin/env
                    sdetweil @1a2a3a
                    @1a2a3a yeh, fine, but no wayland info there
                    I see a diff on my mm.sh
                    if wayland_display is not set, then I set it to
                    WAYLAND_DISPLAY=wayland-0
                    but your scripts use wayland-1
                    SO, lets try this
                    edit mm.sh again
                    change this line
                      if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 1 ]; then
                    back to
                      if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
                    and change this line
                    export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                    to
                    export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-1}
                    and save mm.sh
                    then
                    pm2 stop all
                    pm2 start MagicMirror
                    • 1 Offline
                      1a2a3a @sdetweil
                      @sdetweil it worked! is that your expectation?
                        sdetweil @1a2a3a
                        @1a2a3a yes…
                        all should be good now
                        • 1 Offline
                          1a2a3a @sdetweil
                          @sdetweil many thanks for your help once again sam!
                          • 4 / 4
