    Modules not showing up
    8 Posts 3 Posters 6.8k Views 3 Watching
      jonny4500
      Hey guys,
      I manually installed MagicMirror on my Pi Zero, but I’ve run into some trouble:
      My config file is formatted correctly, but no modules are showing up. If I comment all our and only do one at a time, the only module that shows up is clock.
      Any suggestions??
      Thanks.
        ROMSY
        hey guys, i just reply to this thread, because i’ve got exactly the same problem with my Rpi1 B!
        So i just copied the config.js.sample to config.js, rebooted theab pi and startet everything.
        Got a blank Screen only.
        after that i tried to remove every module and add “hello World”.
        It Worked.
        After that i tried to add module for module:
        When i add the compliments module i still see only my Hello World!
        After i added the clock. everything goes blank again. Anybody knows a reason why?
        here is my config.js so far
        var config = {
                port: 8080,
                ipWhitelist: ["127.0.0.1", [], "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses
                language: "de",
                timeFormat: 24,
                units: "metric",
                                module: "helloworld",
                                        text: "Hallo Welt!",
                                module: "compliments",
                                position: "lower_third",
                                anytime: [
                                         "Hey there sexy!"
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @ROMSY
          @ROMSY probably you don’t have installed momentjs correctly
            ROMSY @strawberry 3.141
            @strawberry-3.141
            i followed this instruction from the forum.
            Question is for me right now, where do i check if i installed it correctly?
              @ROMSY in the magicmirror folder is a folder vendor which should have a folder node_modules and in there there has to be a momentjs folder
                @strawberry-3.141
                pi@infoscreen:~ $ ls MagicMirror/vendor/
                package.json  vendor.js
                just checked the git… same structur in there. so what is the next step?
                  @ROMSY you have to run npm install
                    @strawberry-3.141
                    everything is working now! Thanks a lot :)
