    Upgrade
    27 Posts 6 Posters 7.5k Views 6 Watching
      sdetweil @mumblebaj
      @mumblebaj yeh, I was working on a mobile app last weekend
      It had npm 11 installed ( windows) and had all the acceptscript problems
      • mumblebajM Offline
        mumblebaj Module Developer @sdetweil
        @sdetweil Yeah, warnings come from 11.16.0+
          sdetweil @mumblebaj
          @mumblebaj on windows these were NOT warnings… I actually had to run different tasks to get the scripts allowed/approved… I hadn’t expected that in npm 11…
          same problem as always, some scammers leveraged the automation tools to do damage and now we all have to pay for it…
            MyMirror
            Moin (as we say here in Hamburg),
            I’ve just reinstalled my MM using Sam’s “Install MagicMirror²” script. The script displayed and verified Node version 22.22.1.
            I then ran Sam’s upgrade script, which expected Node version 22.22.2 and installed it.
            If that’s how it’s meant to be – everything’s fine.
            pimaster@MM0626:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
            update log will be in /home/pimaster/MagicMirror/installers/upgrade.log
            doing test run = false
            Node currently installed. Checking version number.
            Minimum Node version: v22.22.2
            Installed Node version: v22.21.1
            installing correct version of node and npm, please wait
            Check current Node installation ...
            Minimum Node version: v22.21.1
            Installed Node version: v22.22.2
            No Node.js upgrade necessary.
            Check current NPM installation ...
            NPM currently installed. Checking version number.
            Minimum npm version: V10.9.7
            Installed npm version: V10.9.7
            No npm upgrade necessary.
            local version 2.37.0 already same as master 2.37.0
            moving css contents to config
              MyMirror @MyMirror
              There might also be a minor error in Sam’s restore script here.
              The “MMM-MyWastePickup” directory was the only one that triggered the “folder already exists” error following a fresh installation.
              restoring MMM-MyWastePickup
              module MMM-MyWastePickup contains package.json, doing npm install
              there were files saved for this module , restoring
               MMM-MyWastePickup folder already exists, skipping restore from https://github.com/jclarke0000/MMM-MyWastePickup.git
              restoring MMM-NearCompliments
              module MMM-NearCompliments contains package.json, doing npm install
                sdetweil @MyMirror
                @MyMirror can you provide me the
                ~/MagicMirror/installlers/restore.log
                open an issue and attach it there
                In the issue. Please explain the steps you used up to restore
                edit
                | thanks… see it
                  this was a bug in backup and restore when multiple ‘module’ folders were sourced from the same git repo (multi- instance copy type problem)
                  the two scripts are fixed now… if you used these scripts, please run another backup to make sure the module_list file is updated…
