    JavaScript error
    28 Posts 2 Posters 9.5k Views 2 Watching
    • L
      Lmagenis @sdetweil
      Now it’s running perfectly if I’m using the browser.
      So, why can’t it run if I use “npm start”?
        sdetweil @Lmagenis
        @Lmagenis you can now… we have debugged, and it works…
        ctrl-c to stop server and then do your normal start for MM
        L 1 Reply Last reply
        • L
          Lmagenis @sdetweil
          It returned:
          App threw an error during load
          TypeError: styleText is not a function
          at /home/pi/MagicMirror/js/logger.js:40:42
          at Object. (/home/pi/MagicMirror/js/logger.js:114:2)
          at Module._compile (node:internal/modules/cjs/loader:1141:14)
          at Module._extensions…js (node:internal/modules/cjs/loader:1196:10)
          at Module.load (node:internal/modules/cjs/loader:1011:32)
          at Module._load (node:internal/modules/cjs/loader:846:12)
          at f._load (node:electron/js2c/asar_bundle:2:13330)
          at Module.require (node:internal/modules/cjs/loader:1035:19)
          at require (node:internal/modules/cjs/helpers:102:18)
          at Object. (/home/pi/MagicMirror/js/app.js:7:13)
          A JavaScript error occurred in the main process
          Uncaught Exception:
          [405959:0511/092036.982897:ERROR:wayland_connection.cc(224)] Failed to connect to Wayland display: No such file or directory (2)
          [405959:0511/092036.983156:ERROR:ozone_platform_wayland.cc(223)] Failed to initialize Wayland platform
          [405959:0511/092036.983172:ERROR:env.cc(255)] The platform failed to initialize. Exiting.
          The futex facility returned an unexpected error code.
          /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
            sdetweil @Lmagenis
            @Lmagenis failed to connect to Wayland display
            Npm start was changed to do Wayland, instead of x11
            Documented in the release notes
            Now need to do
            npm run start:x11
            Are you using pm2 to launch?
            How did you upgrade MagicMirror? Manually or my scripted update?
            • L
              Lmagenis @sdetweil
              I’m not using pm2.
              I updated from the main MM site
              When I run npm run start:x11, I’m getting the same error.
                sdetweil @Lmagenis
                @Lmagenis ok, sounds like update didn’t complete
                Do,
                git status
                Report output
                • L
                  Lmagenis @sdetweil
                  On branch master
                  Your branch is up to date with ‘origin/master’.
                  (use “git add …” to update what will be committed)
                  (use “git restore …” to discard changes in working directory)
                  modified: package-lock.json
                  modified: package.json
                  Untracked files:
                  (use “git add …” to include in what will be committed)
                  RTSPtoWeb/
                  icons/
                  installers/
                  make_error
                  old_modules/
                  run-start.sh
                  splashscreen/
                  no changes added to commit (use “git add” and/or “git commit -a”)
                    sdetweil @Lmagenis
                    @Lmagenis can you do
                    git diff package.json
                    Looks like you used my installer script at some time
                    • L
                      Lmagenis @sdetweil
                      Here’s what it returned:
                      diff --git a/package.json b/package.json
                      index b2c0eca…878e7cc 100644
                      — a/package.json
                      +++ b/package.json
                      @@ -138,7 +138,7 @@
                      “vitest”: “^4.1.5”
                      “optionalDependencies”: {
                      •           "electron": "^41.3.0"
                      •           "electron": "^22.3.4"
                          "engines": {
                                  "node": ">=22.21.1 <23 || >=24"
                        sdetweil @Lmagenis
                        @Lmagenis hmm
                        Do
                        Stop MagicMirror
                        git checkout package.json
                        rm package-lock.json
                        rm -rf  node_modules
                        npm run install-mm
                        Start MagicMirror
                        • L
                          Lmagenis @sdetweil
                          I’ve always used “npm start”. Tried starting it with both commands.
                          pi@raspberrypi:~/MagicMirror $ Start MagicMirror
                          -bash: Start: command not found
                          magicmirror@2.36.0 start
                          node --run start:wayland
                          /bin/sh: 1: ./node_modules/.bin/electron: not found
                            sdetweil @Lmagenis
                            @Lmagenis fun times
                            Try
                            npm install electron@41.3.0
                            please advise results
                            L 2 Replies Last reply
                            • L
                              Lmagenis @sdetweil
                              @sdetweil I really appreciate your help with this!
                              The log has over 600 lines in it. Is there something specific to look for?
                              • L
                                Lmagenis @sdetweil
                                The install returned “npm error A complete log of this…”
                                  sdetweil @Lmagenis
                                  @Lmagenis did it succeed or fail,
                                  Without the log
                                    sdetweil @Lmagenis
                                    @Lmagenis can you send me the log , same userid at gmail please
                                      The log says your disk/sd card is full (or failing)
                                      no space left on device
                                      • L
                                        Lmagenis @sdetweil
                                        @sdetweil Thank you! Looks like I have some cloning to do (once I get the new card)
                                          sdetweil @Lmagenis
                                          @Lmagenis yes, maybe there is a bunch of log files you can delete
                                          Then you could use my backup/restore scripts
                                          https://github.com/sdetweil/MagicMirror-backup-restore.git
                                          Which has a perfect use for this
                                          Very small data. Can use GitHub too as the storage place
                                          • L
                                            Lmagenis @sdetweil
                                            @sdetweil got the new card up and running! Went through the scripts as you instructed but came up with a new error. Started the magic mirror in x11 and it works! Thanks again for your help! You’re indispensable!
