    Show SMS text message on Mirror
    17 Posts 5 Posters 12.5k Views 4 Watching
    • H Offline
      hawkesley
      Thanks will try both.
      • H Offline
        hawkesley @hawkesley
        @hawkesley
        Trying MMM-syslog but cant get access.
        This device is not allowed to access your mirror.
        Please check your config.js or config.js.sample to change this.
        I modified the whitelist as follows :e-mail:
        port: 8080,
        	ipWhitelist: ["::fff:0.0.0.0/1", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3", "::fff:224.0.0.0/4", "127.0.0.1", "::ffff:192.168.1.1/24", "::ffff:192.168.1.109","::ffff:127.0.0.1", "::1"],
        The http is : http://192.168.1.112:8080/syslog?type=normal&message=Test Message
        Any thoughts appreciated.
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @hawkesley
          @hawkesley did you insert exactly what was showing in the error to the whitelist?
          • Y Offline
            yawns Moderator
            To test, if MMM-syslog suits your requirements you could simply set ipWhitelist: [], which will allow all connections. In addition you might want to check this thread. In your case you could try to add "192.168.1.1/24" to support IPv4
            • H Offline
              hawkesley @yawns
              @yawns Thanks, will look at that.
              In reply to strawberry I inserted this “::ffff:192.168.1.109”,
              Access denied on CLI was 192.168.1.109
              • H Offline
                @hawkesley Hi,
                I tested ipW [] and that worked for MMM-syslog.
                I changed the ipW as suggested with “192.168.1.1/24” and that also works.
                So, thanks very much both.
                My remaining question is if I can send the message to MMM-syslog from outside my local network with this ipW?
                I will try later today.
                • Y Offline
                  yawns Moderator
                  If you set up some port forwarding in your router and experiment with ipWhitelist that should work
                  • michael24hM Offline
                    michael24h
                    @hawkesley said in Show SMS text message on Mirror:
                    I install phone-notification-mirror as well. AlsoI installed MMM-syslog which working ok.
                    http://MY-MIRROR-ip-ADRRESS/syslog?type=INFO&message=TEST, showing up on screen.
                    but when I add module: phone_notification to config.js, I get only black screen
                    my config:
                    				module: 'phone_notification',
                                position: 'bottom_left',
                                header: 'Phone Notifications',
                                config:{
                    					accessToken: "......token.......",
                    					numberOfNotifications: 5,
                    					displayNotificationIcon: true,
                    					displayMessage: false,
                    					displayCount: false,
                    					alert: false,
                    					fade: true,
                    					maxCharacters: 50
                    • H Offline
                      hawkesley @michael24h
                      @michael24h check you have the folder for phone notifications named correctlry in modules folder. Balck screen happened a couple of times for me and this was the problem.
                        michael24h
                        yea, thats was problem. I notice after post question
                          michael24h
                          Still no notification receive
                          how i can fix the issue?
