    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 542.4k Views 58 Watching
      benkej @YourhighnessLeender
      @YourhighnessLeender unfortunately yes :angry:
      I try to reinstall the whole system
      • Y Offline
        YourhighnessLeender @benkej
        @benkej oke, please update on your progress. Good luck. Im very close to giving up.
        • paviroP Offline
          paviro @PointPubMedia
          @PointPubMedia Well sure but you could also write your own module listening for the notifications from my module :)
          @bhepler said in Facial Recognition - customize your mirror for every user!:
          @YourhighnessLeender Check your capitalization. Your training script output was ‘Johannes’ and your config.js has ‘johannes’.
          This does not make any difference :)
          @benkej said in Facial Recognition - customize your mirror for every user!:
          @YourhighnessLeender only for trial but I changed everything back to the default. I’m using raspberry pi 3 model b, here is part of my config:
          Read 3 positive images and 400 negative images.
          You should definitely use more than 3 pictures! I use around 200 :D
          – The Doctor
          Y B 2 Replies Last reply Reply Quote 0
          • Y Offline
            YourhighnessLeender @paviro
            @paviro 200 pictures - aha! Maybe my 13 isnt enough. I can’t use the capture script since i’m on webcam so I took em with my phone and transferred them to the pi. I’ll add more and cross my fingers.
            • paviroP Offline
              paviro
              Well that could also be a cause. You should use the same camera for best results!
              Why shouldn’t you be able to use a webcam with the capture script? I never used it with anything else to be honest :D
              – The Doctor
              Y 1 Reply Last reply Reply Quote 1
              • Y Offline
                @paviro hmm. Just can’t get it working for some reason… will try again. It complaind about no picam. Maybe I have to change something in the script? I’ll du another try.
                • paviroP Offline
                  paviro
                  Well the capture script does not have an enforce webcam option. Try to uninstall the picam python module, it will fallback to webcam then.
                  To minimize recognition errors the MagicMirror module requires two identical recognitions to be accepted as current user. If your training data is not good enough it could happen that you are never recognized twice in two directly following images -> Always unknown user.
                  – The Doctor
                  • Y Offline
                    @paviro thanks for the help. How do I uninstall the picam? Is it just to remove picam.py?
                    • paviroP Offline
                      paviro
                      Nooo! Don’t mess with the module code! I just added an option to force webcam use, checkout the updated code on GitHub :)
                      – The Doctor
                      Y 2 Replies Last reply Reply Quote 2
                      • Y Offline
                        @paviro thanks paviro! Will do!
                          benkej @paviro
                          @paviro Thanks! I’ll add more images and try to recognize my face.
                          But It’s very interesting that facerecognition_tester can identify me only from this three images
                          paviroP 1 Reply Last reply Reply Quote 0
                          • Y Offline
                            @paviro thanks!!! 200+ images captured and it’s now working :-) :pray: just need to tweak the threshold to be a bit more forgiving.
                            • paviroP Offline
                              paviro @benkej
                              @benkej as I stated the MagicMirror module need two identical identifies in a row :)
                              @YourhighnessLeender glad to hear :)
                              – The Doctor
                                benkej @paviro
                                @paviro 223 positive images and no success :( maybe I have to add more :blush:
                                What is the best practice to take the pictures? Sit closer to picam and rotate the face or not move and shoot few picture?
                                • paviroP Offline
                                  paviro
                                  I try to take pictures in different lighting conditions with slight changes in angle. One looking a bit down, one a bit to the left and so on.
                                  – The Doctor
                                    benkej @paviro
                                    @paviro ok, thank you
                                    • PointPubMediaP Offline
                                      PointPubMedia
                                      Not sure why, but got better performance with Fisher instead of LBPH
                                      • paviroP Offline
                                        paviro
                                        That’s why there are multiple algorithms :D Choose the one that works best for you :)
                                        – The Doctor
                                          reaper81
                                          hi, is it possible to turn off the popup-window “Gesichtserkennung …” when a face is tracked?
                                          • Y Offline
                                            YourhighnessLeender @reaper81
                                            @reaper81 just remove the notification module in config.js
                                            tosti007T I 2 Replies Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 7 / 11
