    JavaScript error
    28 Posts 2 Posters 9.5k Views 2 Watching
    • L
      Lmagenis @sdetweil
      I added OpenWeatherForecast and updated TitanSchoolMealMenu then the error started. I’ve // out the openweatherforecast on the config file and still get the error. MM doesn’t load and it’s up to date.
        sdetweil @Lmagenis
        @Lmagenis the MMM-TitanSchoolMealMenu module removed the axios requirement over a year ago
        cd ~/MagicMirror/modules/MMM-TitanSchoolMealMenu
        git pull
        if that succeeds, do
        npm install
        then
        npm run server
        if good, then use browser to go to
        http://localhost:8080
        L 1 Reply Last reply
        • L
          Lmagenis @sdetweil
          Now it’s running perfectly if I’m using the browser.
          So, why can’t it run if I use “npm start”?
            sdetweil @Lmagenis
            @Lmagenis you can now… we have debugged, and it works…
            ctrl-c to stop server and then do your normal start for MM
            • L
              Lmagenis @sdetweil
              It returned:
              App threw an error during load
              TypeError: styleText is not a function
              at /home/pi/MagicMirror/js/logger.js:40:42
              at Object. (/home/pi/MagicMirror/js/logger.js:114:2)
              at Module._compile (node:internal/modules/cjs/loader:1141:14)
              at Module._extensions…js (node:internal/modules/cjs/loader:1196:10)
              at Module.load (node:internal/modules/cjs/loader:1011:32)
              at Module._load (node:internal/modules/cjs/loader:846:12)
              at f._load (node:electron/js2c/asar_bundle:2:13330)
              at Module.require (node:internal/modules/cjs/loader:1035:19)
              at require (node:internal/modules/cjs/helpers:102:18)
              at Object. (/home/pi/MagicMirror/js/app.js:7:13)
              A JavaScript error occurred in the main process
              Uncaught Exception:
              [405959:0511/092036.982897:ERROR:wayland_connection.cc(224)] Failed to connect to Wayland display: No such file or directory (2)
              [405959:0511/092036.983156:ERROR:ozone_platform_wayland.cc(223)] Failed to initialize Wayland platform
              [405959:0511/092036.983172:ERROR:env.cc(255)] The platform failed to initialize. Exiting.
              The futex facility returned an unexpected error code.
              /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
                sdetweil @Lmagenis
                @Lmagenis failed to connect to Wayland display
                Npm start was changed to do Wayland, instead of x11
                Documented in the release notes
                Now need to do
                npm run start:x11
                Are you using pm2 to launch?
                How did you upgrade MagicMirror? Manually or my scripted update?
                • L
                  Lmagenis @sdetweil
                  I’m not using pm2.
                  I updated from the main MM site
                  When I run npm run start:x11, I’m getting the same error.
                    sdetweil @Lmagenis
                    @Lmagenis ok, sounds like update didn’t complete
                    Do,
                    git status
                    Report output
                    • L
                      Lmagenis @sdetweil
                      On branch master
                      Your branch is up to date with ‘origin/master’.
                      (use “git add …” to update what will be committed)
                      (use “git restore …” to discard changes in working directory)
                      modified: package-lock.json
                      modified: package.json
                      Untracked files:
                      (use “git add …” to include in what will be committed)
                      RTSPtoWeb/
                      icons/
                      installers/
                      make_error
                      old_modules/
                      run-start.sh
                      splashscreen/
                      no changes added to commit (use “git add” and/or “git commit -a”)
                        sdetweil @Lmagenis
                        @Lmagenis can you do
                        git diff package.json
                        Looks like you used my installer script at some time
                        • L
                          Lmagenis @sdetweil
                          Here’s what it returned:
                          diff --git a/package.json b/package.json
                          index b2c0eca…878e7cc 100644
                          — a/package.json
                          +++ b/package.json
                          @@ -138,7 +138,7 @@
                          “vitest”: “^4.1.5”
                          “optionalDependencies”: {
                          •           "electron": "^41.3.0"
                          •           "electron": "^22.3.4"
                              "engines": {
                                      "node": ">=22.21.1 <23 || >=24"
                            sdetweil @Lmagenis
                            @Lmagenis hmm
                            Do
                            Stop MagicMirror
                            git checkout package.json
                            rm package-lock.json
                            rm -rf  node_modules
                            npm run install-mm
                            Start MagicMirror
                            • L
                              Lmagenis @sdetweil
                              I’ve always used “npm start”. Tried starting it with both commands.
                              pi@raspberrypi:~/MagicMirror $ Start MagicMirror
                              -bash: Start: command not found
                              magicmirror@2.36.0 start
                              node --run start:wayland
                              /bin/sh: 1: ./node_modules/.bin/electron: not found
                                sdetweil @Lmagenis
                                @Lmagenis fun times
                                Try
                                npm install electron@41.3.0
                                please advise results
                                L 2 Replies Last reply
                                • L
                                  Lmagenis @sdetweil
                                  @sdetweil I really appreciate your help with this!
                                  The log has over 600 lines in it. Is there something specific to look for?
                                  • L
                                    Lmagenis @sdetweil
                                    The install returned “npm error A complete log of this…”
                                      sdetweil @Lmagenis
                                      @Lmagenis did it succeed or fail,
                                      Without the log
                                        sdetweil @Lmagenis
                                        @Lmagenis can you send me the log , same userid at gmail please
                                          The log says your disk/sd card is full (or failing)
                                          no space left on device
                                          • L
                                            Lmagenis @sdetweil
                                            @sdetweil Thank you! Looks like I have some cloning to do (once I get the new card)
