    JavaScript error
    28 Posts 2 Posters 6.4k Views 2 Watching
    • L Offline
      Lmagenis
      I’d appreciate help with resolving this issue:
      Thank you!
      A JavaScript error occurred in the main process
      Uncaught Exception:
      TypeError: styleText is not a function
          at /home/pi/MagicMirror/js/logger.js:40:42
          at Object.<anonymous> (/home/pi/MagicMirror/js/logger.js:114:2)
          at Module._compile (node:internal/modules/cjs/loader:1141:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1196:10)
          at Module.load (node:internal/modules/cjs/loader:1011:32)
          at Module._load (node:internal/modules/cjs/loader:846:12)
          at f._load (node:electron/js2c/asar_bundle:2:13330)
          at Module.require (node:internal/modules/cjs/loader:1035:19)
          at require (node:internal/modules/cjs/helpers:102:18)
          at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:7:13)
      • L Offline
        Lmagenis @sdetweil
        @sdetweil got the new card up and running! Went through the scripts as you instructed but came up with a new error. Started the magic mirror in x11 and it works! Thanks again for your help! You’re indispensable!
          sdetweil @Lmagenis
          @Lmagenis can you tell us more?
          how did you install mm, or is this after an update?
          if it runs at all there is an info block output in the startup log
          if using pm2,
          pm2 stop all
          then
          npm run server
          show the messages
          ctrl-c
          to stop mm
          L 2 Replies Last reply Reply Quote 0
          • L Offline
            Lmagenis @sdetweil
            Hi! Thank you for your help!
            Here’s the output:
            [2026-05-11 08:50:20.288] [LOG] [app] Starting MagicMirror: v2.36.0
            [2026-05-11 08:50:20.301] [LOG] [utils] Loading config …
            [2026-05-11 08:50:20.310] [INFO] [utils] Checking config file /home/pi/MagicMirror/config/config.js …
            [2026-05-11 08:50:20.517] [INFO] [utils] Your configuration file doesn’t contain syntax errors :)
            [2026-05-11 08:50:20.519] [INFO] [utils] Checking modules structure configuration …
            [2026-05-11 08:50:20.688] [INFO] [utils] Your modules structure configuration doesn’t contain errors :)
            [2026-05-11 08:50:20.691] [LOG] [app] Loading module helpers …
            [2026-05-11 08:50:20.702] [LOG] [node_helper] Initializing new module helper …
            [2026-05-11 08:50:20.703] [LOG] [node_helper] Module helper loaded: updatenotification
            [2026-05-11 08:50:20.707] [LOG] [app] No helper found for module: clock.
            [2026-05-11 08:50:20.735] [LOG] [node_helper] Initializing new module helper …
            [2026-05-11 08:50:20.735] [LOG] [node_helper] Module helper loaded: MMM-Wallpaper
            [2026-05-11 08:50:20.737] [WARN] [app] No /home/pi/MagicMirror/modules/MMM-Remote-Control/MMM-Remote-Control.js found for module: MMM-Remote-Control.
            [2026-05-11 08:50:20.738] [LOG] [app] No helper found for module: MMM-Remote-Control.
            [2026-05-11 08:50:20.739] [LOG] [app] No helper found for module: MMM-Fireworks.
            [2026-05-11 08:50:20.742] [LOG] [node_helper] Initializing new module helper …
            [2026-05-11 08:50:20.748] [LOG] [node_helper] Module helper loaded: MMM-CalendarExt3
            [2026-05-11 08:50:21.461] [LOG] [node_helper] Initializing new module helper …
            [2026-05-11 08:50:21.462] [LOG] [node_helper] Module helper loaded: calendar
            [2026-05-11 08:50:21.469] [ERROR] [app] Error when loading MMM-TitanSchoolMealMenu: Cannot find module ‘axios’
            Require stack:
            • /home/pi/MagicMirror/modules/MMM-TitanSchoolMealMenu/TitanSchoolsClient.js
            • /home/pi/MagicMirror/modules/MMM-TitanSchoolMealMenu/node_helper.js
            • /home/pi/MagicMirror/serveronly/index.js
              [2026-05-11 08:50:21.470] [LOG] [app] No helper found for module: MMM-UselessFacts.
              [2026-05-11 08:50:21.629] [LOG] [node_helper] Initializing new module helper …
              [2026-05-11 08:50:21.630] [LOG] [node_helper] Module helper loaded: newsfeed
              [2026-05-11 08:50:21.631] [LOG] [app] All module helpers loaded.
              [2026-05-11 08:50:21.648] [LOG] [server] Starting server on port 8080 …
              [2026-05-11 08:50:21.652] [WARN] [server] You’re using a full whitelist configuration to allow for all IPs
              [2026-05-11 08:50:21.693] [LOG] [app] Server started …
              [2026-05-11 08:50:21.695] [LOG] [node_helper] Connecting socket for: updatenotification
              [2026-05-11 08:50:21.696] [LOG] [node_helper] Starting module helper: updatenotification
              [2026-05-11 08:50:21.698] [LOG] [node_helper] Connecting socket for: MMM-Wallpaper
              [2026-05-11 08:50:21.699] [LOG] [MMM-Wallpaper] Starting node helper for: MMM-Wallpaper
              [2026-05-11 08:50:21.700] [LOG] [node_helper] Connecting socket for: MMM-CalendarExt3
              [2026-05-11 08:50:21.706] [LOG] [node_helper] Connecting socket for: calendar
              [2026-05-11 08:50:21.707] [LOG] [calendar] Starting node helper for: calendar
              [2026-05-11 08:50:21.708] [LOG] [node_helper] Connecting socket for: newsfeed
              [2026-05-11 08:50:21.710] [LOG] [newsfeed] Starting node helper for: newsfeed
              [2026-05-11 08:50:21.712] [LOG] [app] Sockets connected & modules started …
              [2026-05-11 08:50:21.714] [INFO] [serveronly]
            Ready to go! Please point your browser to: http://0.0.0.0:8080 <<<
            [2026-05-11 08:50:22.305] [INFO] [systeminformation]
            System Information
            • SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false; MM: v2.36.0
            • OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.62+rpt-rpi-v8
            • VERSIONS: electron: undefined; used node: 22.21.1; installed node: 22.21.1; npm: 11.14.1; pm2: 6.0.14
            • ENV: XDG_SESSION_TYPE: tty; MM_CONFIG_FILE: undefined
              WAYLAND_DISPLAY: undefined; DISPLAY: undefined; ELECTRON_ENABLE_GPU: undefined
            • RAM: total: 3796.81 MB; free: 3047.70 MB; used: 749.11 MB
            • OTHERS: uptime: 44148 minutes; timeZone: America/New_York
            • L Offline
              Lmagenis @sdetweil
              I added OpenWeatherForecast and updated TitanSchoolMealMenu then the error started. I’ve // out the openweatherforecast on the config file and still get the error. MM doesn’t load and it’s up to date.
                sdetweil @Lmagenis
                @Lmagenis the MMM-TitanSchoolMealMenu module removed the axios requirement over a year ago
                cd ~/MagicMirror/modules/MMM-TitanSchoolMealMenu
                git pull
                if that succeeds, do
                npm install
                then
                npm run server
                if good, then use browser to go to
                http://localhost:8080
                • L Offline
                  Lmagenis @sdetweil
                  Now it’s running perfectly if I’m using the browser.
                  So, why can’t it run if I use “npm start”?
                    sdetweil @Lmagenis
                    @Lmagenis you can now… we have debugged, and it works…
                    ctrl-c to stop server and then do your normal start for MM
                    • L Offline
                      Lmagenis @sdetweil
                      It returned:
                      App threw an error during load
                      at Object. (/home/pi/MagicMirror/js/logger.js:114:2)
                      at Module._extensions…js (node:internal/modules/cjs/loader:1196:10)
                      at Object. (/home/pi/MagicMirror/js/app.js:7:13)
                      Uncaught Exception:
                      [405959:0511/092036.982897:ERROR:wayland_connection.cc(224)] Failed to connect to Wayland display: No such file or directory (2)
                      [405959:0511/092036.983156:ERROR:ozone_platform_wayland.cc(223)] Failed to initialize Wayland platform
                      [405959:0511/092036.983172:ERROR:env.cc(255)] The platform failed to initialize. Exiting.
                      The futex facility returned an unexpected error code.
                      /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
                        sdetweil @Lmagenis
                        @Lmagenis failed to connect to Wayland display
                        Npm start was changed to do Wayland, instead of x11
                        Documented in the release notes
                        Now need to do
                        npm run start:x11
                        Are you using pm2 to launch?
                        How did you upgrade MagicMirror? Manually or my scripted update?
                        • L Offline
                          Lmagenis @sdetweil
                          I’m not using pm2.
                          I updated from the main MM site
                          When I run npm run start:x11, I’m getting the same error.
                            sdetweil @Lmagenis
                            @Lmagenis ok, sounds like update didn’t complete
                            Do,
                            git status
                            Report output
                            • L Offline
                              Lmagenis @sdetweil
                              On branch master
                              Your branch is up to date with ‘origin/master’.
                              (use “git add …” to update what will be committed)
                              (use “git restore …” to discard changes in working directory)
                              modified: package-lock.json
                              modified: package.json
                              Untracked files:
                              (use “git add …” to include in what will be committed)
                              RTSPtoWeb/
                              icons/
                              installers/
                              make_error
                              old_modules/
                              run-start.sh
                              splashscreen/
                              no changes added to commit (use “git add” and/or “git commit -a”)
                                sdetweil @Lmagenis
                                @Lmagenis can you do
                                git diff package.json
                                Looks like you used my installer script at some time
                                • L Offline
                                  Lmagenis @sdetweil
                                  Here’s what it returned:
                                  diff --git a/package.json b/package.json
                                  index b2c0eca…878e7cc 100644
                                  — a/package.json
                                  +++ b/package.json
                                  @@ -138,7 +138,7 @@
                                  “vitest”: “^4.1.5”
                                  “optionalDependencies”: {
                                  •           "electron": "^41.3.0"
                                  •           "electron": "^22.3.4"
                                      "engines": {
                                              "node": ">=22.21.1 <23 || >=24"
                                    sdetweil @Lmagenis
                                    @Lmagenis hmm
                                    Do
                                    Stop MagicMirror
                                    git checkout package.json
                                    rm package-lock.json
                                    rm -rf  node_modules
                                    npm run install-mm
                                    Start MagicMirror
                                    • L Offline
                                      Lmagenis @sdetweil
                                      I’ve always used “npm start”. Tried starting it with both commands.
                                      pi@raspberrypi:~/MagicMirror $ Start MagicMirror
                                      -bash: Start: command not found
                                      magicmirror@2.36.0 start
                                      node --run start:wayland
                                      /bin/sh: 1: ./node_modules/.bin/electron: not found
                                        sdetweil @Lmagenis
                                        @Lmagenis fun times
                                        Try
                                        npm install electron@41.3.0
                                        please advise results
                                        • L Offline
                                          Lmagenis @sdetweil
                                          @sdetweil I really appreciate your help with this!
                                          The log has over 600 lines in it. Is there something specific to look for?
                                          • L Offline
                                            Lmagenis @sdetweil
                                            The install returned “npm error A complete log of this…”
                                              sdetweil @Lmagenis
                                              @Lmagenis did it succeed or fail,
                                              Without the log
