    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 570.6k Views 58 Watching
    • N
      nuckinfutz @nuckinfutz
      @nuckinfutz behelper beat me to it.
        benkej
        Hi guys,
        I have the same problem, tried with picam and normal webcam too.
        Capture working, train working, facerecognition_tester working, MMM-Facial-Recognition doesn’t work.
        Anyone sitting in front of the mirror, I get the message in terminal “User undefined with confidence null logged in”
        Y 1 Reply Last reply
        • N
          nuckinfutz @YourhighnessLeender
          @YourhighnessLeender Webcam is fine. If it worked in training it will work in the module.
          • Y
            YourhighnessLeender @nuckinfutz
            @nuckinfutz that is whats so strange. It does work in training but not in the module. Did a new install of the module and new training.xml but no luck. Very very wierd.
            Maybe I should buy a picam and try with that.
            • Y
              YourhighnessLeender @benkej
              @benkej question: did you change any of the capture settings in config.js? Like threshold etc? I was thinking of trying a different algorithm, did you try that?
              B 1 Reply Last reply
                benkej @YourhighnessLeender
                @YourhighnessLeender only for trial but I changed everything back to the default. I’m using raspberry pi 3 model b, here is part of my config:
                    module: 'MMM-Facial-Recognition',
                        // 1=LBPH | 2=Fisher | 3=Eigen
                        recognitionAlgorithm: 1,
                        // Threshold for the confidence of a recognized face before it's considered a
                        // positive match.  Confidence values below this threshold will be considered
                        // a positive match because the lower the confidence value, or distance, the
                        // more confident the algorithm is that the face was correctly detected.
                        lbphThreshold: 50,
                        fisherThreshold: 250,
                        eigenThreshold: 3000,
                        // force the use of a usb webcam on raspberry pi (on other platforms this is always true automatically)
                        useUSBCam: true,
                        // Path to your training xml
                        trainingFile: 'modules/MMM-Facial-Recognition/training.xml',
                        // recognition intervall in seconds (smaller number = faster but CPU intens!)
                        interval: 3,
                        // Logout delay after last recognition so that a user does not get instantly logged out if he turns away from the mirror for a few seconds
                        logoutDelay: 15,
                        // Array with usernames (copy and paste from training script)
                        users: ["Jani"],
                        //Module set used for strangers and if no user is detected
                        defaultClass: "default",
                        //Set of modules which should be shown for every user
                        everyoneClass: "everyone"
                and part of console log:
                [MMM-Facial-Recognition] Facerecognition started...
                [MMM-Facial-Recognition] Loading training data...
                [MMM-Facial-Recognition] ALGORITHM: LBPH
                [MMM-Facial-Recognition] Training data loaded!
                [MMM-Facial-Recognition] --------------------
                [MMM-Facial-Recognition] Webcam ausgewählt...
                [MMM-Facial-Recognition] User undefined with confidence null logged in.
                [MMM-Facial-Recognition] User undefined logged out.
                ^C[MMM-Facial-Recognition] Shutdown: Cleaning up camera...
                [MMM-Facial-Recognition] Terminating..
                @YourhighnessLeender and the output of train.py:
                Which algorithm do you want to use?
                [1] LBPHF (recommended)
                [2] Fisherfaces
                [3] Eigenfaces
                --> 1
                Reading training images...
                Assign label 1 to Jani
                Read 3 positive images and 400 negative images.
                3 images from subject Jani
                Training model...
                Training data saved to training.xml
                Please add or update (if you added new people not just new images) ['Jani'] inside config.js (mirror module) or config.py (model tester). You can change the names to whatever you want, just keep the same order and you'll be fine.
                Please add 1 as your choosen algorithm inside config.js (mirror module) or config.py (model tester).
                • Y
                  YourhighnessLeender
                  @benkej same as me, but no luck :-(
                    @YourhighnessLeender unfortunately yes :angry:
                    I try to reinstall the whole system
                    • Y
                      @benkej oke, please update on your progress. Good luck. Im very close to giving up.
                      • paviroP
                        paviro @PointPubMedia
                        @PointPubMedia Well sure but you could also write your own module listening for the notifications from my module :)
                        @bhepler said in Facial Recognition - customize your mirror for every user!:
                        @YourhighnessLeender Check your capitalization. Your training script output was ‘Johannes’ and your config.js has ‘johannes’.
                        This does not make any difference :)
                        @benkej said in Facial Recognition - customize your mirror for every user!:
                        You should definitely use more than 3 pictures! I use around 200 :D
                        – The Doctor
                        Y B 2 Replies Last reply
                        • Y
                          YourhighnessLeender @paviro
                          @paviro 200 pictures - aha! Maybe my 13 isnt enough. I can’t use the capture script since i’m on webcam so I took em with my phone and transferred them to the pi. I’ll add more and cross my fingers.
                          • paviroP
                            paviro
                            Well that could also be a cause. You should use the same camera for best results!
                            Why shouldn’t you be able to use a webcam with the capture script? I never used it with anything else to be honest :D
                            – The Doctor
                            • Y
                              @paviro hmm. Just can’t get it working for some reason… will try again. It complaind about no picam. Maybe I have to change something in the script? I’ll du another try.
                              • paviroP
                                paviro
                                Well the capture script does not have an enforce webcam option. Try to uninstall the picam python module, it will fallback to webcam then.
                                To minimize recognition errors the MagicMirror module requires two identical recognitions to be accepted as current user. If your training data is not good enough it could happen that you are never recognized twice in two directly following images -> Always unknown user.
                                – The Doctor
                                • Y
                                  @paviro thanks for the help. How do I uninstall the picam? Is it just to remove picam.py?
                                  • paviroP
                                    paviro
                                    Nooo! Don’t mess with the module code! I just added an option to force webcam use, checkout the updated code on GitHub :)
                                    – The Doctor
                                    Y 2 Replies Last reply
                                    Reply Quote 2
                                    • Y
                                      @paviro thanks paviro! Will do!
                                        benkej @paviro
                                        @paviro Thanks! I’ll add more images and try to recognize my face.
                                        But It’s very interesting that facerecognition_tester can identify me only from this three images
                                        paviroP 1 Reply Last reply
                                        • Y
                                          @paviro thanks!!! 200+ images captured and it’s now working :-) :pray: just need to tweak the threshold to be a bit more forgiving.
                                          • paviroP
                                            paviro @benkej
                                            @benkej as I stated the MagicMirror module need two identical identifies in a row :)
                                            @YourhighnessLeender glad to hear :)
                                            – The Doctor
                                            • 10
                                            • 11
                                            • 7 / 11
