    JavaScript error
    28 Posts 2 Posters 9.4k Views 2 Watching
    • L
      Lmagenis @sdetweil
      I’m not using pm2.
      I updated from the main MM site
      When I run npm run start:x11, I’m getting the same error.
        sdetweil @Lmagenis
        @Lmagenis ok, sounds like update didn’t complete
        Do,
        git status
        Report output
        L 1 Reply Last reply
        • L
          Lmagenis @sdetweil
          On branch master
          Your branch is up to date with ‘origin/master’.
          (use “git add …” to update what will be committed)
          (use “git restore …” to discard changes in working directory)
          modified: package-lock.json
          modified: package.json
          Untracked files:
          (use “git add …” to include in what will be committed)
          RTSPtoWeb/
          icons/
          installers/
          make_error
          old_modules/
          run-start.sh
          splashscreen/
          no changes added to commit (use “git add” and/or “git commit -a”)
            sdetweil @Lmagenis
            @Lmagenis can you do
            git diff package.json
            Looks like you used my installer script at some time
            • L
              Lmagenis @sdetweil
              Here’s what it returned:
              diff --git a/package.json b/package.json
              index b2c0eca…878e7cc 100644
              — a/package.json
              +++ b/package.json
              @@ -138,7 +138,7 @@
              “vitest”: “^4.1.5”
              “optionalDependencies”: {
              •           "electron": "^41.3.0"
              •           "electron": "^22.3.4"
                  "engines": {
                          "node": ">=22.21.1 <23 || >=24"
                sdetweil @Lmagenis
                @Lmagenis hmm
                Do
                Stop MagicMirror
                git checkout package.json
                rm package-lock.json
                rm -rf  node_modules
                npm run install-mm
                Start MagicMirror
                • L
                  Lmagenis @sdetweil
                  I’ve always used “npm start”. Tried starting it with both commands.
                  pi@raspberrypi:~/MagicMirror $ Start MagicMirror
                  -bash: Start: command not found
                  magicmirror@2.36.0 start
                  node --run start:wayland
                  /bin/sh: 1: ./node_modules/.bin/electron: not found
                    sdetweil @Lmagenis
                    @Lmagenis fun times
                    Try
                    npm install electron@41.3.0
                    please advise results
                    L 2 Replies Last reply
                    • L
                      Lmagenis @sdetweil
                      @sdetweil I really appreciate your help with this!
                      The log has over 600 lines in it. Is there something specific to look for?
                      • L
                        Lmagenis @sdetweil
                        The install returned “npm error A complete log of this…”
                          sdetweil @Lmagenis
                          @Lmagenis did it succeed or fail,
                          Without the log
                            sdetweil @Lmagenis
                            @Lmagenis can you send me the log , same userid at gmail please
                              The log says your disk/sd card is full (or failing)
                              no space left on device
                              • L
                                Lmagenis @sdetweil
                                @sdetweil Thank you! Looks like I have some cloning to do (once I get the new card)
                                  sdetweil @Lmagenis
                                  @Lmagenis yes, maybe there is a bunch of log files you can delete
                                  Then you could use my backup/restore scripts
                                  https://github.com/sdetweil/MagicMirror-backup-restore.git
                                  Which has a perfect use for this
                                  Very small data. Can use GitHub too as the storage place
                                  • L
                                    Lmagenis @sdetweil
                                    @sdetweil got the new card up and running! Went through the scripts as you instructed but came up with a new error. Started the magic mirror in x11 and it works! Thanks again for your help! You’re indispensable!
                                      sdetweil @Lmagenis
                                      @Lmagenis great news!!!
                                      Where did you see the error ?
                                      How did you install MagicMirror on the new system?
                                      • L
                                        Lmagenis @sdetweil
                                        @sdetweil I backed up the files with your script first in case the sd copy program in the pi failed. I didn’t need the backup, but it’s nice to have in case something goes wrong.
                                        when I ran “npm start” it was loading the modules and returned this:
                                        (I skipped copying the earliest info about all of the modules)
                                        [2026-05-12 07:52:44.151] [LOG] [node_helper] Connecting socket for: MMM-OpenWeatherForecast
                                        [2026-05-12 07:52:44.152] [LOG] [MMM-OpenWeatherForecast] ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
                                        [2026-05-12 07:52:44.153] [LOG] [node_helper] Connecting socket for: newsfeed
                                        [2026-05-12 07:52:44.154] [LOG] [newsfeed] Starting node helper for: newsfeed
                                        [2026-05-12 07:52:44.155] [LOG] [app] Sockets connected & modules started …
                                        [10718:0512/075244.158823:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                                        [10718:0512/075244.159077:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                                        [10718:0512/075244.159133:ERROR:ui/aura/env.cc:246] The platform failed to initialize. Exiting.
                                        /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                                          sdetweil @Lmagenis
                                          @Lmagenis ok, understood
                                          We changed npm start to use the Wayland compositor, instead of x11 because the pi os has that as default now
                                          If you used my install script and selected pm2, then my startup script (mm.sh) detects which compositor is running, and issues the appropriate start command
