    (Solved) PM2 does not start on reboot
    15 Posts 4 Posters 15.1k Views 6 Watching
    • X
      xbmcnut
      Hi there. I have MM running but the auto start feature is not working. See below.
      0_1489442964694_upload-015b7538-a813-476d-936c-8b0cfcc3645a
      PM2 is version 2.4.2 and the MM install was built on Jessie Lite (2017-03-02) on a Pi2. I can start the script with PM2 start mm.sh and use PM2 save when it’s running but PM2 list after a reboot shows nothing running. How do I debug this?
      I noted that when following the auto start instructions, chmod +x mm.sh returned a permissions error. Is that normal? Does that have to be run as sudo? I changed the permissions to the ‘Pi’ user using WinSCP but it made no difference.
      0_1489443276731_upload-dad08d4d-bdc7-4e6a-96ff-a6eef7c12ae5
      • X
        xbmcnut
        OK, I started again with a clean install of the full Jessie build now then leaned it out using this guide. As before, once I start going through with the PM2 stuff, everything seems to work OK until a reboot and MM does not start. Surely someone else has seen this? Am I making a simple NOOB mistake here or does it just not work?
        0_1489547666665_upload-72de88bb-d0f6-46ed-884c-38ce64503343
        • A
          amanzimdwini @xbmcnut
          @xbmcnut Hey - I’m not the only one any more… Same problem: used to work on an OLD installation, and now - nothing. I am just working on a brand new one tonight.
          BTW: does you screensaver stay off? I had to work quite a bit at getting that working in the new distro.
          A X 2 Replies Last reply Reply Quote 0
          • A
            amanzimdwini @amanzimdwini
            @amanzimdwini @xbmcnut
            Clean installation onto a Pi3 works… (and I have NO idea why it works on this one: my last pi3 gave me the same problem you had). So you might want to look at a different Pi?
            Best of luck!
            • X
              xbmcnut @amanzimdwini
              @amanzimdwini I have resolved it now as I posted a bug. Turns out it’s related to the timeout setting for the PM2 service. Developers are going to remove timeout in next release but for now it can be tweaked. And no, had no joy with screensaver either. Disabled it in GUI and it seems to be gone now.
              https://github.com/Unitech/pm2/issues/2765#issuecomment-286778941
              • A
                @xbmcnut Just read your post - now MY installation wont run PM2. Argh. Where do you change the timeout settings?
                ps - Re: screensaver: I had to resort to’
                sudo apt-get install xscreensaver
                and the disable it.
                X 1 Reply Last reply Reply Quote 0
                • X
                  @amanzimdwini said in (Solved) PM2 does not start on reboot:
                  /etc/systemd/system/pm2-root.service
                  I changed mine from 8 to 15s using WinSCP with the SCP/Shell set to sudo su -
                  A R 2 Replies Last reply Reply Quote 0
                  • A
                    @xbmcnut took me a good 10 seconds to find pm2-pi.service for the raspberry
                    And another 5 to change it.
                    YOU ARE A GENIUS!
                    thanks
                    • R
                      rmohsen @xbmcnut
                      @xbmcnut Hello
                      total noob here and i have the same problem , how do i do that ?
                      ps : i’m not a developer or anything , i’m just a regular user so i kinda need step by step
                      thanks
                      • X
                        xbmcnut @rmohsen
                        @rmohsen Do you know how to access your mirror with either PuTTy or WinSCP?
                        • R
                          rmohsen @xbmcnut
                          @xbmcnut yes. Tried winscp but couldn’t edit the file , no permission
                          I managed to change it from 8 to 15 with another command on terminal but still not working
                          • X
                            xbmcnut @rmohsen
                            @rmohsen Apologies. My install has died over the weekend and MM will no longer run. Getting to Desktop login screen on reboot and that’s it even though I told it to auto login, the desktop will not start. Have popped in ‘too hard bin’ for the moment, sorry.
                            • Sandy2503S
                              Sandy2503
                              @xbmcnut :abcd:
                              where have you changed the Idle Time ???
                              Thats my pm2-root.service:
                              [Unit]
                              Description=PM2 process manager
                              Documentation=https://pm2.keymetrics.io/
                              After=network.target
                              [Service]
                              Type=forking
                              User=root
                              LimitNOFILE=infinity
                              LimitNPROC=infinity
                              LimitCORE=infinity
                              Environment=PATH=/usr/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
                              Environment=PM2_HOME=/root/.pm2
                              PIDFile=/root/.pm2/pm2.pid
                              ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
                              ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
                              ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
                              [Install]
                              WantedBy=multi-user.target
                              Greetz Sandy2503
                              • X
                                xbmcnut @Sandy2503
                                @Sandy2503 I believe in the latest version of PM2, this was removed.
                                • Sandy2503S
                                  Sandy2503
                                  today is install a fresh version of raspian pixel on my raspi 2 with the new version (2.1.1) of MagicMirror and the actual version of PM2 (2.4.5)
                                  But the autostart function themes not to work and in the pm2-root.service is no part to set the idle time.
                                  How can i fix the idle Problem ?
