    Fitbit
    129 Posts 42 Posters 198.5k Views 37 Watching
    • H Offline
      Hellangel1987 @olliewarren411
      @olliewarren411
      i set it all on that page. exeption was my location. but all other options are set.
      • H Offline
        @olliewarren411
        works! i sued your code. Delete the token. set it up new - start it with sudo npm start in MagicMirror directory. -> WORKS!
        I think i missunterstand the fibit API page where you have some buttons tu push and autorize the app (i think i pushed them in the wrong way)…
        You sayed something about your token.ini -> can you explain what exactly you have to to every day? i think about an cronjob for that - good chance to solve that together!
        And another option is the weight of my fitbit ARIA, these data are also available - how can we bind them into the app ?
        • O Offline
          olliewarren411 @Hellangel1987
          @Hellangel1987
          Glad to hear you got it working.
          I’m just trying to get the module to refresh more often. Not sure how to go about it.
          You probably could get your weight data in too, you’d need to contact the creator of the module for that.
          • K Offline
            kckndrgn @olliewarren411
            @olliewarren411 said in Fitbit:
            Yes, you can change the refresh interval. In the script MMM-fitbit.js you’ll see
            start: function() {
            		Log.info('Starting module: ' + this.name);
            		this.sendSocketNotification('SET CREDS',this.config.credentials)
            		this.sendSocketNotification('GET DATA', 'intial');
            		this.fadeSpeed = 500;
            		// Schedule update interval.
            		var self = this;
            		setInterval(function() {
            			self.updateData();
            		}, 60*60*1000);
            change the 60 x 60 x 1000 to an interval of your choosing. Just be careful to to refresh too often as you’ll get emails from FB telling you that you are pulling too much data. I think (and I’d have to check tonight) that I have mine set to 15 x 60 x 1000.
            • O Offline
              olliewarren411 @kckndrgn
              @kckndrgn
              Thanks! works perfect. I’ve copied your set up so it refreshes the data every 15 mins.
              • P Offline
                plumcraft
                I was getting invalid redirect_uri during the setup process. (sudo python setupAccess.py)
                But now It’s working for me, great module !
                • K Offline
                  kckndrgn
                  Anyway to get around having to run the setupAccess.py everyday/every other day to keep the tokens fresh?
                  Since I have to stop the MM from running, run the script to get new token, start MM again, it gets kind of annoying. I also run my Pi w/o keyboard/mouse so when I need to refresh the tokens I have to connect them.
                  I thought about adding a cron job to stop the MM, run the script and start MM, thoughts? Since the script leaves a browser window open, can the cron job kill it or is there a way to have the python script close the window when done?
                  TIA
                  • H Offline
                    Hellangel1987 @kckndrgn
                    @kckndrgn
                    dont know exactly but im also interested in your cronjob solution, can you inform us about your steps ? im tired getting every day that setupaccess working :(
                    • K Offline
                      kckndrgn @Hellangel1987
                      @Hellangel1987 said in Fitbit:
                      @kckndrgn
                      I haven’t done it, yet, just thinking about it since it was mentioned. I think I’ve narrowed down the issue though:
                      {"message": {"401": {"errors": [{"message": "Access token expired: eyJhbGciOiJIUzI1NiJ9.eyJzdWIiOiI0NU5QMzUiLCJhdWQiOiIyMjdRVjkiLCJpc3MiOiJGaXRiaXQiLCJ0eXAiOiJhY2Nlc3NfdG9rZW4iLCJzY29wZXMiOiJ3aHIgd3BybyB3bnV0IHdzbGUgd3dlaSB3c29jIHdhY3Qgd3NldCB3bG9jIiwiZXhwIjoxNDcxNzAxNjYzLCJpYXQiOjE0NzE2NzI4NjN9.VvLWtyYYvVShgrWC4UOVMXfdv0uiy7Nic-WDj7RMiKA. Visit https://dev.fitbit.com/docs/oauth2 for more information on the Fitbit Web API authorization process.", "errorType": "expired_token"}], "success": false}}, "type": "error"}
                      {"message": "Getting a new access token", "type": "status"}
                      {"message": "Error getting new access token", "type": "error"}
                      {"message": {"400": {"errors": [{"message": "Refresh token invalid: 4292cf037821b9441122e432bdd92a238fac61028dfbd6be982d2e6b73474c32. Visit https://dev.fitbit.com/docs/oauth2 for more information on the Fitbit Web API authorization process.", "errorType": "invalid_grant"}], "success": false}}, "type": "error"}
                      First got an “expired” token notice, then the process tries to get a new token (possibly using the “refresh” token, I’m not sure at this point). But refresh tokens are valid for one use only, so it’s like the updated token is getting updated in the token.ini file.
                      • P Offline
                        plumcraft
                        Also interested with the cron mechanism, the module could execute the setupAccess process once a day and trigger a reload on the gui ?
                        I’m using vnc to connect remotely on the RPI since i don’t have mouse/keyboards connected.
                        • 6
                        • 7
                        • 12
                        • 13
                        • 5 / 13
