    Show SMS text message on Mirror
    17 Posts 5 Posters 11.6k Views 4 Watching
    • H Offline
      hawkesley @yawns
      @yawns Thanks, will look at that.
      In reply to strawberry I inserted this “::ffff:192.168.1.109”,
      Access denied on CLI was 192.168.1.109
      • H Offline
        hawkesley @hawkesley
        @hawkesley Hi,
        I tested ipW [] and that worked for MMM-syslog.
        I changed the ipW as suggested with “192.168.1.1/24” and that also works.
        So, thanks very much both.
        My remaining question is if I can send the message to MMM-syslog from outside my local network with this ipW?
        I will try later today.
        • yawnsY Offline
          yawns Moderator
          If you set up some port forwarding in your router and experiment with ipWhitelist that should work
          • michael24hM Offline
            michael24h
            @hawkesley said in Show SMS text message on Mirror:
            I install phone-notification-mirror as well. AlsoI installed MMM-syslog which working ok.
            http://MY-MIRROR-ip-ADRRESS/syslog?type=INFO&message=TEST, showing up on screen.
            but when I add module: phone_notification to config.js, I get only black screen
            my config:
            				module: 'phone_notification',
                        position: 'bottom_left',
                        header: 'Phone Notifications',
                        config:{
            					accessToken: "......token.......",
            					numberOfNotifications: 5,
            					displayNotificationIcon: true,
            					displayMessage: false,
            					displayCount: false,
            					alert: false,
            					fade: true,
            					maxCharacters: 50
            • H Offline
              hawkesley @michael24h
              @michael24h check you have the folder for phone notifications named correctlry in modules folder. Balck screen happened a couple of times for me and this was the problem.
                michael24h
                yea, thats was problem. I notice after post question
                  michael24h
                  Still no notification receive
                  how i can fix the issue?
