    Magic Mirror on PI 3
    pi 3 magic mirror
    7 Posts 3 Posters 3.8k Views 3 Watching
      akrishnan.j
      Hello,
      i am new to MM, after executing curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash,
      i am getting error on (image attached). I tried with npm update -g and the same is appearing.
        Davepre @akrishnan.j
        Hi Akrishnan.j ,
        I am very new to the MM as well. I had a similar error when I first installed but since its still a very early stage of the whole process I decided to start over and follow the complete setup tutorial provided by KirAsh4 step by step and suddenly it worked. Maybe just try to start over?
        here’s the link to the Tutorial.
        As said, I found it really helpful because it is very detailed and provides screenshots for every step.
        Best regards / Dave
        • yawnsY Offline
          yawns Moderator
          I too would recommend following the complete tutorial. Especially the update part of your raspberry is very important, I see both node and npm versions are very outdated.
            akrishnan.j @yawns
            @yawns HI, Thank you. I assumed the latest PI3 Raspian had the Most recent node versions. Seems not. In the process of upgrade
            yawnsY 1 Reply Last reply Reply Quote 0
            • yawnsY Offline
              yawns Moderator @akrishnan.j
              @akrishnan.j
              Right, I thought the same thing, that is very misleading.
                akrishnan.j @yawns
                @yawns After updating the Node atleast in my case to Ver 6 , it works now.
                • yawnsY Offline
                  @akrishnan.j
                  Great. Thanks for your feedback and enjoy your mirror :)
