    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 570.6k Views 58 Watching
    • Y
      YourhighnessLeender @paviro
      @paviro hmm. Just can’t get it working for some reason… will try again. It complaind about no picam. Maybe I have to change something in the script? I’ll du another try.
      • paviroP
        paviro
        Well the capture script does not have an enforce webcam option. Try to uninstall the picam python module, it will fallback to webcam then.
        To minimize recognition errors the MagicMirror module requires two identical recognitions to be accepted as current user. If your training data is not good enough it could happen that you are never recognized twice in two directly following images -> Always unknown user.
        – The Doctor
        Y 1 Reply Last reply
        • Y
          @paviro thanks for the help. How do I uninstall the picam? Is it just to remove picam.py?
          • paviroP
            paviro
            Nooo! Don’t mess with the module code! I just added an option to force webcam use, checkout the updated code on GitHub :)
            – The Doctor
            Y 2 Replies Last reply
            Reply Quote 2
            • Y
              @paviro thanks paviro! Will do!
                benkej @paviro
                @paviro Thanks! I’ll add more images and try to recognize my face.
                But It’s very interesting that facerecognition_tester can identify me only from this three images
                paviroP 1 Reply Last reply
                • Y
                  @paviro thanks!!! 200+ images captured and it’s now working :-) :pray: just need to tweak the threshold to be a bit more forgiving.
                  • paviroP
                    paviro @benkej
                    @benkej as I stated the MagicMirror module need two identical identifies in a row :)
                    @YourhighnessLeender glad to hear :)
                    – The Doctor
                    B 1 Reply Last reply
                      benkej @paviro
                      @paviro 223 positive images and no success :( maybe I have to add more :blush:
                      What is the best practice to take the pictures? Sit closer to picam and rotate the face or not move and shoot few picture?
                      • paviroP
                        paviro
                        I try to take pictures in different lighting conditions with slight changes in angle. One looking a bit down, one a bit to the left and so on.
                        – The Doctor
                        B 2 Replies Last reply
                          benkej @paviro
                          @paviro ok, thank you
                          • PointPubMediaP
                            PointPubMedia
                            Not sure why, but got better performance with Fisher instead of LBPH
                            • paviroP
                              paviro
                              That’s why there are multiple algorithms :D Choose the one that works best for you :)
                              – The Doctor
                                reaper81
                                hi, is it possible to turn off the popup-window “Gesichtserkennung …” when a face is tracked?
                                • Y
                                  YourhighnessLeender @reaper81
                                  @reaper81 just remove the notification module in config.js
                                  tosti007T I 2 Replies Last reply
                                  • tosti007T
                                    tosti007 Module Developer @YourhighnessLeender
                                    @YourhighnessLeender @reaper81 I would not advise removing the notification module, since then you wouldn’t be able to see any notification anymore. Instead I would suggest you to remove the lines in the MMM-Facial-Recognition.js file where they call this.sendNotification("SHOW_ALERT", here also something);
                                    If there is anything don’t hesitate to contact me!
                                    ProfileSwitcher, TouchNotifications
                                    • paviroP
                                      paviro
                                      Added an option.
                                      @tosti007 I am not sure its a good idea to advice people to change module code since it makes updating more dificult for them and could also break stuff.
                                      – The Doctor
                                      tosti007T R 2 Replies Last reply
                                      • tosti007T
                                        tosti007 Module Developer @paviro
                                        @paviro Yea that’s true, sorry for it, however I also don’t really think it’s advisable to disable the notifications in total. I see an option for a new configurable feature here? :)
                                          benkej @paviro
                                          @paviro it’s working now! Thank you :) I changed the algorithm from LBPH to Fisher regenerated the training.xml with train.py and my mirror can identify me :-D
                                          unfortunately I have new problem.
                                          Everything working great until only one person is in training.xml if it’s more then one person face is trained identify mirror the face but the name is always from the last person in the user list.
                                            reaper81 @paviro
                                            @paviro Wow, that was realy fast, thanks. Where can I find the new Option? Can you add them in your Github-Documentation?
                                            tosti007T 1 Reply Last reply
                                            • 10
                                            • 11
                                            • 7 / 11
