    JavaScript error
    28 Posts 2 Posters 9.5k Views 2 Watching
      sdetweil @Lmagenis
      @Lmagenis hmm
      Do
      Stop MagicMirror
      git checkout package.json
      rm package-lock.json
      rm -rf  node_modules
      npm run install-mm
      Start MagicMirror
      L 1 Reply Last reply
      • L
        Lmagenis @sdetweil
        I’ve always used “npm start”. Tried starting it with both commands.
        pi@raspberrypi:~/MagicMirror $ Start MagicMirror
        -bash: Start: command not found
        magicmirror@2.36.0 start
        node --run start:wayland
        /bin/sh: 1: ./node_modules/.bin/electron: not found
          sdetweil @Lmagenis
          @Lmagenis fun times
          Try
          npm install electron@41.3.0
          please advise results
          L 2 Replies Last reply
          • L
            Lmagenis @sdetweil
            @sdetweil I really appreciate your help with this!
            The log has over 600 lines in it. Is there something specific to look for?
            • L
              Lmagenis @sdetweil
              The install returned “npm error A complete log of this…”
                sdetweil @Lmagenis
                @Lmagenis did it succeed or fail,
                Without the log
                  sdetweil @Lmagenis
                  @Lmagenis can you send me the log , same userid at gmail please
                    The log says your disk/sd card is full (or failing)
                    no space left on device
                    • L
                      Lmagenis @sdetweil
                      @sdetweil Thank you! Looks like I have some cloning to do (once I get the new card)
                        sdetweil @Lmagenis
                        @Lmagenis yes, maybe there is a bunch of log files you can delete
                        Then you could use my backup/restore scripts
                        https://github.com/sdetweil/MagicMirror-backup-restore.git
                        Which has a perfect use for this
                        Very small data. Can use GitHub too as the storage place
                        • L
                          Lmagenis @sdetweil
                          @sdetweil got the new card up and running! Went through the scripts as you instructed but came up with a new error. Started the magic mirror in x11 and it works! Thanks again for your help! You’re indispensable!
                            sdetweil @Lmagenis
                            @Lmagenis great news!!!
                            Where did you see the error ?
                            How did you install MagicMirror on the new system?
                            • L
                              Lmagenis @sdetweil
                              @sdetweil I backed up the files with your script first in case the sd copy program in the pi failed. I didn’t need the backup, but it’s nice to have in case something goes wrong.
                              when I ran “npm start” it was loading the modules and returned this:
                              (I skipped copying the earliest info about all of the modules)
                              [2026-05-12 07:52:44.151] [LOG] [node_helper] Connecting socket for: MMM-OpenWeatherForecast
                              [2026-05-12 07:52:44.152] [LOG] [MMM-OpenWeatherForecast] ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
                              [2026-05-12 07:52:44.153] [LOG] [node_helper] Connecting socket for: newsfeed
                              [2026-05-12 07:52:44.154] [LOG] [newsfeed] Starting node helper for: newsfeed
                              [2026-05-12 07:52:44.155] [LOG] [app] Sockets connected & modules started …
                              [10718:0512/075244.158823:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                              [10718:0512/075244.159077:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                              [10718:0512/075244.159133:ERROR:ui/aura/env.cc:246] The platform failed to initialize. Exiting.
                              /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                                sdetweil @Lmagenis
                                @Lmagenis ok, understood
                                We changed npm start to use the Wayland compositor, instead of x11 because the pi os has that as default now
                                If you used my install script and selected pm2, then my startup script (mm.sh) detects which compositor is running, and issues the appropriate start command
