    Fitbit
    129 Posts 42 Posters 210.7k Views 37 Watching
    • H Offline
      Hellangel1987 @olliewarren411
      @olliewarren411
      i set it all on that page. exeption was my location. but all other options are set.
      • H Offline
        @olliewarren411
        works! i sued your code. Delete the token. set it up new - start it with sudo npm start in MagicMirror directory. -> WORKS!
        I think i missunterstand the fibit API page where you have some buttons tu push and autorize the app (i think i pushed them in the wrong way)…
        You sayed something about your token.ini -> can you explain what exactly you have to to every day? i think about an cronjob for that - good chance to solve that together!
        And another option is the weight of my fitbit ARIA, these data are also available - how can we bind them into the app ?
        • O Offline
          olliewarren411 @Hellangel1987
          @Hellangel1987
          Glad to hear you got it working.
          I’m just trying to get the module to refresh more often. Not sure how to go about it.
          You probably could get your weight data in too, you’d need to contact the creator of the module for that.
          • K Offline
            kckndrgn @olliewarren411
            @olliewarren411 said in Fitbit:
            Yes, you can change the refresh interval. In the script MMM-fitbit.js you’ll see
            start: function() {
            		Log.info('Starting module: ' + this.name);
            		this.sendSocketNotification('SET CREDS',this.config.credentials)
            		this.sendSocketNotification('GET DATA', 'intial');
            		this.fadeSpeed = 500;
            		// Schedule update interval.
            		var self = this;
            		setInterval(function() {
            			self.updateData();
            		}, 60*60*1000);
            change the 60 x 60 x 1000 to an interval of your choosing. Just be careful to to refresh too often as you’ll get emails from FB telling you that you are pulling too much data. I think (and I’d have to check tonight) that I have mine set to 15 x 60 x 1000.
            • O Offline
              olliewarren411 @kckndrgn
              @kckndrgn
              Thanks! works perfect. I’ve copied your set up so it refreshes the data every 15 mins.
              • P Offline
                plumcraft
                I was getting invalid redirect_uri during the setup process. (sudo python setupAccess.py)
                But now It’s working for me, great module !
                • K Offline
                  kckndrgn
                  Anyway to get around having to run the setupAccess.py everyday/every other day to keep the tokens fresh?
                  Since I have to stop the MM from running, run the script to get new token, start MM again, it gets kind of annoying. I also run my Pi w/o keyboard/mouse so when I need to refresh the tokens I have to connect them.
                  I thought about adding a cron job to stop the MM, run the script and start MM, thoughts? Since the script leaves a browser window open, can the cron job kill it or is there a way to have the python script close the window when done?
                  TIA
                  • H Offline
                    Hellangel1987 @kckndrgn
                    @kckndrgn
                    dont know exactly but im also interested in your cronjob solution, can you inform us about your steps ? im tired getting every day that setupaccess working :(
                    • K Offline
                      kckndrgn @Hellangel1987
                      @Hellangel1987 said in Fitbit:
                      @kckndrgn
                      I haven’t done it, yet, just thinking about it since it was mentioned. I think I’ve narrowed down the issue though:
                      {"message": {"401": {"errors": [{"message": "Access token expired: eyJhbGciOiJIUzI1NiJ9.eyJzdWIiOiI0NU5QMzUiLCJhdWQiOiIyMjdRVjkiLCJpc3MiOiJGaXRiaXQiLCJ0eXAiOiJhY2Nlc3NfdG9rZW4iLCJzY29wZXMiOiJ3aHIgd3BybyB3bnV0IHdzbGUgd3dlaSB3c29jIHdhY3Qgd3NldCB3bG9jIiwiZXhwIjoxNDcxNzAxNjYzLCJpYXQiOjE0NzE2NzI4NjN9.VvLWtyYYvVShgrWC4UOVMXfdv0uiy7Nic-WDj7RMiKA. Visit https://dev.fitbit.com/docs/oauth2 for more information on the Fitbit Web API authorization process.", "errorType": "expired_token"}], "success": false}}, "type": "error"}
                      {"message": "Getting a new access token", "type": "status"}
                      {"message": "Error getting new access token", "type": "error"}
                      {"message": {"400": {"errors": [{"message": "Refresh token invalid: 4292cf037821b9441122e432bdd92a238fac61028dfbd6be982d2e6b73474c32. Visit https://dev.fitbit.com/docs/oauth2 for more information on the Fitbit Web API authorization process.", "errorType": "invalid_grant"}], "success": false}}, "type": "error"}
                      First got an “expired” token notice, then the process tries to get a new token (possibly using the “refresh” token, I’m not sure at this point). But refresh tokens are valid for one use only, so it’s like the updated token is getting updated in the token.ini file.
                      • P Offline
                        plumcraft
                        Also interested with the cron mechanism, the module could execute the setupAccess process once a day and trigger a reload on the gui ?
                        I’m using vnc to connect remotely on the RPI since i don’t have mouse/keyboards connected.
                        • K Offline
                          kckndrgn
                          3 days of syncing without an issue. Not sure what changed, I did pull the latest dev code for MM but made no changes to the fitbit module.
                          (of course now that I’ve said this, it will error out during the day :) )
                          • K Offline
                            kckndrgn
                            Had my first issues in a while last night. The problem was that my router lost internet connection and when it was restored the tokens were expired. I ran the setupAccess.py and got new tokens.
                            Seems that there should be a better way to reset the module on restart, like if the tokens are expired, the go get new ones.
                            • VendittelliV Offline
                              Vendittelli Module Developer
                              The python that accesses the fitbit API is currently having that functionality added, I’m doing some work at the moment to help with install issues and once the work on python-fitbit is complete I’ll update again.
                              • C Offline
                                chengstark
                                results: [{"message":"Writing credentials to credentials.ini","type":"status"},{"message":"Writing id: 227Z5P and secret: 55b8d28e28533664a52c6ec6a25b51f0","type":"status"},{"message":"Credentials write successful","type":"status"}]
                                nop
                                { Error: process exited with code 1
                                    at terminateIfNeeded (/home/pi/MagicMirror/modules/node_modules/python-shell/index.js:100:23)
                                    at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/node_modules/python-shell/index.js:88:9)
                                    at emitTwo (events.js:106:13)
                                    at ChildProcess.emit (events.js:191:7)
                                    at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
                                  executable: 'python',
                                  options: null,
                                  script: 'modules/MMM-fitbit/python/getData.py',
                                  args: null,
                                  exitCode: 1 }
                                i noticed that my mirror stopped getting data updates. it works yesterday but not today, can you help me identify where went wrong?
                                Note from admin: Please use Markdown on code snippets for easier reading!
                                • K Offline
                                  kckndrgn @chengstark
                                  @chengstark,
                                  Possibly the internet connection was lost during a refresh, this will cause the tokens to get out of date.
                                  I stop MM, re-run the “setupAccess.py” script using credentials from the file, then re-start MM and all is fine, until the next time I have an internet hiccup.
                                  • C Offline
                                    chengstark @kckndrgn
                                    @kckndrgn thanks, will try
                                      I have released a fix for the .ini files problem in the latest version on GitHub. You’ll need to delete your tokens.ini and credentials.ini files and remake them (as well as performing a git pull) for the fix to be effective.
                                        darrene
                                        For some reason, I’m getting calories displayed, but nothing else. @Vendittelli, does the module have any additional debugging or logging that I can turn on to look through? - I’m not getting any issues in dev mode or in the terminal - it seems that’s the only data I get. When I look in the dev console, I see:
                                        writing steps (data/goal): 0/10000
                                        Writing floors (data/goal): 0/10
                                        writing calories out (data/goal): 1664/2930
                                        writing distance (data/goal) 0/5
                                        writing activeminutes (data/goal): 0/30
                                        writing sleep (data/goal): 0/480
                                        When I clear down my tokens.ini and re-run the setupaccess.py, I can see the scope information for the token results includes u’social’, u’settings’, u’profile’, u’sleep’, u’activity’, u’heartrate’, u’weight’, u’nutrition’, u’location’
                                        if that’s helpful…
                                        As a slight aside: @olliewarren411, would you mind sharing your ‘vertical-layout’ css? I’m still trying to get my head around cascading style sheets!
                                        VendittelliV 1 Reply Last reply Reply Quote 0
                                          Vendittelli Module Developer @darrene
                                          @darrene That is weird. The module is pretty unadvanced so I don’t have proper debugging, unfortunately. The scope looks correct, are you sure you have synced your Fitbit today? It would explain why calories are displayed as they are calculated automatically so you don’t need to sync them.
                                            darrene @Vendittelli
                                            Thanks for the quick reply @Vendittelli - that could be the answer. I didn’r realise the calories were calculated like that - as you say, it’d certainly explain it.
                                            I’ll have a look into it. If it comes to it, I’ll recreate the app - I seem to remember there are a list of tick boxes for the fitibit attributes and on the pi browser, it was really difficult to tell whether or not they were ticked!
                                            • 6
                                            • 7
                                            • 3 / 7
