    Facial Recognition - customize your mirror for every user!
    215 Posts 55 Posters 513.6k Views 57 Watching
      rvdgeer @shashank
      @shashank If you run the facetrainer (capture.py and train.py) first, you should know what to enter here…
        shashank @rvdgeer
        @rvdgeer hi,
        After running capture.py a folder created by name ‘sasi’ in the /home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/facetrainer/training_data
        then by running train.py a training.xml created in the path
        and also in /home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/facerecognition_tester/lib i mentioned name in personen = ["sasi"]
        my config.js file as below
            module: 'MMM-Facial-Recognition',
            position: 'top_left',
                // 1=LBPH | 2=Fisher | 3=Eigen
                recognitionAlgorithm: 1,
                // Threshold for the confidence of a recognized face before it's considered a
                // positive match.  Confidence values below this threshold will be considered
                // a positive match because the lower the confidence value, or distance, the
                // more confident the algorithm is that the face was correctly detected.
                lbphThreshold: 50,
                fisherThreshold: 250,
                eigenThreshold: 3000,
                // force the use of a usb webcam on raspberry pi (on other platforms this is always true automatically)
                useUSBCam: false,
                // Path to your training xml
                trainingFile: 'modules/MMM-Facial-Recognition/training.xml',
                // recognition intervall in seconds (smaller number = faster but CPU intens!)
                interval: 2,
                // Logout delay after last recognition so that a user does not get instantly logged out if he turns away from the mirror for a few seconds
                logoutDelay: 15,
                // Array with usernames (copy and paste from training script)
                users: ['sasi'],
                //Module set used for strangers and if no user is detected
                defaultClass: "default",
                //Set of modules which should be shown for every user
                forAllClass: "for_all"
            module: 'clock',
            //Set your classes here seperated by a space.
            //Shown for all users
            classes: 'for_all'
        when i run pm2 start mm i am struck at below message
        0_1474984402690_upload-363493b4-6bba-4782-bab1-808bb8a3f585
        can someone help me on this error
        paviroP 1 Reply Last reply Reply Quote 0
        • Z Offline
          zachlan
          Potentially stupid question here, apologies in advance if I’ve missed something obvious. I have the mirror and the face recognition working (Yay!) but when it’s running, on the left side of the screen it shows “MMM-Facial-Recognition” and module-10-mmm-facial-recognition underneath. I though about removing the position tag, but that’s there in the readme version so did not. How do I remove the text showing the running facial recognition module?
          Thanks!Zach
          • paviroP Offline
            paviro @shashank
            @rvdgeer that sucks sorry about that. Recognition can be tricky sometimes :/
            @shashank check the trainingFile in your config, does it really exist at that location?
            Update: I see you figured it out, was a wrong location the problem? Just remove the position part is isn’t relevant anymore sorry :)
            S P 2 Replies Last reply Reply Quote 0
            • paviroP Offline
              paviro @rvdgeer
              This post is deleted!
                shashank @paviro
                @paviro
                yes , i copied the training file from //MMM-Facial-Recognition-Tools/facetrainer
                to // Path to your training xml
                trainingFile: ‘modules/MMM-Facial-Recognition/training.xml’,
                  s1084836
                  Hello, First of all thanks a lot for building this great module!
                  I am trying to get it to work, I’ve installed the module and it looks like It doens’t start:
                  Output when I start the NPM:
                  `pi@raspberrypi:~/MagicMirror $ npm start
                  magicmirror@2.0.0 start /home/pi/MagicMirror
                  electron js/electron.js
                  Loading config ...
                  Loading module helpers ...
                  All module helpers loaded.
                  Starting server op port 8080 ...
                  Server started ...
                  Connecting socket for: camera
                  camera helper started ...
                  Connecting socket for: MMM-Facial-Recognition
                  Staring module helper: MMM-Facial-Recognition
                  Launching application.
                  initializing nodemailer
                  It looks like its installed fine, because of the starting module helper: MMM-Facial-Recognition.
                  But I am not getting the normal output like I see by other people:
                  [MMM-Facial-Recognition] Facerecognition started...
                  [MMM-Facial-Recognition] Loading training data...
                  My Config.json file:
                  `/* Magic Mirror Config Sample
                  By Tom & Joey
                  MIT Licensed.
                  var config = {
                  port: 8080,
                  language: 'nl',
                  timeFormat: 24,
                  units: 'metric',
                              module: 'camera',
                  	    position: 'top_center',
                  		selfieInterval: 3,  // Time interval in seconds before the photo will be taken.
                  	        emailConfig: {
                  	            service: 'Hotmail', // Email provider to use to send email with a photo.
                  	            auth: {
                  	                user: '<s1084836@hotmail.com>', // Your email account
                  	                pass: '<test12345>'        // Your password for email account
                  			lbphThreshold: 50,
                  			useUSBCam: true,
                  			interval: 2,
                  			logoutDelay: 15,
                  			users: ['Tom'],
                  			everyoneClass: "everyone"
                  Is there anything I’m doing wrong ? :D
                  Note from admin: Please use Markdown on code snippets for easier reading!
                    awarrington
                    @paviro thanks creating such a cool module!
                    I have followed the instructions to capture the training images and have successfully created a training.xml file :)
                    When I add the MMM-Facial-Recognition module to my Magic Mirror config.js file I get “WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration” in the terminal and the Magic Mirror shows an error page saying config.js not found.
                    My config.js is:
                    var config = {
                    	port: 8080,
                    	language: 'en',
                    	timeFormat: 12,
                    	units: 'metric',
                    			module: 'clock',
                    			classes: 'everyone'
                    			module: 'compliments',
                    			position: 'lower_third'
                    			classes: 'andy'
                    				lbphThreshold: 50,
                    				useUSBCam: false,
                    				trainingFile: '/home/pi/MagicMirror/modules/MMM-Facial-Recognition/training.xml',
                    				interval: 3,
                    				logoutDelay: 15,
                    				users: ['andy'],
                    If I comment out " classes: ‘everyone’ " and " classes: ‘andy’ " in the other modules the MagicMirror loads with no errors but blank black screen.
                    Any ideas what’s causing this ?
                      rvdgeer @awarrington
                      @awarrington It seems like you’ve missed the comma’s at the end of the line where the position is for the clock and compliments module here:
                      			module: 'clock',
                      			position: 'top_left', <--
                      			classes: 'everyone'
                        awarrington
                        @rvdgeer Thank you! All works perfectly now
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 21
                        • 22
                        • 8 / 22
