    MMM-Button dont load
    5 Posts 3 Posters 2.6k Views 3 Watching
      schmucke
      Hey,
      if i try to use the MMM-Button module i just get this error:
      0|mm       | App threw an error during load
      0|mm       | Error: Module version mismatch. Expected 50, got 49.
      0|mm       |     at Error (native)
      0|mm       |     at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
      0|mm       |     at Object.Module._extensions..node (module.js:583:18)
      0|mm       |     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
      0|mm       |     at Module.load (module.js:473:32)
      0|mm       |     at tryModuleLoad (module.js:432:12)
      0|mm       |     at Function.Module._load (module.js:424:3)
      0|mm       |     at Module.require (module.js:483:17)
      0|mm       |     at require (internal/module.js:20:19)
      0|mm       |     at bindings (/home/pi/MagicMirror/modules/MMM-Button/node_modules/bindings/bindings.js:76:44)
      0|mm       | Whoops! There was an uncaught exception...
      i have install the module right…
      has anyone a idea?
      Thank you
      johnnyboyJ 1 Reply Last reply
      • johnnyboyJ
        johnnyboy @schmucke
        @schmucke
        I`m not sure here… but where it says "expected 50, got 49… 1 is missing eh?
          schmucke
          yes, but what is missing? i dont understand it :/
          • Y
            yawns Moderator
            please run npm list, which electron version are you running?
            If it is 1.4 then please run this command in the MMM-Button folder
            npm rebuild --runtime=electron --target=1.4.0 --disturl=https://atom.io/download/atom-shell --build-from-source
            Reply Quote 1
              schmucke @yawns
              @yawns thank you, now the module starts.
              thank you very much
