    Show SMS text message on Mirror
    17 Posts 5 Posters 12.1k Views 4 Watching
    • brobergB Offline
      broberg Project Sponsor
      https://www.pushbullet.com, yes works with ios.
      The syslog module works simply enough via http get,
      • H Offline
        hawkesley
        Thanks will try both.
        • H Offline
          hawkesley @hawkesley
          @hawkesley
          Trying MMM-syslog but cant get access.
          This device is not allowed to access your mirror.
          Please check your config.js or config.js.sample to change this.
          I modified the whitelist as follows :e-mail:
          port: 8080,
          	ipWhitelist: ["::fff:0.0.0.0/1", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3", "::fff:224.0.0.0/4", "127.0.0.1", "::ffff:192.168.1.1/24", "::ffff:192.168.1.109","::ffff:127.0.0.1", "::1"],
          The http is : http://192.168.1.112:8080/syslog?type=normal&message=Test Message
          Any thoughts appreciated.
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @hawkesley
            @hawkesley did you insert exactly what was showing in the error to the whitelist?
            • yawnsY Offline
              yawns Moderator
              To test, if MMM-syslog suits your requirements you could simply set ipWhitelist: [], which will allow all connections. In addition you might want to check this thread. In your case you could try to add "192.168.1.1/24" to support IPv4
              • H Offline
                hawkesley @yawns
                @yawns Thanks, will look at that.
                In reply to strawberry I inserted this “::ffff:192.168.1.109”,
                Access denied on CLI was 192.168.1.109
                • H Offline
                  @hawkesley Hi,
                  I tested ipW [] and that worked for MMM-syslog.
                  I changed the ipW as suggested with “192.168.1.1/24” and that also works.
                  So, thanks very much both.
                  My remaining question is if I can send the message to MMM-syslog from outside my local network with this ipW?
                  I will try later today.
                  • yawnsY Offline
                    yawns Moderator
                    If you set up some port forwarding in your router and experiment with ipWhitelist that should work
                    • michael24hM Offline
                      michael24h
                      @hawkesley said in Show SMS text message on Mirror:
                      I install phone-notification-mirror as well. AlsoI installed MMM-syslog which working ok.
                      http://MY-MIRROR-ip-ADRRESS/syslog?type=INFO&message=TEST, showing up on screen.
                      but when I add module: phone_notification to config.js, I get only black screen
                      my config:
                      				module: 'phone_notification',
                                  position: 'bottom_left',
                                  header: 'Phone Notifications',
                                  config:{
                      					accessToken: "......token.......",
                      					numberOfNotifications: 5,
                      					displayNotificationIcon: true,
                      					displayMessage: false,
                      					displayCount: false,
                      					alert: false,
                      					fade: true,
                      					maxCharacters: 50
                      • H Offline
                        hawkesley @michael24h
                        @michael24h check you have the folder for phone notifications named correctlry in modules folder. Balck screen happened a couple of times for me and this was the problem.
