    JavaScript error
    28 Posts 2 Posters 6.5k Views 2 Watching
      sdetweil @Lmagenis
      @Lmagenis can you send me the log , same userid at gmail please
        The log says your disk/sd card is full (or failing)
        no space left on device
        • L Offline
          Lmagenis @sdetweil
          @sdetweil Thank you! Looks like I have some cloning to do (once I get the new card)
            sdetweil @Lmagenis
            @Lmagenis yes, maybe there is a bunch of log files you can delete
            Then you could use my backup/restore scripts
            https://github.com/sdetweil/MagicMirror-backup-restore.git
            Which has a perfect use for this
            Very small data. Can use GitHub too as the storage place
            • L Offline
              Lmagenis @sdetweil
              @sdetweil got the new card up and running! Went through the scripts as you instructed but came up with a new error. Started the magic mirror in x11 and it works! Thanks again for your help! You’re indispensable!
                sdetweil @Lmagenis
                @Lmagenis great news!!!
                Where did you see the error ?
                How did you install MagicMirror on the new system?
                • L Offline
                  Lmagenis @sdetweil
                  @sdetweil I backed up the files with your script first in case the sd copy program in the pi failed. I didn’t need the backup, but it’s nice to have in case something goes wrong.
                  when I ran “npm start” it was loading the modules and returned this:
                  (I skipped copying the earliest info about all of the modules)
                  [2026-05-12 07:52:44.151] [LOG] [node_helper] Connecting socket for: MMM-OpenWeatherForecast
                  [2026-05-12 07:52:44.152] [LOG] [MMM-OpenWeatherForecast] ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
                  [2026-05-12 07:52:44.153] [LOG] [node_helper] Connecting socket for: newsfeed
                  [2026-05-12 07:52:44.154] [LOG] [newsfeed] Starting node helper for: newsfeed
                  [2026-05-12 07:52:44.155] [LOG] [app] Sockets connected & modules started …
                  [10718:0512/075244.158823:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                  [10718:0512/075244.159077:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                  [10718:0512/075244.159133:ERROR:ui/aura/env.cc:246] The platform failed to initialize. Exiting.
                  /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                    sdetweil @Lmagenis
                    @Lmagenis ok, understood
                    We changed npm start to use the Wayland compositor, instead of x11 because the pi os has that as default now
                    If you used my install script and selected pm2, then my startup script (mm.sh) detects which compositor is running, and issues the appropriate start command
