    JavaScript error
    28 Posts 2 Posters 8.8k Views 2 Watching
      sdetweil @Lmagenis
      @Lmagenis the MMM-TitanSchoolMealMenu module removed the axios requirement over a year ago
      cd ~/MagicMirror/modules/MMM-TitanSchoolMealMenu
      git pull
      if that succeeds, do
      npm install
      then
      npm run server
      if good, then use browser to go to
      http://localhost:8080
      • L
        Lmagenis @sdetweil
        Now it’s running perfectly if I’m using the browser.
        So, why can’t it run if I use “npm start”?
          sdetweil @Lmagenis
          @Lmagenis you can now… we have debugged, and it works…
          ctrl-c to stop server and then do your normal start for MM
          • L
            Lmagenis @sdetweil
            It returned:
            App threw an error during load
            TypeError: styleText is not a function
            at /home/pi/MagicMirror/js/logger.js:40:42
            at Object. (/home/pi/MagicMirror/js/logger.js:114:2)
            at Module._compile (node:internal/modules/cjs/loader:1141:14)
            at Module._extensions…js (node:internal/modules/cjs/loader:1196:10)
            at Module.load (node:internal/modules/cjs/loader:1011:32)
            at Module._load (node:internal/modules/cjs/loader:846:12)
            at f._load (node:electron/js2c/asar_bundle:2:13330)
            at Module.require (node:internal/modules/cjs/loader:1035:19)
            at require (node:internal/modules/cjs/helpers:102:18)
            at Object. (/home/pi/MagicMirror/js/app.js:7:13)
            A JavaScript error occurred in the main process
            Uncaught Exception:
            [405959:0511/092036.982897:ERROR:wayland_connection.cc(224)] Failed to connect to Wayland display: No such file or directory (2)
            [405959:0511/092036.983156:ERROR:ozone_platform_wayland.cc(223)] Failed to initialize Wayland platform
            [405959:0511/092036.983172:ERROR:env.cc(255)] The platform failed to initialize. Exiting.
            The futex facility returned an unexpected error code.
            /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
              sdetweil @Lmagenis
              @Lmagenis failed to connect to Wayland display
              Npm start was changed to do Wayland, instead of x11
              Documented in the release notes
              Now need to do
              npm run start:x11
              Are you using pm2 to launch?
              How did you upgrade MagicMirror? Manually or my scripted update?
              • L
                Lmagenis @sdetweil
                I’m not using pm2.
                I updated from the main MM site
                When I run npm run start:x11, I’m getting the same error.
                  sdetweil @Lmagenis
                  @Lmagenis ok, sounds like update didn’t complete
                  Do,
                  git status
                  Report output
                  • L
                    Lmagenis @sdetweil
                    On branch master
                    Your branch is up to date with ‘origin/master’.
                    (use “git add …” to update what will be committed)
                    (use “git restore …” to discard changes in working directory)
                    modified: package-lock.json
                    modified: package.json
                    Untracked files:
                    (use “git add …” to include in what will be committed)
                    RTSPtoWeb/
                    icons/
                    installers/
                    make_error
                    old_modules/
                    run-start.sh
                    splashscreen/
                    no changes added to commit (use “git add” and/or “git commit -a”)
                      sdetweil @Lmagenis
                      @Lmagenis can you do
                      git diff package.json
                      Looks like you used my installer script at some time
                      • L
                        Lmagenis @sdetweil
                        Here’s what it returned:
                        diff --git a/package.json b/package.json
                        index b2c0eca…878e7cc 100644
                        — a/package.json
                        +++ b/package.json
                        @@ -138,7 +138,7 @@
                        “vitest”: “^4.1.5”
                        “optionalDependencies”: {
                        •           "electron": "^41.3.0"
                        •           "electron": "^22.3.4"
                            "engines": {
                                    "node": ">=22.21.1 <23 || >=24"
                          sdetweil @Lmagenis
                          @Lmagenis hmm
                          Do
                          Stop MagicMirror
                          git checkout package.json
                          rm package-lock.json
                          rm -rf  node_modules
                          npm run install-mm
                          Start MagicMirror
                          • L
                            Lmagenis @sdetweil
                            I’ve always used “npm start”. Tried starting it with both commands.
                            pi@raspberrypi:~/MagicMirror $ Start MagicMirror
                            -bash: Start: command not found
                            magicmirror@2.36.0 start
                            node --run start:wayland
                            /bin/sh: 1: ./node_modules/.bin/electron: not found
                              sdetweil @Lmagenis
                              @Lmagenis fun times
                              Try
                              npm install electron@41.3.0
                              please advise results
                              L 2 Replies Last reply Reply Quote 0
                              • L
                                Lmagenis @sdetweil
                                @sdetweil I really appreciate your help with this!
                                The log has over 600 lines in it. Is there something specific to look for?
                                • L
                                  Lmagenis @sdetweil
                                  The install returned “npm error A complete log of this…”
                                    sdetweil @Lmagenis
                                    @Lmagenis did it succeed or fail,
                                    Without the log
                                      sdetweil @Lmagenis
                                      @Lmagenis can you send me the log , same userid at gmail please
                                        The log says your disk/sd card is full (or failing)
                                        no space left on device
                                        • L
                                          Lmagenis @sdetweil
                                          @sdetweil Thank you! Looks like I have some cloning to do (once I get the new card)
                                            sdetweil @Lmagenis
                                            @Lmagenis yes, maybe there is a bunch of log files you can delete
                                            Then you could use my backup/restore scripts
                                            https://github.com/sdetweil/MagicMirror-backup-restore.git
                                            Which has a perfect use for this
                                            Very small data. Can use GitHub too as the storage place
